Pagina 257 di 275 primaprima ... 157207247255256257258259267 ... ultimoultimo
Visualizzazione dei risultati da 2,561 a 2,570 su 2747
[Rom] Android Revolution HD 2.0.0 (Android 2.2.1 basato su ROM 1.72.405.3)
  1. #2561
    Androidiano VIP L'avatar di lorefly
    Nov 2010
    livorno
    samsung galaxy s2
    Ringraziato 26 volte in 23 Posts
    una domanda ma quando si mette un tema compatibile con la revo come mai lo sfondo che si vede nel tema non lo si trova ma si ritrova lo sfondo della rom originale?
    come faccio ad inserire lo sfondo del tema?
    Samsung Galaxy Note 2
    Codice Modello: GT-7100
    Gestore Telefonico: H3g
    Rom: Omega v18
    Kernel: Stock
    Baseband MG1
    Versione Android: JB 4.1.2
    Nov 2010
    livorno
    samsung galaxy s2
    Questo log con la revo 2.1 tutto attivo come la veinte?
    2011/03/05 00:37:07,-101mA,100%
    2011/03/05 00:39:32,-1mA,100%
    2011/03/05 00:41:12,-166mA,100%
    2011/03/05 00:42:17,-181mA,100%
    2011/03/05 00:43:17,-98mA,100%
    2011/03/05 00:46:24,-180mA,100%
    2011/03/05 00:48:09,-181mA,100%
    2011/03/05 00:49:14,-50mA,100%
    2011/03/05 00:51:29,-4mA,100%
    2011/03/05 00:52:48,-175mA,100%
    2011/03/05 00:57:12,-166mA,100%
    2011/03/05 01:00:42,-4mA,100%
    2011/03/05 01:03:33,-176mA,100%
    2011/03/05 01:05:30,-4mA,100%
    2011/03/05 01:07:39,-180mA,100%
    2011/03/05 01:09:31,-4mA,100%
    2011/03/05 01:10:39,-1mA,99%
    2011/03/05 01:15:42,-1mA,99%
    2011/03/05 01:17:15,-182mA,99%
    2011/03/05 01:20:27,-162mA,99%
    2011/03/05 01:21:30,-4mA,99%
    2011/03/05 01:22:30,-183mA,99%
    2011/03/05 01:24:39,-162mA,99%
    2011/03/05 01:26:04,-164mA,99%
    2011/03/05 01:32:04,-166mA,99%
    2011/03/05 01:37:10,-164mA,99%
    2011/03/05 01:38:27,-4mA,99%
    2011/03/05 01:39:32,-4mA,99%
    2011/03/05 01:41:27,-174mA,99%
    2011/03/05 01:51:20,-1mA,99%
    2011/03/05 01:52:47,-169mA,99%
    2011/03/05 01:54:00,-161mA,98%
    2011/03/05 02:00:42,-4mA,98%
    2011/03/05 02:07:37,-162mA,98%
    2011/03/05 02:08:54,-1mA,98%
    Sent from my Desire HD using Tapatalk
    Rom: Omega v18
    Kernel: Stock
    Baseband MG1
  4. #2563
    Senior Droid L'avatar di famonaco
    ciao ragazzi e' da un po che non mi collegavo ( sono in colombia) e ho visto la nuova release 3 della revo, io ho la 14 coome la flasho???? come sempre??? full wipe, flasho e ok o devo cambiare qualkosa???? kernel????
  5. #2564
    Androidiano VIP L'avatar di molko
    Feb 2011
    Htc ONE
    Ringraziato 47 volte in 42 Posts
    Quote Originariamente inviato da famonaco Visualizza il messaggio
    Si come al solito, cmq tutte le istruzioni le trovi nel thread dedicato:
    https://www.androidiani.com/forum/mo...2-v-3-x-x.html
  6. #2565
    Androidiano VIP L'avatar di ITAIce
    Feb 2011
    Monza & Brianza
    Galaxy Note 3, Galaxy Tab 10.1
    Ringraziato 257 volte in 239 Posts
    Ciao a tutti,
    scusate, ma il link per il kernel leeDroid 2.2.4 non funziona... sapreste indicarmi un link alternativo? Non vorrei fare pasticci e scaricarne uno sbagliato...
    Apr 2010
    Droidland
    Quote Originariamente inviato da ITAIce Visualizza il messaggio
    Ciao a tutti,
    Index of /DHD-Kernels/
  8. Il seguente Utente ha ringraziato thay per il post:
    ITAIce (05-03-11)
  9. #2567
    Androidiano L'avatar di dhd79
    Mar 2011
    milano
    XIAOMI REDMI 3
    buon giorno a tutti raga....
    ho flshato la arhd 3....tutto fila liscio come l'olio....
    solo una cosa mi sembra un po strana ,quando entro in un applicazione anche senza girare il mitico dhd ruota automaticamente la schermata,cosa che prima non accadeva,
    sapete dirmi se ho toccato qualche impostazione?
    comunque ho provato diverse rom tra e piu nominate e questa android revolution penso che sia la migliore rom con sense....
  10. #2568
    Banned
    Jan 2011
    Quote Originariamente inviato da dhd79 Visualizza il messaggio
    È un bug!;-) credo ci sia un fix tramite patch..cmq in questo momento la revo nn è affatto la rom migliore..purtroppo l'autore sembra essere un po confuso sul da farsi e rilascia le sue belle versioni troppo presto senza averle testate a dovere..risultato..questi bug..parche da flashare..e sbattimenti vari..cmq
    .io amo le revo e spero che tornino Al top già dalla prossima.versione..se vuoi provare le due rom sense. Poi cazzute del momento ti consiglio come prima scelta la CoreDroid..come.seconda scelta la RCMix hd!
  11. #2569
    Mar 2011
    milano
    XIAOMI REDMI 3
    devo dirti che :la CORE DROID l'ho provata ma mi si pianta il tel...mentre la RCMix hd l'ho scaricata ma al momento del flash si ferma l'istalazione e mi dice flash fallito........pero con la revolution mi trovo bene apparte questo bug che va e non va.Quando parli della RCMix hd ti riferisci a quella nuova con build 1.86.......giusto?
  12. #2570
    Banned
    Jan 2011
    Come sarebbe ti si pianta il telefono? Ma lo fai fullwipe prima di installare Un rom??
