Pagina 7 di 154 primaprima ... 567891757107 ... ultimoultimo
Visualizzazione dei risultati da 61 a 70 su 1538
[ROM] [4.4.4] [MAKO] Mahdi-Rom
  1. #61
    Senior Droid L'avatar di Giox96
    Nexus 4
    Ringraziato 215 volte in 169 Posts
    Nuova Build 11/01/14
    kernel/lge/mako
    -Added multi-rom support
    -Added double tap to wake by Stratosk - disabled by default
    -Linux v3.4.76
    frameworks/base
    -ActiveDisplay check for Immersive Mode Enable
    -Active display: Respect Quiet Hours
    -Quicksettings: Immersive mode tile add improved drawables
    -Add time-context headers to the notification header (1/2)
    -Fix notification header disappearing on tablets
    -Cleanup and enhance notification drawer header
    -Re-add auto brightness configuration UI (1/2)
    -Add method to PowerManager that allows querying the lowest possible
    -privacyguard: Share privacy package name between activity stacks
    -Fixed missing shading of statusbar circle battery and network traffic
    -Recents circle memory indicator fixes
    -GlobalActions.java: fix soft reboot
    -roll back all bluetooth changes
    -Quicksettings: LocationTile tile improvements by Slim
    -Revert "Keyguard: do not show maximized on simpin and several fixes"
    packages/apps/Settings
    -Storage Settings: Allow user to trigger a volume rescan
    -Add a custom notification panel header (2/2)
    -Fix led pulsespeedoff disable behaviour
    -Roll back all bluetooth changes
    -Fix exception in BatterySipper.getQuickNameIconForUid
    -Recover last location state during on/off switch
    -Quicksettings: change reference from GPS to Location
    packages/apps/LockClock
    -Merged with CM
    All of these projects have been restored to a near aosp state, which means that
    Audio/Video, Bluetooth and Camera are stock aosp so our Nexus devices will be running a lot better.
    external/bluetooth/bluedroid
    frameworks/av
    frameworks/native
    hardware/libhardware
    hardware/libhardware_legacy
    packages/apps/Bluetooth
    packages/apps/Camera2
    packages/apps/Gallery2
    I didn't get time to look at the screen cast problem but I will, I'm slowly getting through the bugs and you will have to give me some time,
    I've also updated the experimental kernel and features are in the op.
    Nexus 4 (mako)//[ROM: RASTAPOP/ KERNEL: FRANCO r214]
    TWRP Recovery 2.8.1.0 / Modem 1.04 / Nova Launcher / ART
    ryk
    ryk non è in linea
    Nexus 4,G2,Nexus 5,Xiaomi MI3
    Ringraziato 317 volte in 277 Posts
    Giox tu la stai usando ?
    Nexus 5 Rom Pac Man + ElementalX
    Xiaomi Mi3 Rom RayGlobe Miui
  4. #63
    Androidiano L'avatar di Biathedo
    Altamura
    Nexus 4
    Quote Originariamente inviato da Giox96 Visualizza il messaggio
    bastano i due wipe cache+dalvik per l'aggiornamento o sbaglio?
  5. #64
    Nexus 4
    Quote Originariamente inviato da ryk Visualizza il messaggio
    Yes, però adesso sto scaricando la SlimKat perchè sono curioso di provarla
  6. #65
    Nexus 4
    Quote Originariamente inviato da Biathedo Visualizza il messaggio
    Wipe System, cache e dalvik, poi riflash rom,gapps e supersu
  7. Il seguente Utente ha ringraziato Giox96 per il post:
    fpolle (12-03-14)
  8. #66
    Samsung Galaxy ace 2/Nexus 4
    Ringraziato 51 volte in 42 Posts
    Ora provo questa rom con l'ak,dicono che la batteria dura molto
  9. #67
    Ringraziato 70 volte in 60 Posts
    Anche il system dici anche solo per aggiornare da una precedente versione?non è che poi si riparte da 0 a dover configurate tutto quanto?
  10. #68
    Nexus 4
    Quote Originariamente inviato da elmarso Visualizza il messaggio
    Nono non dovrai fare nessuna configurazione all'avvio, io lo faccio per avere un installazione più pulita
  11. #69
    Facevo così pure io col galaxy nexus,poi qui avevo chiesto ma sembrava che non facesse il wipe system nessuno quindi pensavo avrebbe cancellato i dati.buono a sapersi,riprenderò a farlo allora
  12. #70
    Altamura
    Nexus 4
    Come mai anche supersu? quando l'ho installata la prima volta non l'ho flashato e ce l'ho lo stesso
