Pagina 14 di 17 primaprima ... 41213141516 ... ultimoultimo
Visualizzazione dei risultati da 131 a 140 su 163
[ROM][5.x.x][ SOKP-SONIC OPEN KANG PROJECT][AIO] Hammerhead
  1. #131
    Sep 2010
    ROMA
    Nexus 5,Gnex,Galaxy Giò
    New build MR 1.0 is out!!!
    SOKP-L-5.1.1-LMY48J-MR1.0-RELEASE-20150824-hammerhead.zip
    Updated To Android 5.1.1 r10
    First Milestone Release of SOKP in Android-L
    Fix Wallpaper changing issue.
    Switched Back to SaberMod Tool-chain for building ROM and Kernels of Both 32 bit and 64bit devices.
    Built with Heavy optimization using JustArchi's ArchiDroid Optimizations V4.1
    Security vulnerabilities fixes including CVE Fix
    TRDS 5.0 [original feature developed By Slim Rom] along with side by side compatibility with layers.[WIP]
    Navigation Ring Targets
    Add three-fingers-swipe to screenshot
    AppOps: fix delete ops wrongly matched issue
    Fix StrictMode violation during getDefaultApn
    SystemUI: more SlimDim performance boosts
    Fix telephony property access for CDMA rewrite rules in PhoneNumberUtils
    Fix intent resolution of default preferred apps
    Fix Auto selection of APN
    Various ART & Bionic optimizations
    init: Add support for gzipped firmware files
    Work around 32 bit glibc bug
    Add VMRuntime.clampGrowthLimit
    General Updates related to device trees and kernel.
    Ultima modifica di morfances; 24-08-15 alle 21:04
    Oneplus 9
    Oneplus 5 6/64
    ROM: Pixel Experience 9.0
    Nexus 5
    Galaxy Nexus (venduto)
    Senior Droid L'avatar di VashTheS
    Nov 2013
    Ringraziato 155 volte in 122 Posts
    Speriamo hanno sistemato parecchie cose, era piena di bug la scorsa release..
    La provò così vediamo se compete con xenonHD
  4. Il seguente Utente ha ringraziato VashTheS per il post:
    morfances (24-08-15)
  5. #133
    Androidiano VIP L'avatar di EneaMeeta
    Lograto (BS)
    Nexus5
    Ringraziato 307 volte in 256 Posts
    Abbiano !!!
    Inviato dal mio tostapane utilizzando tapatampax 😜
    Nexus5 Black
    ROM AICP
    Kernel ..........
    Se pesti una merda ... porta fortuna ... se il giorno dopo ne pesti un'altra ... doppia fortuna ... ma ... un pò meno furtuna non guasterebbe!!! Andrea Moretta
  6. Il seguente Utente ha ringraziato EneaMeeta per il post:
    Badu11 (25-08-15)
  7. #134
    Androidiano VIP L'avatar di dadenet
    GNexus, Nexus 5/6
    Ringraziato 1,209 volte in 954 Posts
    Per me ottima , floating mode funzionante , sul kernel sto ancora testando le potenzialità.
    with SCREW'D ROM + Adb e Fastboot command + Prima di flashare Rom e Kernel Guida ai Wipe
  8. Il seguente Utente ha ringraziato dadenet per il post:
    morfances (25-08-15)
  9. #135
    scusate io sono ancora alla versione precedente. ho avuto qualche problema di riavvii improvvisi ma niente di grave. ora però mentre stavo scrivendo un sms il telefono si è spento. provo ad accendere e non va. cioè mi compare la scritta google per un paio di secondi e poi si spegne!! non riesco nemmeno ad andare in recovery!!! qualche anima poi che mi da una mano. non so che fare!!!
  10. #136
    Sep 2010
    ROMA
    Quote Originariamente inviato da Saso84 Visualizza il messaggio
    forse è scarico..strano...non credo dipenda dalla rom.
    Se riesci ad andare in recovery fai un flash pulito della nuova build!!
    Oneplus 9
    Oneplus 5 6/64
    Nexus 5
  11. #137
    Si è ripreso da solo. Boooo. Ho subito fatto un flash della nuova build . La provo così... Come rom ha un sacco di funzioni e la batteria dura un casino, ma è un po instabile per i miei gusti.
  12. #138
    Lograto (BS)
    Nexus5
    Bah, io non noto questa instabilità che reclami, non mi ricordo nemmeno l'ultima volta che ho dovuto riavviare..
    Edit:
    Aggiornato ora, gran bell'aggiornamento di m....a!
    Come di consueto wipe cache, dalvik, system, flash ROM, gapps, bloatware, UKM, supersu, modulo xposed, reboot ............ non si avvia, parte la boot animations poi lo schermo diventa nero leggermente illuminato quando dovrebbero partire le ottimizzazioni non succede nulla per interminabili minuti, allora riavvio di nuovo in recovery e rifaccio da capo ma ottengo lo stesso risultato, allora ritorno in recovery e rifaccio ancora da capo ma senza flashare xposed, la ROM si avvia, conclusione xposed non è compatibile, dato che mi serve riavvio nuovamente e rimetto la R9.0 e tutto funziona, ma ......... cazzarola apro l'app google messenger ma crasha di continuo, cosi passo la gestione momentaneamente a hangouts e stranamente non mi visualizza gli SMS, Bah dico strano, non gli do peso e disinstallo messenger, lo reinstallo e la apro, attendere recupero conversazioni in corso ............. nulla ha trovato, l'app ora funziona ma gli SMS sono tutti spariti... Aiutoooooooooo
    Edit2:
    E adesso non funziona manco l'app google messenger, se la apro non mi lascia inviare i messaggi, non si apre la conversazione, se cerco di aprire l'app messenger dai contatti cliccando sulla bustinai dice impossibile aprire una conversazione, ma che cavolo è successooooo?
    Inoltre se cerco di inviare nuovi SMS con hangout non funzionano..
    Edit3:
    In definitiva non c'era modo di recuperare gli SMS e di far funzionare messenger, ho rifllashato la MR1.0 e tutto è tornato funzionante e gli SMS sono ricomparsi tutti..
    Che tra l'altro al primo flash l'app messenger andava in crash ora no.. Vabbè..
    Il problema ora è che xposed non funge, flashato l'ultima versione V71..
    Se lo installo non si avvia la ROM, rimane nella schermata successiva alla boot animation con lo schermo nero leggermente retroilluminato, ma non si avvia nulla..
    Qualcuno sa come risolvere?
    Ultima modifica di EneaMeeta; 26-08-15 alle 14:01
    Nexus5 Black
    ROM AICP
    Kernel ..........
  13. #139
    Quote Originariamente inviato da EneaMeeta Visualizza il messaggio
    Edit:
    Edit2:
    Edit3:
    Mah... Io non sono un grande esperto. Diciamo che mi piace smanettare e imparare piano cose nuove . da quanto ho capito questa rom non digerisce molto ulteriori modifiche. Va usata cosi com'è. Flash rom gapps e basta. Anche solo cambiando kernel va di fuori. Però la tengo perché apprezzo molto la durata della batteria. È l'unica che mi permette di fare una giornata intera. Per dire. Da stamattina dalle 8 fino ad ora.. Che sono le 23 e 30 sono al 18 per cento di batteria con un uso normale ( messaggi, qualche accesso su fb, un po di spotify e lettura di documenti o sul web).
  14. #140
    Lograto (BS)
    Nexus5
    Fino alla versione precedente xposed funzionava alla grande..
    Per il kernel non per contraddirti, ma provala con blu spark (ex code blue), va una bomba, power save aggressive e UV a -50 il resto stock, super fluida e durata batteria ottima, io ci faccio almeno 16 ore di standby con oltre 2/2,5 di schermo e ho sempre il Wi-Fi attivo, in più ho il dt2w e il fast charge che per me sono essenziali..
    Il blu spark non ha ne faux sound ne franco, ma sinceramente con il Dolby sono superflui..
    Nexus5 Black
    ROM AICP
    Kernel ..........
  15. I seguenti 2 Utenti hanno ringraziato EneaMeeta per il post:
    morfances (27-08-15),Saso84 (27-08-15)
