il comando non lo devi dare da fastboot ma dal cell in stand by collegato solo carica e dubug usb attivo.
Nella versione 0.2 il lockscreen si trova in system/app
se non ti funziona QTADB prova ad installare questo,non perche lo devi usare
ma ti dovrebbe sistemare i driver
http://androidcommander.com/?file_id=7
insatalla riavvia e prova ancora con QTADB
facci sapere
Lo proverò, comunque adesso funziona. Il problema era il fatto che pensavo si usasse da fastboot.
Sent from my Desire HD using Tapatalk
In serata ci sara la V03i lavori proseguono
anche mike è entrato nella partita isieme a copy
e ha gia messo a disposizine una patch per la 0.2
con questi aggiornamenti e fix
Updated Superuser to latest 2.3.6.1 with 100% working su binary
Updated Busybox to latest 1.19.0
Updated Gmail to latest 2.3.4.1
HTC IME mod included. Turn it on to have perfectly fit to screen keyboard
Updated Adobe Flash Player to latest 10.2.156.12
Updated Twitter to latest 2.0.1
Updated Market to latest 2.3.6
Updated VoiceSearch to latest 2.1.1
Updated YouTube to latest 2.1.6
Added SD Card Speed Tweak
Added some ROM speed tweaks
Updated Google Maps to latest 5.3.1
Updated Facebook to latest 1.5.2
Added HTC Notes widget
Added ES File Explorer
Removed Plurk and some useless components
Browser fix included
Rosie fix included
PS
ed ecco la 0.3
Multiupload.com - upload your files to multiple file hosting sites!
Ultima modifica di linux33it; 16-04-11 alle 22:46
Edit
Ultima modifica di memnoch; 16-04-11 alle 23:29
Pronta
v0.3[LIST][*]Updated Superuser to latest 2.3.6.1 with 100% working su binary[*]Updated Busybox to latest 1.19.0[*]Updated Gmail to latest 2.3.4.1[*]HTC IME mod included. Turn it on to have perfectly fit to screen keyboard[*]Updated Adobe Flash Player to latest 10.2.156.12[*]Updated Twitter to latest 2.0.1[*]Updated Market to latest 2.3.6[*]Updated VoiceSearch to latest 2.1.1[*]Updated YouTube to latest 2.1.6[*]Added SD Card Speed Tweak[*]Added some ROM speed tweaks[*]Updated Google Maps to latest 5.3.1[*]Updated Facebook to latest 1.5.2[*]Added HTC Notes widget[*]Added ES File Explorer[*]Removed Plurk and some useless components[*]Browser fix included[*]Rosie fix included[*]updated framework dimens values to make text look better
