Pagina 96 di 195 primaprima ... 46869495969798106146 ... ultimoultimo
Visualizzazione dei risultati da 951 a 960 su 1946
Monitorare il Consumo della Batteria
  1. #951
    Androidiano VIP L'avatar di Rantolux
    Feb 2011
    Xiaomi Mi 8
    Ringraziato 514 volte in 446 Posts
    Quote Originariamente inviato da lifestream Visualizza il messaggio
    2011/04/07 03:20:22,-216mA,100%
    2011/04/07 03:22:09,-3mA,100%
    2011/04/07 03:25:52,-3mA,100%
    2011/04/07 03:30:07,-3mA,100%
    2011/04/07 03:31:08,-3mA,100%
    2011/04/07 03:32:44,-3mA,100%
    2011/04/07 03:37:29,-3mA,100%
    2011/04/07 03:41:37,-3mA,100%
    2011/04/07 03:42:45,-3mA,99%
    2011/04/07 03:45:23,-3mA,99%
    2011/04/07 03:48:08,-3mA,99%
    2011/04/07 03:49:09,-3mA,99%
    2011/04/07 03:59:09,-3mA,99%
    2011/04/07 04:00:12,-3mA,99%
    2011/04/07 04:10:05,-5mA,99%
    2011/04/07 04:14:28,-50mA,99%
    2011/04/07 04:15:28,-133mA,99%
    2011/04/07 04:17:13,-166mA,99%
    2011/04/07 04:20:05,-3mA,99%
    2011/04/07 04:30:13,-3mA,98%
    2011/04/07 04:31:15,-5mA,98%
    2011/04/07 04:41:08,-5mA,98%
    2011/04/07 04:44:13,-3mA,98%
    2011/04/07 04:45:13,-3mA,98%
    2011/04/07 04:50:05,-5mA,98%
    2011/04/07 05:00:13,-3mA,98%
    2011/04/07 05:10:06,-3mA,97%
    2011/04/07 05:12:20,-15mA,97%
    2011/04/07 05:13:20,-15mA,97%
    2011/04/07 05:14:58,-49mA,97%
    2011/04/07 05:20:05,-14mA,97%
    2011/04/07 05:30:12,-3mA,97%
    2011/04/07 05:31:17,-3mA,97%
    2011/04/07 05:33:37,-144mA,97%
    2011/04/07 05:40:21,-5mA,97%
    2011/04/07 05:41:21,-5mA,97%
    2011/04/07 05:45:25,-3mA,97%
    2011/04/07 05:50:05,-5mA,97%
    2011/04/07 06:00:13,-3mA,96%
    2011/04/07 06:08:22,-3mA,96%
    2011/04/07 06:09:23,-5mA,96%
    2011/04/07 06:15:24,-129mA,96%
    2011/04/07 06:20:05,-3mA,96%
    2011/04/07 06:30:13,-3mA,96%
    2011/04/07 06:31:22,-3mA,96%
    2011/04/07 06:36:23,-5mA,95%
    2011/04/07 06:37:23,-5mA,95%
    2011/04/07 06:45:25,-3mA,95%
    2011/04/07 06:50:05,-3mA,95%
    2011/04/07 07:00:13,-8mA,95%
    2011/04/07 07:04:23,-5mA,95%
    2011/04/07 07:05:24,-5mA,95%
    2011/04/07 07:15:25,-3mA,95%
    2011/04/07 07:20:06,-3mA,95%
    2011/04/07 07:30:13,-15mA,95%
    2011/04/07 07:31:26,-5mA,94%
    2011/04/07 07:32:26,-5mA,94%
    2011/04/07 07:33:27,-3mA,94%
    2011/04/07 07:43:19,-9mA,94%
    2011/04/07 07:44:19,-120mA,94%
    2011/04/07 07:45:19,-88mA,94%
    Questi sono i consumi in 3g in stand-by dopo aver fatto la calibrazione. La cosa che ho notato è che non appena ho iniziato ad usare la rete i consumi si alzano vertiginosamente, in 35 minuti di navigazione la batteria è scesa sino all'87% il che mi sembra eccessivo voi che ne pensate? Il kernel che utilizzo è quello in firma.
    bhè questo log è accettabile. da quanto monti l'attuale rom?
    tieni conto che la connessione dati consuma leggermente di più del wi-fi, ma in quei 35 minuti se hai navigato più che la connessione il display ti ha scaricato la batteria
    Xiaomi Mi 9
    Senior Droid L'avatar di lifestream
    Feb 2011
    Quote Originariamente inviato da Rantolux Visualizza il messaggio
    E' da ieri che la monto ma comunque la luminosità del display l'ho sempre tenuta al minimo
    HTC Desire HD Rooted ENG S-off
    4EXTRecovery 2.1.1b
    Rom ---> Miui 1.12.2
    Kernel---> Stock
    Radio--->26.09.04.11_M2
    Motorola Xoom 3G 32Gb Rooted
    Rom ---> Nightly ICS EOS Team xoom 3g
  4. #953
    Feb 2011
    Xiaomi Mi 8
    tieni conto che la rom deve avere un periodo di assestamento, nel mio caso ho avuto consumi sotto 1% ora solo dopo almeno una settimana di utilizzo
    Xiaomi Mi 9
  5. #954
    Androidiano L'avatar di stalk3r88
    Apr 2011
    Ragazzi è possibile che in carica vedendo log si legge:
    es:
    minuto 1 -->55%
    minuto 3 -->57%
    minuto 5 -->59%
    minuto 7 -->61%
    minuto 9 -->63%
    cioè ogni 2 minuti salga di 2% mentre altri minuti di carica resta per 4 minuti allo stesso livello di %??
    ...<<L'esperienza è il nome che l'uomo dà ai propri sbagli>>...
  6. #955
    Feb 2011
    Xiaomi Mi 8
    Quote Originariamente inviato da stalk3r88 Visualizza il messaggio
    es:
    minuto 1 -->55%
    minuto 3 -->57%
    minuto 5 -->59%
    minuto 7 -->61%
    minuto 9 -->63%
    non sò che senso abbia ciò.......però la carica non essendo spento il telefono non può essere costante, visto che accendendo il display in vari momenti, tutte le varie app che girano nel sistema in modo non costante........fa si che la corrente entrante non viene interamente accumulata ma viene utilizzata per le varie operazioni e questo utilizzo non è sempre uguale
    Xiaomi Mi 9
  7. Il seguente Utente ha ringraziato Rantolux per il post:
    stalk3r88 (07-04-11)
  8. #956
    MLK
    MLK non è in linea
    Androidiano L'avatar di MLK
    Nov 2010
    HTC Desire HD
    ho calibrato la batteria come nella guida ma noto che dopo il riavvio la batteria scende al 99 per poi risalire quasi subito a 100.. il problema è però che l'amperaggio non scende mai a 0!
    che impostazioni devo avere al riavvio? tutto attivo o tutto spento? che frequenza di aggiornamento x il widget?
  9. #957
    Androidiano VIP L'avatar di Orco
    Aug 2010
    Crema
    Ringraziato 183 volte in 170 Posts
    Quote Originariamente inviato da MLK Visualizza il messaggio
    Certo, perchè durante il riavvio la batteria non ricarica, però consuma e consuma parecchio, quindi te la ritrovi a 99%, ma subito dopo ricomincia la carica, quindi te lo ritrovi al 100%. Per avere 0mA in Current Widget devi attendere almeno per un'oretta!! Ci vuole pazienza!!
    [SIZE=1]HTC Desire HD Rooted & ENG S-OFF
    ROM: SP33_ITALIA_1.0.0_AROMAfull
    RADIO: 26.09.04.11_M2
    KERNEL: 3.0.93-ucdx
    RECOVERY: 4EXTRecovery Touch 1.0.0.5 RC9
  10. #958
    Feb 2011
    Xiaomi Mi 8
    Al riavvio è normale che scende al 99% per poi risalire perchè ancora sotto carica, poi come vedi anche quando è arrivato al 100% il widget di current non ti dà un amperaggio pari a 0, questo ti indica che pur al 100% la batteria non è completamente carica.
    Lo 0 nel widget lo raggiungerà tra circa 40 minuti a quel punto potrai staccare il caricabatteria perchè la batteria è carica completamente e la calibratura è finita
    Xiaomi Mi 9
  11. #959
    MLK
    MLK non è in linea
    Nov 2010
    HTC Desire HD
    ah ecco grazie.. pensavo fosse una cosa più immediata..
    ho lasciato 60 come aggiornamento..
  12. #960
    Feb 2011
    Xiaomi Mi 8
    non toccare nulla nell'app currentwidget
    Xiaomi Mi 9
