Pagina 48 di 165 primaprima ... 3846474849505898148 ... ultimoultimo
Visualizzazione dei risultati da 471 a 480 su 1648
[SOS MODDING]Aiuti e consigli sul Modding!
  1. #471
    Androidiano VIP L'avatar di paolocorpo
    SAMSUNG S20+5G
    Ringraziato 1,766 volte in 1,666 Posts
    ASUS NEXUS 7 TOOLKIT AUTO UPDATE V4.3.7 [19TH MARCH 2013] AVAILABLE!!
    Changelog:
    +Updated SuperSu [root] files to V1.25 for all root procedures
    +Updated TWRP Touch Recovery to 2.4.4.0
    +Fixed Toolkit not Auto Updating properly from Toolkit Settings section
    +Added text in drivers section about disabling Driver Signature Enforcement
    +Fixed several bugs I encountered after the last run of tests
    +Fixed TWRP Recovery booting when CWM Recovery is chosen
    +Added text in Model Selection screen to support new builds when available
    For people who do not want or cannot get the Auto Update versions you can download 4.2.2 from Goo.im Downloads - Browsing stock and flash it via the Toolkit. You can download TWRP 2.4.4.0 from Goo.im Downloads - Browsing google_nexus7 and flash it via the Toolkit. You can also update the adb/fastboot files for 4.2.2 by downloading Goo.im Downloads - Browsing adb and overwriting the files. SuperSU can be updated to the latest version from the app.
    [Auto Updates are only accessible if you have donated to the Toolkit project, received an activation code and unlocked the professional features. Auto Updates are a much faster and easier way of pushing small updates that would otherwise not be worth doing. I can push a single textual change or add support for a new build without having to go through the whole process of building a full version and uploading a large file. IF you are not able to or do not want to donate to unlock the Auto Update feature (and other professional features) then all the smaller updates are collated and a full build made when I have time or if there are enough updates to warrant it. This is the easiest way to make sure all the Toolkits are as up to date as possible. IF you have any views about this please pm me about them and do not post in the open thread]
    Thread Link: [Google Nexus 7 TOOLKIT V4.0.0] Drivers, Backup, Unlock, Root, CWM, Flash + MUCH MORE - xda-developers
    Mark.
    Se non uccide fortifica
    FIGLIO - PIXEL45GStock11
    FIGLIA - IPHONE7
    MOGLIE - MiA1Stock9
    IO - S205G Stock11-TabSamA-TicwatchPro
    SPARE- GNEXOMNI 4.4.4, N4Stock4.4.4,Moto360 2nd,N7 3G, N5XGZSOP9.0, Mi6 6/64MIUI10 GloDev 9.6.27
    <-- Se ti sono stato utile, ricordati il THANKS
    Jul 2010
    Galaxy s4 - Galaxy Nexus
    salve a tutti domani mi arrivera il nexus 7. possiedo gia un galaxy nexus sbloccato e con custom rom.
    volevo chiedere se la procedura è la stessa e cioè col toolkit anziche fare un passaggio alla volta e cioè prima sblccare bootloader, root, recovery, potevo fare col tasto 8 del toolkit e cioè 1 clock for all e successivamente mi metto la twrp con goomanager che mi piace di piu' come recovery.
    @paolocorpo la versione da te postata del toolkit è la 4.3.7 ma sul thread di xda c'è solo la 4.0.0
    poi una piccola domanda offtopic..
    posso utilizzare lo stesso account che ho sul galaxy nexus? le app che nel caso ho acquistato rimarranno solamente per il telefono giusto e non per il tablet? quali sono le controindicazioni?
    Ultima modifica di gulp; 19-03-13 alle 23:19
  4. #473
    Androidiano VIP L'avatar di stefan95
    Nexus 4, Nexus 7, S4, LG G2
    Ringraziato 156 volte in 141 Posts
    la 4.0.0 é l'ultima versione FREE
    quella che dice paolo é la Donate
    Esiste il tasto 8 Click for all
  5. #474
    Androidiano VIP L'avatar di lebrac
    LG P990, Nexus 7
    Ringraziato 782 volte in 578 Posts
    Quote Originariamente inviato da gulp Visualizza il messaggio
    Se metti lo stesso account se le hai comprate potrai usarle in entrambi i dispositivi... É quello il bello :-D
    Inviato dal mio Nexus 7 con Tapatalk HD
    GUIDE UTILI:
    - MULTIROM NEXUS 7
    - GUIDA AL WUG'S TOOLKIT
    - GUIDA WIPE/FORMAT
    NON FACCIO SUPPORTO VIA PM, POSTATE NEI THREAD.
  6. #475
    SAMSUNG S20+5G
    La versione free è la 4.0.0
    Eseguendo una donazione e quindi ricevendo un seriale si attiva un updater che lo porta sino alla 4.3.7
    FIGLIA - IPHONE7
    MOGLIE - MiA1Stock9
  7. #476
    Ragazzi ho letto del Franco kernel, ottimo soprattutto per la batteria. Vi chiedo, ma per installarlo c'è bisogno di una custom ROM o basta solo root e bootloader? Grazie
    Inviato dal mio Nexus 7 con Tapatalk 2
  8. #477
    Ti serve la Recovery modificata
  9. #478
    Jul 2010
    E cosa ha in più la donate? Quanto costa?
  10. #479
    SAMSUNG S20+5G
    La donate (che si ottiene inserenedo un codice il che si ottine facendo una donazione minima di 3 GBP) ti permette di poter aggiornare di tanto in tanto
    Se leggi in giro ci sono toolki alternativi, ed anche dei workaround per aggirare il mancato aggiornamento (sin qui almeno 4 volte) della versione free
    A te la scelta
    Io l'ho fatto
    FIGLIA - IPHONE7
    MOGLIE - MiA1Stock9
  11. #480
    LG P990, Nexus 7
    Ad esempio il wug's nexus toolkit totalmente gratuito.
    GUIDE UTILI:
    - MULTIROM NEXUS 7
    - GUIDA WIPE/FORMAT
