Pagina 17 di 21 primaprima ... 71516171819 ... ultimoultimo
Visualizzazione dei risultati da 161 a 170 su 210
[ROM] [KK 4.4.x] [UFFICIALE] CyanogenMod 11
  1. #161
    Nexus 5X
    Ringraziato 63 volte in 48 Posts
    Causa crash continui della M6 ed imminente crisi di nervi ho dovuto decidere cosa fare...
    Dopo aver letto questo: CM 11 M4: Post-release Items | CyanogenMod
    ed in particolare
    So what are the release streams?
    There are effectively 3 release streams for CM: Nightlies, M/Stable, and Installer:
    Nightlies are always the most bleeding edge in code, features, and yes, bugs (including the kind that may prevent the device from booting at all).
    Update process: Flash a new nightly on top of the old – no need to wipe
    M/Stable are specifically tagged, branched, tested and released. If you are a tinkerer but adverse to the chaos of nightlies, this is for you.
    Update process: Flash a new M/Stable on top of the previous M/Stable – no need to wipe
    Installer builds are those served via the CM Installer applications (Windows, Mac). These builds are specially signed and named separately – there is no concept of an ‘M’ build for this release channel – so saying ‘Installer skipped M#’ is an incorrect interpretation. This channel only ever receives specially created Stable builds – they even come with their own naming structure (eg XNPQ02R).
    Update process: Incremental OTA’s are provided using the CMFota application – updates are handled by device logic with minimal user interaction, no wipe needed
    If you are a nightly user, use nightlies. If you prefer to tinker but want something less chaotic, use the M/Stables. If you aren’t a tinkerer and don’t want chaos, use the Installer builds (if available).
    ho quindi fatto un wipe completo e ho deciso di installare la CM 11 attraverso l'installer ( CyanogenMod | Downloads ). Dato che anche le M-release si sono rivelate inaffidabili, credo che la versione installata dall'installer sia quanto di più simile vi possa essere ad una stable. La release attuale installata dall'installer è ad occhio una variante della M3.
    N.B.
    In pratica adesso ci sono queste 3 versioni:
    1) Nightly
    2) M-release
    3) Installer build
    Il primo post di questo thread andrebbe aggiornato di conseguenza.
    Ultima modifica di ekerazha; 19-05-14 alle 12:57
    Nexus S
    Quote Originariamente inviato da ekerazha Visualizza il messaggio
    E come ti trovi ora?
  4. #163
    Nexus 5X
    Quote Originariamente inviato da EadWard Visualizza il messaggio
    Bene... ha qualche funzione in meno delle ultime M-release ma ha anche meno bug, diciamo che viene aggiornata in corrispondenza di M-release particolarmente stabili. Gli unici bug che ho trovato (peraltro presenti anche nelle ultime M-release) sono relativi al launcher, ad esempio la scritta all'interno della barra di ricerca a volte sparisce (poco male, io la barra di ricerca la nascondo, visto che sul Nexus S è inutile perché c'è il tasto Cerca fisico).
    My device: Nexus 5X
    My projects: Guru kernel for Nexus S [discontinued]
  5. #164
    Nexus S
    Quali funzioni in meno hai trovato?
  6. #165
    Nexus 5X
    Ad esempio non ci sono il reverse lookup ecc. nel dialer...
    My device: Nexus 5X
  7. #166
    Ragazzi io oggi ho installato la versione del 20 di maggio come nightly e devo dire che funziona tutto abbastanza bene... Non ho più i problemi di impuntamento e di crash di systemui, unico problema che sto riscontranto è un po' di battery drain ma credo che lo risolverò cambiando kernel
  8. #167
    Androidiano L'avatar di VegetaSSJ5
    Google Nexus 4
    Il battery drain si presenta con quale modalità di localizzazione? (alta precisione, basso consumo, solo dispositivo, off)
  9. #168
    Off è proprio che la batteria va via in 2 ore scarse a causa del fatto che passa il 50% del tempo in deep sleep e il 50% a 1000mhz... Non ci sono kernel alternativi per 4.4.2 su nexus s? (su S3 stesso problema risolto cambiando appunto il kernel)
  10. #169
    Google Nexus 4
    beh da come hai descritto credo che sia un bug che risolveranno prossimamente....
  11. #170
    Google Nexus 4
    sul forum di xda confermano di aver risolto il bug dei crash, ma confermano il problema del battery drain introdotto con la versione di ieri... ci tocca aspettare le prossime nightly. anzi, da come il team cm ha detto nel post di rilascio della M6, ora i rilasci di versioni più o meno stabili dovrebbero essere quindicinali (cosa in parte confermata dal changelog della nightly del 20 maggio, che è molto corposo), tuttavia sono giá in ritardo con il primo rilascio di questa nuova tipologia di versioni (la m6 era del 4 maggio).
