Pagina 7 di 11 primaprima ... 56789 ... ultimoultimo
Visualizzazione dei risultati da 61 a 70 su 104
[ROM][7.x]Pure Nexus for Hammerhead
  1. #61
    Sep 2010
    ROMA
    Nexus 5,Gnex,Galaxy Giò
    Nuova build!!
    purenexus_hammerhead-7.1.1-20170122-HOMEMADE.zip
    01/21/17 Release Changelog
    Change: update phone and calculator icons to circle icons
    Change: expose quick settings tuner switch bar for themers
    Change: expose settings switch bar for themers
    Change: expose settings dashboard category padding for themers
    Change: expose framework-res manifest styles for themers
    Change: sync statusbar battery style with quick setting battery
    Feature: Contextual Header images and image packs
    Feature: ability to change amount of rows in quick settings
    Feature: ability to disable quicksettings tile titles
    Feature: added one handed mode and toggle
    Feature: added double tap to sleep on navbar option
    Feature: added ability to hide vpn and data saver icon in statusbar icons
    Fix: speakerphone bug on nexus 6
    Fix: ok google everywhere on all devices even Pixels
    Fix: backup/restore functionality on Pixels
    Fix: home button force close issue with pixel animation enabled
    Fix: pixel animation toggle it now works instantly
    Fix: grayscale in ambient display inversion on dark themes
    Oneplus 9
    Oneplus 5 6/64
    ROM: Pixel Experience 9.0
    Nexus 5
    Galaxy Nexus (venduto)
    Ho installato l'ultima build, ma non mi trova più i permessi di root. Qualcun altro con lo stesso problema?
  4. #63
    Sep 2010
    ROMA
    Nuova build con tanti fix!!!
    https://www.androidfilehost.com/?fid=745425885120708530
    Updates Google+ Community BeansTown's Twitter Donate
    02/15/17 Release Changelog
    Update: update to latest february source android_7.1.1_r21
    Update: update proprietary binaries for all supported devices
    Update: update kernel source for all supported devices
    Update: update Masquerade app to latest version
    Added: initial translations for N have been merged
    Change: expose back icon tint color for themers in contacts common
    Change: expose adb N icon for themers
    Change: expose quick settings tiles tint color for themers
    Change: expose keyguard affordance circle background for themers
    Change: expose bluetooth pin confirm dialog text colors for themers
    Change: change numberpicker divider color to pixel blue
    Change: do not disturb tile longpress when active to show detail view
    Feature: add toggle to make bluetooth/data/wifi toggles east toggles
    Feature: add incall vibration options compatible with google dialer
    Feature: add option for immersive recent apps
    Feature: add option to enable a recents kill all fab button and location
    Feature: add option to enable/disable the quick setting battery icon syncing with statusbar
    Fix: sideloading of apks with certain apps installed (one handed mode regression)
    Fix: restore user brightness level after reboot with night light on
    Fix: visual glitch in network traffic meter
    La provo e vi faccio sapere
    edit : sembra funzioni tutto
    mod audio suggerita : https://www.androidfilehost.com/?fid=817550096634746597
    Con aroma scegliete quello che vi pare
    Ho flashato supersu per il root e usato le open gapps
    Ultima modifica di morfances; 16-02-17 alle 12:28
    Oneplus 9
    Oneplus 5 6/64
    Nexus 5
  5. I seguenti 2 Utenti hanno ringraziato morfances per il post:
    Aydan (16-02-17),BrokenEyes (27-02-17)
  6. #64
    Senior Droid L'avatar di dami118
    Ischia (NA)
    Google Nexus 5
    Ringraziato 36 volte in 34 Posts
    Io ho trovato un bug nel wifi: quando provo a connettermi a una rete wifi con protezione eap (ad esempio quella dell'Università) non mi fa premere su connetti. È un problema della rom suppongo perché con android stock non lo faceva
  7. #65
    Sep 2010
    ROMA
    Quote Originariamente inviato da dami118 Visualizza il messaggio
    Nessun problema con WiFi di casa e di ufficio
    Inviato dal mio Nexus 5 utilizzando Tapatalk
    Oneplus 9
    Oneplus 5 6/64
    Nexus 5
  8. #66
    Androidiano L'avatar di loziogiulio
    Ragazzi buongiorno,
    me la consigliate per un uso quotidiano? A Stabilità e batteria come siamo messi?
    Faccio un uso pro del telefono, quindi ufficio, whatsapp, social per lavoro e quant'altro, ma soprattutto il telefono dovrebbe coprire il giorno.
    Grazie!
    EDIT: sto con la versione 6 e mi trovo piuttosto bene.
  9. #67
    Aug 2013
    nexus 5
    Ho riscontrato questo problema anche io con altre rom. Credo sia proprio la versione di android, perché quando stavo su marshmallow non avevo questo problema.
  10. #68
    Senior Droid L'avatar di midnighteight
    Bari
    Nexus 5, Nexus 7, Galaxy S2
    Ringraziato 148 volte in 120 Posts
    Ciao a tutti, mi reputo un utente abbastanza esperto ma da un po' non seguo molto lo sviluppo della rom perchè ormai da mesi mi trovo molto bene con la Pure Nexus (marshmallow)+blu spark.
    E' arrivato però il momento di dare una bella pulita completa e vorrei sapere se mi conviene rimontare la stessa versione della pure nexus o valutare di passare a Nougat.
    Ecco quindi le mie domande:
    1) Nougat non è arrivato ufficialmente sul Nexus 5. La Pure nexus Nougat funziona al 100% o hao dovuto arrendersi a dei compromessi (funzioni non del tutto funzionanti o implementate, driver mancanti, ecc.)??
    2) La Pure Nexus Nougat attuale come va? funziona tutto? è stabile? è consigliata per un uso giornaliero e duraturo?
    Grazie mille a tutti!
    Google Nexus 5 - Pure Nexus + blu spark
    Google Nexus 7 WiFi (2012) - CyanogenMod 12.1
    <-- Se ti sono stato d'aiuto ringraziami con un Thanks!
  11. #69
    Sep 2010
    ROMA
    Quote Originariamente inviato da midnighteight Visualizza il messaggio
    Funziona tutto alla grande. Non ha ancora tutte le funzioni presenti in M. Credo che la sua rivale attuale sia la Aosp Extended. Credo con questo di aver risposto a entrambi i punti 1 e 2. A te la scelta
    Oneplus 9
    Oneplus 5 6/64
    Nexus 5
  12. I seguenti 2 Utenti hanno ringraziato morfances per il post:
    BrokenEyes (27-02-17),midnighteight (27-02-17)
  13. #70
    Bari
    Quale kernel mi consigliate di abbinarci ?? Sempre il blu_spark?
