Pagina 19 di 118 primaprima ... 917181920212969 ... ultimoultimo
Visualizzazione dei risultati da 181 a 190 su 1180
IceColdSandwich - Android 4.0.4 (ICS) - AOKP
  1. #181
    Apr 2011
    Diversi bug come già detto prima alla fotocamera ai video e alle applicazioni non ancora conpatibili che vanno in crash
    Inviato dal mio HTC Desire HD usando Tapatalk
    Androidiano L'avatar di andram
    Dec 2009
    HTC Desire HD
    Ringraziato 18 volte in 14 Posts
    Vi informo che è stata appena aggiornata alla versione:
    IceColdSandwich 5.5 - OLIVE EDITION - 12/03/2012
    Mirror1
    MD5: 4c5f11e4bf7dfcd1613d3dfab2ddd612
    parecchi ed interessanti gli aggiornamenti...
    • added Own Phone number option
    • updated translations trough out the ROM
    • updated Dutch translation in ROMControl by nielsnll
    • added back About menu option in ROMControl - it's AOKP's work after alll
    • added custom brightness settings - AOKP
    • added Greek dictionary
    • added Croatian dictionary
    • removed Home.apk
    • removed GoogleLatinIME - that secon keyboard
    • updated Trebuchet
    • speeded up FPS in some apps like gmail, facebook...
    • added Startup tweaks to ROMControl
    • fixed button backlight with non-automatic brighness
    • added ADB over network
    • updated overlay script - better support for .tgz
    • ported Profiles options/settings/powermenu to AOKP from CyanogenMod
    • ported Quiet hours to AOKP from CyanogenMod
    • updated GooManager to 1.5.2
    • added Fast Charge toggle - it was always in the kernel (ON by default in my kernel, some have issues when connecting to car charger, so now it can be turned OFF) ONLY FOR THOSE WHO NEED IT!!!
    • who knows what we broke with all this stuff now
    sono in fase di download!!
    Ciao e buona serata
    HTC Desire HD
    IceColdSandwich 8.8 AOKP - ICS 4.0.4
    RIL HTC-RIL 2.2.0018G
    Radio 12.69a.60.29U_26.17.14.11_M
    Kernel 2.6.35.14-LorDmodUE-10.1-ICS-BFS
    HTC Magic Black 32A
    Recovery ClockworkMod 2.5.0.7
    Ginger Yoshi 1.5 - GB 2.3.5
    Radio 62.52S.20.18U_3.22.20.17
    Kernel 2.6.35.13-farmatito
  4. #183
    Dec 2009
    HTC Desire HD
    Il reparto fotocamera STOCK ha subito dei piccoli aggiustamenti ma ancora non siamo apposto.
    Adesso la modalità "panorama" riesce a lavorare. (la qualità del risultato non è al top)
    Lo zoom digitale genera i soliti problemi (righe colorate sul bordo).
    Unica soluzione per la cam per adesso è seguire i consigli di Linux33it... Notte
    4.1.1
    adesso i filmati vengono riprodotti perfettamente anche in HD
    anche you tube funziona regolarmente
    non vedo artefatti da nessuna parte (fino ad adesso)
    manca la possibilita' di fare video ma si puo risolvere installando tpcamera
    basta scaricare questo pacchetto e copiare i tre files con un file manager in data/app e riavviare...
    HTC Desire HD
    HTC Magic Black 32A
  5. #184
    Raga scusate la domanda,ma è una mia semplice curiosità! Ho letto che htc ha rilasciato i sorgenti per l'ottimizzazione audio beats e che un modder ne aveva ricavato un pacchetto flashabile x portare questa esclusiva su tutti i terminali android! Da quando sono venuto a conoscenza di questa notizia mi sono posto la domanda se fosse possibile flashare quel pacchetto anche su questa rom(dato ke fotocamera a parte mi ci trovo bene soprattutto x i consumi)?
    P.s. Lo stesso quesito vale x il bravia engine!
    Inviato dal mio HTC Desire HD usando Androidiani App
    HTC Desire HD
    Radio Version: 26.14.04.28_M
    Rom: IceColdSandwich 5.5
    Kernel: 2.6.35.14 - LorDmodUE-8.9b7-CFS-ICS+
    AndroidVersion: 4.0.3
  6. #185
    Androidiani Power User
    Dec 2009
    Rimini
    Quote Originariamente inviato da ykim88 Visualizza il messaggio
    pare che sia solo per GB,comunque puoi vedere qui
    https://www.androidiani.com/applicaz...-android-87606
  7. #186
    Richtc
    attualmente funziona con tutti i dispositivi Gingerbread e non con ice cream sandwich ma arriverà anche per ics..per bravia engine non lo so
  8. #187
    Torino
    DHD,S2,XperiaS,HOX
    O non sono capace a impostarlo oppure non funziona: parlo del tempo che passa prima che si attivi il blocco schermo tramite pin (sequenza pin o password). ovvero una volta che blocchiamo lo schermo con il tasto power possiamo decidere dopo quando entra in funziono il blocco tramite pin, entro tale tempo possiamo andare a sbloccare lo schermo senza dover inserire nessun tipo di codice. se non sbaglio andando in impostazioni, sicurezza, blocco automatico dovrebbe essere possibile cambiare il tempo prima che sia obbligatorio inserire un pin per sbloccare il telefono. ditemi se sto sbagliando qualcosa, se in realtà è un'impostazione diversa, oppure se ancora non è funzionante. anche perchè l'iphone è dal 2g che è possibile decidere dopo quanto inserire il pin, cosa a mio dire molto molto utile. comunque per adesso è veramente un'ottima rom. un'altro problema che segnalo (forse vale solo per me) ma il led di notifica funziona solo in verde e non in arancio.
  9. #188
    Apr 2011
    Ragazzi scusate oggi mi e caduto il cell e mi si e spaccato il display. Come rom ho la 5.5 .x fare valere la garanzia oltre a installare la rom originale devo togliere anche lo sblocco? Grazie
  10. #189
    Dec 2009
    Rimini
    Quote Originariamente inviato da dj8simo6 Visualizza il messaggio
    il problema non è lo sblocco, la rottura dello schermo per caduta non è coperto da garanzia
  11. #190
    Androidiano VIP L'avatar di Sinir696
    Apr 2011
    Desire HD
    Ringraziato 48 volte in 39 Posts
    Non credo che abbia mai corazzato un cellulare come il dhd... il terrore che se mi cade si rompe...brrr..... comunque il blocco del cellulare te lo consiglio li stesso metti caso che ti mettessero in conto anche il blocco del cellulare che di solito fanno... te Linux porti qualche protezione al dhd?
    Desire hd completamente sbloccato! mi sembra una descrizione abbastanza completa!
    Nexus 7 preso e sbloccato tutto nello stesso giorno!
