Pagina 9 di 21 primaprima ... 789101119 ... ultimoultimo
Visualizzazione dei risultati da 81 a 90 su 207
[JB 4.2.2] · [PORT] · MIUI 5 · [mako] ·
  1. #81
    Androidiano VIP L'avatar di Ares77
    GN4 + DHD
    Ringraziato 529 volte in 359 Posts
    Quote Originariamente inviato da ryk Visualizza il messaggio
    Allora poi ho riavviato e riprovato a giocare ad Asphalt e la temperatura si si e' alzata ma comunque non e' andata a piu di 67
    Per il resto la rom e' bellissima
    No non ho provato
    L'unica cosa in WiFi a scaricare dal play store a volte va bene a volte scarica piu lento
    In download, e la prima cosa che proverò è la compatibilità con il multilanguage della vecchia release.... Comunque per chi fosse interessato ecco cosa è stato rom:
    After many PM's I decided to make a Current and Updated thread for MIUIv5 for our Nexus 4.
    Will update it with every new build and current fixes needed.
    This is based on a Port. Expect bugs until MIUI releases official.
    based on MIUIROM 3.6.21
    small MIUI Gapps, Franco Kernel r156 and extras
    Download ROM:
    ROM w/ small MIUI Gapps, Franco r156, and Extras:
    http://d-h.st/E8S
    LTE Fix:
    http://d-h.st/goo
    Flash file of your choice:
    Network Fix with Stock Nav Bar:
    http://d-h.st/HuQ
    Network Fix with 36DPI Nav Bar:
    http://d-h.st/jdf
    3.6.21 Changelog
    Spoiler
    Extras:
    Gapps (Gmail, Google Calendar, Google Gallery w/Photosphere Camera, Google Now, Maps, News&Weather, Play Store (Multi-DPI), Talk, Voice Search, Youtube)
    Adaway (for ads)
    DSP Manger
    Flash Player
    Google Installer (Install other Google apps)
    Mediascanner (scan media to show on computer when using USB)
    MIUI Keyboard
    MiuiSpnConf (to edit operator name in the status bar)(if you want nothing to show, just put a space only. Hit Save, then turn on then off Airplane manually through the status bar (dont use the airplane button in the app or it will FC)
    Rebooter (to preserve our power button's life)
    Weather BZ (working weather)
    LTE FIX (make sure to have .27 or .33 radio for LTE to work)
    No audio fix for t-mobile LTE users)
    What's Broken:
    You tell me.
    __________________________________________________ __________________________________________________ ___________________
    based on MIUIAndroid ROM 3.6.15
    with small MIUI Gapps, Network Location Fix, and Extras (Camera with Photosphere included)
    Option #1
    Download ROM:
    ROM w/ ☆ AK ☆ ak.035 kernel, small Miui Gapps, Network Location Fix, and extras:
    http://d-h.st/Rx2
    Extras included in ROM:
    Gapps (Gallery, Gmail, Google Calendar, Maps, Music, News&Weather, Play Store, Youtube)
    Removed Camera that came with ROM and added Camera with Photosphere
    MIUI Keyboard
    Themed AOSP Keyboard
    DSP Manger
    Adaway (for ads)
    Mediascanner (scan media for apps to show pics and music and for files to show on computer when using USB)
    Option #2
    Stock ROM Only no addons:
    MIUIAndroid 3.6.15Will update with AK kernel
    http://files.miuiandroid.com/3.6.15/..._jb-3.6.15.zip
    or
    http://tinyw.in/rNIE
    MIUI Small Gapps:
    http://d-h.st/gQr
    Fixes in this build:
    Geo Location working perfect. Check with News&Weather or Weather BZ app.
    Only one Permissions App in this base. No more Permissions FC.
    LED control added to Settings
    What's Broken:
    LBE Guard app will FC.
    You tell me.
    Working Kernels for MIUI:
    ☆ AK ☆
    http://forum.xda-developers.com/show....php?t=2316901
    Supercharged franco.Kernel - r155 | 3.4.49+ gcc 4.8.1 -O3-Modified by Nburnes
    http://d-h.st/Kf8
    Franco r156:
    http://forum.xda-developers.com/atta...8&d=1371679338
    Matrix
    http://forum.xda-developers.com/show....php?t=2007231
    Faux:
    http://forum.xda-developers.com/show....php?t=2008222
    Trinity:
    http://goo.gl/jPK5E
    Hells Core:
    normal:
    http://android.h0st.to/nexus4/kernel..._anykernel.zip
    hells:
    http://android.h0st.to/nexus4/kernel...rnel_hells.zip
    Optional: (Some are included in the ROMS)
    36 DPI navbar (3.6.21):
    http://d-h.st/Xd7
    36 DPI navbar (3.6.15):
    http://d-h.st/HEm
    MIUI Keyboard: (Flash)
    http://d-h.st/zdJ
    Lockscreen:
    http://forum.xda-developers.com/show...postcount=1186
    Clocks:
    CenterClock 3.6.21 Status bar: Posted by http://forum.xda-developers.com/show...&postcount=274
    http://d-h.st/DeR
    CenterClock 3.6.21 iOS Style Status bar: Posted by http://forum.xda-developers.com/show...&postcount=274
    http://d-h.st/QYd
    Stock 3.6.21 Status bar: Posted by http://forum.xda-developers.com/show...&postcount=274
    http://d-h.st/vGD
    Center Clock (3.6.15): Posted by http://forum.xda-developers.com/show...&postcount=112
    http://d-h.st/fLG
    Center Clock (3.6.15)iOS style) Posted by http://forum.xda-developers.com/show...&postcount=112
    http://d-h.st/YDy
    Stock Clock (3.6.15): (If you don't like the CenterClock Mod above, flash this to return to normal (Flash)
    http://d-h.st/mKG
    Cameras:
    Camera from MIUI ROM: (Flash)
    http://d-h.st/09H
    Camera with Photosphere: (Flash)
    http://d-h.st/NxT
    Camera:. Cool camera and you can take photo with the volume buttons (install apk)
    http://d-h.st/e30
    MIUI Camera: (Flash) (steps: fix only take 1 picture/ menu-> settings-> advanced functions-> off simple mode. Go back menu-> iso-> choose iso any ISO just not Auto ISO. Thanks: http://forum.xda-developers.com/show...&postcount=768
    http://d-h.st/X7F
    Steps:
    Wipe all (In TWRP wipe Factory Reset, System, Cache, Dalvik Cache, Flash ROM, wipe cache/dalvik)
    Flash ROM
    Boot
    Flash Network Fix (If needed)
    Boot
    Flash GAPPS (If needed)
    Boot
    Flash 36 DPI mod (OPTIONAL)
    Boot
    Sign in to Play Store
    Go to /Settings/Accounts/Google/Location settings and Enable "Let Google apps access your location"
    LTE users Go to Settings/Mobile networks/Access Point Names and now you should see T-mobile US LTE. Select that and restart.
    Thanks to:
    XDA-Developers
    MIUI for the source http://miuiandroid.com/community/
    KoaaN for the initial port
    lushengduan for his work
    luiseteyo and Soul_Raider for their threads
    Franco Kernel https://github.com/franciscofranco/mako/tree/nightlies)
    anarkia1976 Kernel http://forum.xda-developers.com/show....php?t=2316901)
    Many others who have been helping on the other MIUI threads.
    Se se stanco delle solite trollate e vuoi fare davvero sul serio, vieni con noi nel MVR: MANICOMIO VANILLA ROOTBOX.http://www.androidiani.com/forum/off...l-delirio.html.
  2. Il seguente Utente ha ringraziato Ares77 per il post:
    ryk (22-06-13)
    ryk
    ryk non è in linea
    Nexus 4,G2,Nexus 5,Xiaomi MI3
    Ringraziato 317 volte in 277 Posts
    Ares provata ? che te ne pare ? riscalda molto a te ?
  5. #83
    GN4 + DHD
    Si ryk provata ieri notte, ma non mi ha convinto, il telefono incandescente, poi sono al mare senza connessione etc, preferisco non rischiare.... Ah hi provato la 3.6 15 con AK...
  6. Il seguente Utente ha ringraziato Ares77 per il post:
    ryk (23-06-13)
  7. #84
    ryk
    ryk non è in linea
    Quote Originariamente inviato da Ares77 Visualizza il messaggio
    grazie per la risposta ah quindi anche quella con ak riscalda molto..anche a me quela con il franco troppo,credo di toglierla,peccato perche' mi piaceva comunque..
  8. #85
    GN4 + DHD
    Puoi sempre provare con un altro kernel, trovi quelli compatibili nel post di ieri...
    Hai provato anche le varie fotocamere?
  9. #86
    ryk
    ryk non è in linea
    No non ho provato le fotocamere,ora provo con un altro kernel e poi provo anche quelle
    Nexus 5 Rom Pac Man + ElementalX
    Xiaomi Mi3 Rom RayGlobe Miui
  10. #87
    GN4 + DHD
    Ottimo facci sapere
  11. Il seguente Utente ha ringraziato Ares77 per il post:
    ryk (24-06-13)
  12. #88
    E quello senza kernel AK si surriscalda molto?
  13. #89
    ryk
    ryk non è in linea
    Quote Originariamente inviato da SevenDay Visualizza il messaggio
    Oggi lo provo
  14. I seguenti 2 Utenti hanno ringraziato ryk per il post:
    Ares77 (24-06-13),SevenDay (24-06-13)
  15. #90
    Oggi lo provo
    Sei riuscito a testare il kernel? Il Franco con questa ROM anche con giochini semplici scalda veramente troppo
