Pagina 7 di 20 primaprima ... 5678917 ... ultimoultimo
Visualizzazione dei risultati da 61 a 70 su 200
[ ROM ] [4.4.2 KOT49H] [PSX+PSK] Pure Speed X
  1. #61
    Androidiano L'avatar di johnmuddy
    Ringraziato 68 volte in 44 Posts
    Non è necessario bootloader ne radio.
    Liscia significa che partendo dalla rom stock 4.4 fai factory reset e flash nuova ROM. È il metodo più conservativo ma che il più sicuro
    Senior Droid L'avatar di Giox96
    Nexus 4
    Ringraziato 215 volte in 169 Posts
    Qualcuno ha testato il modulo gravity box su questa rom? funziona l'opzione di aggiungere altre shortcut sul quicksetting?
    EDIT:Funziona perfettamente
    Ultima modifica di Giox96; 30-11-13 alle 12:34
    Nexus 4 (mako)//[ROM: RASTAPOP/ KERNEL: FRANCO r214]
    TWRP Recovery 2.8.1.0 / Modem 1.04 / Nova Launcher / ART
  4. #63
    ctfrommn:
    In sick of this entire thread and frankly the brand of users XDA has now..... I'm not losing another moments sleep over this crap. I'm done reading page after page of nitpicking, how this would be perfect if, user caused issues, and other ridiculousness. I'm certain I never solicited advice and opinion. This is a personal project I/we decided to share publicly...... I must say I'm sad I did. Reading this stuff day after day absolutely sucks all joy out of doing this.
    Somewhere along the line it became assumed that developers desire a never ending barrage of things the end user of a free product would like changed, doesn't like, or has some minute thing "wrong". There is no development talk going on here.
    I can't read anymore posts that contain things like... I love this ROM , but....
    Take it as it comes our use something different. In not sure why people think I get anything from the more people use this. This is not a budding career or some other money making endeavor.
    I tried to take a day off answering the endless supply of questions on a holiday only to open page after page of absolute nitpicking nonsense. I really don't like the direction these forums are going, and apart from the couple dozen very helpful people on here, the users either.
    This was not my vision for creating this or opening this thread. This was a core group of close "friends" before.... We bs'd , hung out, talked about all sorts of stuff.... It was nice. Then thousands of people start using it and the whole vibe is gone.....
    All this has managed to accomplish is to almost guarantee that v2 will be the final public XDA release. It truly saddens me that it would ever come to this. This is the result of unsolicited popularity.... It just kills the joy in doing this. I really, truly don't care if 5 or 5000 people like or use this. We build what we like for us. This isn't some commercial product we're trying to market.....
    I have no more to say about this...
    Thanks to all who have been helpful.... I'm certain you will still benefit from anything we choose to create in the future.
    Riassumendo: A causa degli utenti che dicevano " perchè non metti i pies, perchè non metti holo, perchè non metti questo, quello e quell'altro" lo sviluppatore ha deciso di rendere la psx privata perciò a meno di ripensamenti questa sarà l'ultimo aggiornamento che vedremo della PSX
    Ultima modifica di johnmuddy; 29-11-13 alle 21:39
  5. #64
    Bologna
    Sensation/nexus 4/S5
    volevo provare questa rom ma su xda leggevo di un possibile errore 7 o altro in fase di istallazione e che bisogna flashare una recovery pachata ma siccome di inglese ne so poco e con il traduttore non è così semplice chiedevo a chi la sta utilizzando se ci sono stati problemi o no e se si un chiarimento sulla soluzione adottata, ho già usato questa rom fino alla 8.5 e devo dire ottima rom grazie
  6. #65
    Senior Droid L'avatar di IImanuII
    Ringraziato 104 volte in 75 Posts
    Io non ho avuto alcun problema con la v2. Ho fatto così: salvato tutto con titanium, ripristinato stock con la 4.4, messa la cwm recovery, installato psx e gapps, messo kernel sempahore, messo xposed e gravitybox
  7. #66
    Quote Originariamente inviato da masgass Visualizza il messaggio
    considera che su XDA ci sono smanettoni level 100 , che fanno casini inimmaginabili sul sistema, perciò vai tranquillo con la solita procedura
  8. #67
    Nexus 4
    Con la TWRP recovery ho dovuto fare i Fix Permession altrimenti mi diceva Installation Failed
  9. #68
    Nexus 4
    Il Thread su XDA è stato chiuso
  10. #69
    Bologna
    Quote Originariamente inviato da giox96 Visualizza il messaggio
    Anche io ho la TWRP 2.6.3.3 e monto la rom rastakat 4.4 ma con altre rom kk mi è capitato istallation failed e una stringa che ora non ricordo,quindi per capire fai wipe factory reset,fix permission e poi flashi rom gapps e su giusto?
  11. #70
    Bologna
    Si ho visto e mi sembra di aver capito che si era stufato di utenti che chiedevano senza leggere e da un certo punto di vista lo posso capire ,però se ti metti a sviluppare una rom su un forum come XDA devi metterlo in conto,credo che continui a sviluppare ma su un forum privato ad invito io personalmente cerco sempre di documentarmi più che posso ma l'inglese lo mastico poco e niente e a volte devo chiedere non so voi ...
