Pagina 17 di 17 primaprima ... 7151617
Visualizzazione dei risultati da 161 a 166 su 166
[ROM] Viper10 | Android N ◦ Tweaks | HUB | OTA
  1. #161
    Moderatore L'avatar di sirioo
    Naples
    Oneplus 11 16/256
    Ringraziato 1,287 volte in 1,060 Posts
    Viper10 5.8.0 (27th March)
    The update will trigger an cache rebuild, so be patient, the boot after the update will take a while!
    Additions & Updates
    • Fullrom only
      • Updated to latest Magisk 11.6
      • Updated to latest MagiskManager 2.4.7
    • Swipe Up on homescreen to open appdrawer
    • Random Animation and Interpolation type
    • Whitelist for random Animation and Interpolation types
    • Custom shortcut for appdrawer (previous option was just for custom applications)
    • Option to hide lock icon on lockscreen
    • Option to set a custom image for your lock icon
    Fixes & Cleanups
    • Fixed camera custom gallery app setting not working for HTC Gallery
    OTA:
    Get the update via the OTA System directly on your device via VenomTweaks->OTA Update
    Magisk users: Download and flash the OTA manually.
    FULLROMS:
    Device : OP11 Grey - 16/256 | Rom : OOS 14 BA | Audio Mod : Dolby Atmos + ViperFX RE | Kernel: Stock | Recovery : Stock
    NON ACCETTO RICHIESTE DI AIUTO IN PRIVATO
    ****RISPETTA IL REGOLAMENTO DEL FORUM****
  2. Il seguente Utente ha ringraziato sirioo per il post:
    iLuke (02-04-17)
    Naples
    Oneplus 11 16/256
    Viper10 5.9.0 (6th April)
    Additions & Updates
    • Fullrom only
      • Updated to Magisk 12.0
      • Updated to MagiskManager to 4.3.1
    • Option for Signal Icons on left
    • Option for Battery on left
    • Option to remove app drawer, places all your apps on your homescreen instead
    • Change switches track and thumb color system wide
    • Settings icons take color of the one you select for the checked thumb switch state.
    • Custom calender shortcut now also working for the header
    • Option to hide the date in the header
    • Added additional html time formats in VenomTweaks, includes now three new ones with date included
    Fixes & Cleanups
    • Fixed headsup timeout
    • Fixed clock color resetting temporarily when expanding and collapsing the statusbar
    OTA:
    FULLROMS:
  5. Il seguente Utente ha ringraziato sirioo per il post:
    kaos80 (04-05-17)
  6. #163
    Trento
    HTC M8-ONE X+-ZOPO Speed 7 Plu
    siamo già alla versione 5.11.0
  7. #164
    Trento
    sapete per caso come fare per spostare le apps dalla memoria interna alla SD ?? io ci ho provato ma non me ne lascia spostare nemmeno una
  8. #165
    Senior Droid L'avatar di mistertenente
    Nov 2013
    Ringraziato 82 volte in 78 Posts
    Secondo voi è la migliore rom per il 10?
  9. #166
    Nov 2013
    Quote Originariamente inviato da zhunghuo Visualizza il messaggio
    Mi sa che devi impostare la SD come memoria di sistema, poi farà tutto da solo
