Pagina 66 di 165 primaprima ... 1656646566676876116 ... ultimoultimo
Visualizzazione dei risultati da 651 a 660 su 1648
[SOS MODDING]Aiuti e consigli sul Modding!
  1. #651
    Androidiano VIP L'avatar di lebrac
    LG P990, Nexus 7
    Ringraziato 782 volte in 578 Posts
    Quote Originariamente inviato da XxmentxX Visualizza il messaggio
    Si ho il root
    Allora se hai una recovery modificata flasha una rom....Oppure ripristini il tablet come appena comprato
    GUIDE UTILI:
    - MULTIROM NEXUS 7
    - GUIDA AL WUG'S TOOLKIT
    - GUIDA WIPE/FORMAT
    NON FACCIO SUPPORTO VIA PM, POSTATE NEI THREAD.
    Androidiano VIP L'avatar di paolocorpo
    SAMSUNG S20+5G
    Ringraziato 1,766 volte in 1,666 Posts
    ASUS NEXUS 7 TOOLKIT PUBLIC RELEASE V5.0.0 AVAILABLE!!
    mskip May 4, 2013 Google Nexus 7
    DONWLOAD LINK: http://goo.im/devs/mskip/toolkit/goo...Kit_v5.0.0.exe
    ChangeLog:
    +Completely restructured Toolkit code
    +FULL Support upto JellyBean 4.2.2 (all models)
    +Added model zip file download system after model selection to reduce download size
    +Default driver installation is now koush’s Universal driver pack which works upto and including Windows 8
    +Check md5 of stock image to make sure downloaded file isn’t corrupted before flashing
    +Downloaded stock image file is copied to the ‘backups’ folder before flashing for future use
    +Added adb sideload for auto flashing zip files
    +All stock images now downloaded from goo.im so the link won’t be broken if google delete the file
    +Latest CWM and TWRP Recovery images included
    +Lots more minor improvements and changes to nearly all procedures
    Thread Link: [Google Nexus 7 TOOLKIT V5.0.0] Drivers, Backup, Unlock, Root, Recovery, Flash + MORE - xda-developers
    Enjoy.
    Mark.
    Ultima modifica di paolocorpo; 05-05-13 alle 08:51
    Se non uccide fortifica
    FIGLIO - PIXEL45GStock11
    FIGLIA - IPHONE7
    MOGLIE - MiA1Stock9
    IO - S205G Stock11-TabSamA-TicwatchPro
    SPARE- GNEXOMNI 4.4.4, N4Stock4.4.4,Moto360 2nd,N7 3G, N5XGZSOP9.0, Mi6 6/64MIUI10 GloDev 9.6.27
    <-- Se ti sono stato utile, ricordati il THANKS
  4. #653
    Jan 2011
    Salve ragazzi, volevo sapere se ottenendo i permessi di root si poteva aumentare l'uscita audio traimite jack modificando qualche file di sistema o utilizzando qualche app.
  5. #654
    SAMSUNG S20+5G
    Quote Originariamente inviato da Daviduccio Visualizza il messaggio
    Non è il root in se ma la possibilità che esso ti offrre di usare qualche app, mod e rom per migliorare l'audio
    Dicono che la cyano sotto questo aseptto migliora e di molto l'audio ma non ne ho esperienza diretta
    FIGLIA - IPHONE7
    MOGLIE - MiA1Stock9
  6. #655
    Jan 2011
    Quote Originariamente inviato da paolocorpo Visualizza il messaggio
    Si il senso era quello. Cioè attraverso i permessi modificare qualche file di sistema Comunque proverò, grazie
  7. #656
    LG P990, Nexus 7
    Si ci sono delle app...volume+ o volume boost non ricordo
    GUIDE UTILI:
    - MULTIROM NEXUS 7
    - GUIDA WIPE/FORMAT
  8. Il seguente Utente ha ringraziato lebrac per il post:
    Daviduccio (05-05-13)
  9. #657
    Androidiano L'avatar di BlackDark
    Ragazzi aiuto
    Sono entrato in recovery stock del nexus e è uscito nessun comando col droid con un triangolino
    Come fare per fare il reboot? Aiutatemi vi prego non si riavvia
    edit:
    risolto
    Ultima modifica di BlackDark; 06-05-13 alle 20:30
  10. #658
    Jul 2010
    Avevo letto da qualche parte (non ricordo dove) che cercavate il modo di mandare sms con il nexus7... Io sono riuscito parzialmente così (solo da web 10 al giorno gratuiti Vodafone o Tim) fate così., scaricate" ermete sms"anche se incompatibile installatelo lo stesso sul tablet magari tramite pc, poi mettete il vostro account Vodafone /Tim fatto! Se pur con il limite dei 10 messaggi solo verso il vostro operatore (gratuitamente) io mi trovo bene!
  11. #659
    LG P990, Nexus 7
    Quote Originariamente inviato da led zeppelin Visualizza il messaggio
    Prova anche freesmee...in pratica utlizza vari servizi per inviare sms gratis o a basso costo, tra cui anche i 10 al giorno della vodafone (+ altri 10 emulando un widget vodafone = 20 sms al di)
    GUIDE UTILI:
    - MULTIROM NEXUS 7
    - GUIDA WIPE/FORMAT
  12. Il seguente Utente ha ringraziato lebrac per il post:
    led zeppelin (06-05-13)
  13. #660
    Ragazzi per via di skygo e della formula 1 ancora non ho messo il kernel. Cosa mi consigliate tra franco kernel (preferito) ed m-kernel? A me serve ESCLUSIVAMENTE per aumentare la durata della batteria. A me arriva se tutto va bene a 6 ore di schermo ma devo vedere video o skygo, se lo uso per navigare non arrivo a più di 5 ore. In più odio quando lascio inattivo il tablet e poi oplà un 2% in meno, su un articolo che lessi il franco kernel migliora proprio sulla durata in standby. Dunque, cosa mi consigliate?
    Inviato dal mio Nexus 7 con Tapatalk 2
