Questo è il build.pro appena scaricato da rom manager
ro.ril.enable.a53=1
ro.ril.enable.dtm=1
ro.ril.hsdpa.category=10
ro.ril.hsupa.category=6
ro.ril.def.agps.mode=2
ro.ril.gprsclass=12
ro.ril.disable.fd.plmn.prefix=23402,23410,23411
ro.ril.enable.sdr=1
ro.ril.enable.amr.wideband=1
ro.com.google.clientidbase=android-htc
# begin build properties
# autogenerated by buildinfo.sh
ro.build.id=GRI40
ro.build.display.id=htc_ace-userdebug 2.3.3 GRI40 eng..20110322.232741 test-keys
ro.build.version.incremental=29209
ro.build.version.sdk=10
ro.build.version.codename=REL
ro.build.version.release=2.3.3
ro.build.date=二 3月 22 23:28:16 CST 2011
ro.build.date.utc=1300807696
ro.build.type=userdebug
ro.build.user=root
ro.build.host=AA100
ro.build.tags=test-keys
ro.product.model=Desire HD
ro.product.brand=htc_generic
ro.product.name=htc_ace
ro.product.device=ace
ro.product.board=spade
ro.product.cpu.abi=armeabi-v7a
ro.product.cpu.abi2=armeabi
ro.product.manufacturer=HTC
ro.product.locale.language=hdpi
ro.product.locale.region=
ro.wifi.channels=
ro.board.platform=msm7x30
# ro.build.product is obsolete; use ro.product.device
ro.build.product=ace
# Do not try to parse ro.build.description or .fingerprint
# ro.build.description=2.31.1400.1 CL29209 test-keys
ro.build.description=RCMixHD_5.9.4
ro.build.changelist=29209
ro.product.ua=
ro.build.fingerprint=orange_uk/htc_ace/ace/ace:2.2.1/FRG83D/333804:user/release-keys
ro.build.project=179991
ro.product.version=2.31.1400.1
keyguard.no_require_sim=1
# end build properties
# system.prop for ace
ro.sf.lcd_density=240
debug.fb.rgb565 = 0
rild.libpath=/system/lib/libhtc_ril.so
# RilLibPath for Ganlite by Godel_Chen
rild.libpath.ganlite=/system/lib/librilswitch.so
rilswitch.vendorlibpath=/system/lib/libhtc_ril.so
rilswitch.ganlibpath=/system/lib/libganril.so
# Modify MMS APN retry timer from 5s to 2s.
ro.gsm.2nd_data_retry_config = max_retries=3, 2000, 2000, 2000
# ace RF team request
ro.ril.enable.dtm = 1
ro.ril.hsxpa = 2
# Default network type.
# 0 => WCDMA preferred.
ro.telephony.default_network=0
wifi.interface=eth0
wifi.supplicant_scan_interval=90
# The OpenGL ES API level that is natively supported by this device.
# This is a 16.16 fixed point number
ro.opengles.version = 131072
# This is a high density device with more memory, so larger vm heaps for it.
dalvik.vm.heapsize=32m
# For the default value of agps
ro.ril.def.agps.mode = 2
# For HSDPA low throughput
ro.ril.disable.power.collapse = 1
# For Ace China NEL
ro.ril.update.org.acoustic = 1
# For emmc phone storage
ro.phone_storage = 0
# For ext4 file system
ro.ext4fs = 0
# For FOTA setting (leave empty value to use default)
ro.htc.checkin.url = http://andchin.htc.com/android/checkin
ro.htc.checkin.crashurl = http://andchin.htc.com/android/crash
ro.htc.checkin.url_CN = http://andchin.htccomm.com.cn/android/checkin
ro.htc.checkin.crashurl_CN = http://andchin.htccomm.com.cn/android/crash
ro.htc.checkin.exmsg.url = http://fotamsg.htc.com/android/extra/
ro.htc.checkin.exmsg.url_CN = http://fotamsg.htccomm.com.cn/android/extra/
# Release Bluetooth HW/SW information
ro.bt.chipset = Broadcom BCM4329-B1
ro.bt.version = Bluetooth 2.1 + EDR
ro.bt.stack = Broadcom BTL-A
ro.bt.stack.version = 2.0.50.032
#0x10000010010100100000011 represent bt profile list
ro.bt.profiles = 4270339
# Properties of BTLA stack
service.brcm.bt.activation = 0
service.brcm.bt.srv_active = 0
service.brcm.bt.hcid_active = 0
service.brcm.bt.btld = 0
service.brcm.bt.btld_pid = 0
service.brcm.bt.avrcp_pass_thru = 0
service.brcm.bt.avrcp_toggle = 1
# For quick boot mode
persist.sys.shutdown.mode = hibernate
# Properties of Scalado Denoise param.
postprocess.iso_midband = 400
postprocess.denoise_level = 5
# Following property will be reference by Settings.
ro.product.processor=1GHz
ro.product.ram=768MB
ro.product.display_resolution=4.3 inch WVGA resolution
ro.product.main_camera=8M
ro.product.front_camera=NA
ro.product.bluetooth= 2.1 + EDR
ro.product.wifi = 802.11 b/g/n
# For opensense sdk
ro.htc.common.version = 2.1.0.0
# ADDITIONAL_BUILD_PROPERTIES
ro.url.legal=http://www.google.com/intl/%s/mobile/android/basic/phone-legal.html
ro.url.legal.android_privacy=http://www.google.com/intl/%s/mobile/android/basic/privacy.html
ro.com.google.networklocation=1
ro.setupwizard.mode=DISABLED
ro.config.ringtone=QuietlyBrilliant.mp3
ro.config.notification_sound=Zeta.mp3
ro.config.alarm_alert=NewDay.mp3
ro.config.cal_notification=Epsilon.mp3
ro.config.msg_notification=Gamma.mp3
ro.setupwizard.mode=OPTIONAL
ro.com.google.gmsversion=2.3_r1
wifi.interface=eth0
ro.opengles.version=131072
media.a1026.nsForVoiceRec=0
media.a1026.enableA1026=1
dalvik.vm.lockprof.threshold=500
dalvik.vm.dexopt-flags=m=y
net.bt.name=Android
dalvik.vm.stack-trace-file=/data/anr/traces.txt
ro.rommanager.developerid=capychimp
ro.modversion=RCMixHD_v5.9.5
LinkBack URL
About LinkBacks
Rispondi quotando
