Pagina 50 di 72 primaprima ... 40484950515260 ... ultimoultimo
Visualizzazione dei risultati da 491 a 500 su 714
Nik Project X v4.1 By Nikhil007 a.k.a Nikhil Dhayatka
  1. #491
    Androidiano VIP L'avatar di wexus
    Feb 2011
    Ringraziato 263 volte in 198 Posts
    Quote Originariamente inviato da Senso41
    Devo dire con molta educazione e rammarico, ma ci sta comunque lasciando anche Nik purtroppo
    Originariamente inviato da nikhil007mmus
    Guys to tell you all recently i reported my device was screwed and i got it fixed . after using it for two days the device still had problems with the charging and stuff .. so i went to the service centre and they told me that the motherboard seems screwed .. Finally the phone was dead and i had already spent lots of money already on it .. My Htc Incredible s is gone ..
    I got the HTC OneX as i found no use in fixing the incredible s as it costed like lots..
    But no worries i didnt have the desire hd or desire s but still roms were released for them .. so its gna be the same for the incredible s from now ..
    I am surely gonna be continuing my work for the incs no matter what !!
    All the good things have to come to an end .. Im sad but im happy for the support i got from this community .. Look forward to the Transformer cz its still coming .. if anyone has a crappy old incs ( extra one ) i would really appreciate it !!
    and if u guys want to upgrade , do upgrade to the HTC OneX cz im gna be there in a wile
    OT: riguardo la rom cinese citata in questo forum, per il problema lingua sembra che si risolvi con questa applicazione nel play https://play.google.com/store/apps/d...ccl.morelocale.
    Forse sarebbe da aprire una discussione, visto che è la seconda sense4 full, e che sembra funzioni tutto, hotspot compreso.
    Per chi la volesse provare ecco il link diretto https://dl.dropbox.com/u/6797224/And....4Sense4.0.zip
    Ma perché non non tradurlo dato che non tutti sanno l 'inglese. Grazie
    PS :ci molla anche nik?????? Noooo
    Inviato dal mio HTC Desire HD usando Androidiani App
    Un THANKS al giorno leva il medico d'intorno!!!
    Androidiano VIP L'avatar di Senso41
    Apr 2011
    XIAOMI MI A2 4/64
    Ringraziato 2,334 volte in 1,670 Posts
    Quote Originariamente inviato da wexus Visualizza il messaggio
    Il suo Incredible S riparato è definitivamente andato, e riparare la scheda madre costa troppo. Ha preso quindi un ONE X.
    Sembra comunque che la rom fatta per l'Incredible la porterà sui Desire.
    Ci credo poco ma vedremo...
    Xiaomi Mi A2
  4. #493
    Senior Droid L'avatar di daddeHD
    Rimini
    Nexus 4 16GB - Nexus 7 16GB
    Ringraziato 129 volte in 123 Posts
    penso che possiate stare moderatamente tranquilli,
    il senso del post di nick,in poche parole è questo:
    mi si è definitivamente rotto l'incredible s e non vale la pena di ripararlo.
    non temete poichè come ho fatto e faccio per il Desire HD e l'S non abbandonero' l'incredible pertanto continuero' lo sviluppo in ogni caso
    (se qualcuno ha un incredible da buttare lo prendo volentieri)
    fine
    Nexus 4 16GB Rev.11 ROM - SlimKat 4.4.4 build 8 Stable
    KERNEL - 3.4.94 SlimKat 4.4 3.9 RADIO - 2.0.1701.03
    Nexus 7 2012 16GB ROM - Purity 4.4.4 build 19/09/14
  5. #494
    Senior Droid L'avatar di Lucky81
    Xiaomi Mi5 Pro
    Ringraziato 72 volte in 62 Posts
    Speriamo bene...
    Intanto sabato mi è caduto dalle mani il mio DHD e adesso non mi funziona più il Wi-Fi, il bluetooth ed il tasto volume giù...
    Lo riparerenno in garanzia?!? Ho seri dubbi...
    Xiaomi Mi5 Ceramic - 4Gb 128Gb -
    MIUI 9 Global Beta
    Samsung Note 10.1 GT N-8000
  6. #495
    Sep 2010
  7. #496
    Androidiano VIP L'avatar di markusssss
    Scafati
    Xiaomi Redmi Note 3 Pro
    Ringraziato 90 volte in 78 Posts
    Speriamo che rilasci presto qualche aggiornamento :-D
    Inviato dal mio HTC Desire HD con Tapatalk 2
    Se ti ho aiutato a risolvere il problema clicca sul tasto Thanks qui sotto ↓
  8. #497
    Androidiano L'avatar di fulvio87
    GALAXY S5
    Con questa rom sono molto soddisfatto per la velocità di risposta , ma purtroppo come consumi è troppo .
    Riesco a fare al massimo 16 ore con la batteria , con 50 min di schermo , 30 min di chiamate, e nn lo sto usando al massimo come faccio di solito .
    La mattina mi sveglio, lo stacco dalla carica e accendo la connessione dati, arrivo a lavoro dopo nemmeno un ora e gia sta a 95% senza averlo usato...
    Peccato perchè come velocità è veramente ottima
    SAMSUNG GALAXY S III GT-I9300
    S.O: Android Jelly Bean 4.1.1
    SD: SAMSUNG 16GB Classe 10
    HTC Desire HD
    ROM: Jelly Bean TIME v.28
    Android : 4.1.2
    Radio: 12.69a.60.29_26.17.14.11_M
  9. #498
    Senior Droid L'avatar di peppe68
    Ringraziato 63 volte in 49 Posts
    Quote Originariamente inviato da fulvio87 Visualizza il messaggio
    Prova a scaricarlo fino all'1% e dopo il primo spegnimento a riavviarlo e vedere quanti minuti ci puoi fare ancora con il display e carica 1%. Al secondo spegnimento quello definitivo ricaricalo senza accenderlo per tutta la notte.
  10. #499
    GALAXY S5
    Già fatto ma , l'unica cosa che nn ho mai fatto è caricarlo tutta la notte da spento perche ho la sveglia , e da spendo nn funge.
    Però stasera proverò. Grazie
    HTC Desire HD
    Android : 4.1.2
  11. #500
    Feb 2011
    Hai ragione! Stessa identica situazione. Allora non sono il solo, vedo scritto che gente, che come questa rom i consumi Cosí ridotti non si sono mai visti. Cacchio il terminale é uguale x tutti, a parte ha installare delle applicazioni disattivare dari abbassare la luminosità eccc, non cambia di molto la situazione e diciamolo, avere un terminale e non poter tenere la luminosità a stecca perché mi piace con la paura di consumare la batteria e staccate i dati e cosí via, é davvero triste. Pensate che ormai foto con doppia batteria e sempre il carica batteria, davvero triste, eppure ho provato delle rom che consumavano pochissimo ma poi come sempre vengono abbandonate. Mi dispiace dirlo, io che gli iphoniani non mi vanno giú e la politica di Apple nemmeno, devo confermare che i loro terminali sono davvero formidabili sia come hardware e software, qua sono mesi che si brancola bel buio x avere una rom che fa acqua da tutte le parti....
