Ragazzi la rom è stata aggiornata alla versione FINALE per gingerbread e devo dire che è veramente PERFORMANTE ! mai avevo visto una Rom sense 3.0 così fluida e scattante davvero mi ha stupito ! (forse saranno i driver samsung utilizzati da Lee ... non saprei) .
Inoltre nella rom è incluso L'aroma installer ovvero potremmo scegliere quali componenti della rom installare e quali componenti non installare ! (Si consiglia l'installazione della recovery touch per semplificare la scelta dei componenti da installare e quelli da non installare)
CHANGELOG
LeeDrOiD_3D_V5.4 2nd April FINAL GB ROM
Included LeeDrOiD_Shooter Kernel_V5.4 2nd April - FINAL GB KERNEL
Full Kernel change log >>> HERE @GitHub <<<
Added dynamic LED brightness
Unlimited notifacation LED duration
Lowered LED Voltages to save more power
Fixed Camera/screen color inversion issues
Enabled USB OTG support
Rebase - removed fb:display changes (not required)
Updated 2 Phase ondemand from Pyramin 3.0 source
GPU OC code & scaling cleaned up and reworked
Zero memory and more efficiency in mm/percpu.c:cpu_mem_alloc()
fs: lower vfs_cache_pressure 100->25
Updated LagFree Governor
lower instantaneous bandwidth demand to save more battery in MSM/Devices
Tripple buffering in Display and HDMI
More config/code cleanups
JOES RCU Backported from 2.6.38
More Power managment updates
DMA updates via CAF
SMD updates via CAF
Video enc/dec updates via CAF
Numerous sched updates to improve performance
Fixed proximity/light sensor wake identified in previous test kernel
Re enabled MSM idle stats
Enabled large TCP initial buffer
Disabled "No Suspend"
Accelerate last non-dyntick-idle CPU's grace periods
Default MIN CPU Speed dropped to 192Mhz
use the git implementation of SHA-1
Improved boot times
CRC32 updates via CAF
SCM Fixups via CAF
Deep sleep fixed
Compass fixed
------------Rom Changes---------------
Added Aroma installer!! Huge thanks to Amarullz
All items marked with * are optional and selectable on install
*Optional Orange UK Signal boost/WiFi calling selectable in Aroma
*Optional X Loud Audio Engine (thanks to Nutzy & XxXPachaXxX)
*Optional Stock HTC keyboard
*Optional Remove Dancing droid
*Optional stock HTC Camera
*Optional HTC No Beats htc music app
*Optional RTL Language pack
*Optional AGPS fix thanks to crypted
*Optional stock HTC boot animations
*Optional boot sound removal
*Option to remove HTC Locations, Stocks, Flickr & Watch
*Optional HTC Sense removal option
*Optional Samsung EGL Drivers
Removed "Amaze" from the camera, mirror and album name strings
Fixed system tuner init.d settings (System left RW until boot complete)
Removed useless battery calibration script
Fixed Keyboard with arrows size issues
Updated Market to Google Play store
Enabled 20 tabs in browser
Enabled UBS storage (OTG) in settings
Added additional info to "About"
Included spiderman, NFS Shift & Sims 3 stock lib's
Brand new Tweaks UI - Huge thanks to J4n87!!
Reworked ScrollingCache code (100% Disabled)
Several system cleanups & misc tweaks
Default wallpaper corrected
All pre-installed applications updated
System Recompressed & ZipAligned
Improved overall Speed & Stability
Sto provando l'ultima versione...per il momento noto che non mi entra nel men personalizzazione..Dopo averlo premuto torna in home..E' solo un problema mio?
filippo125
No, lo faceva anche a me, ma non mi ha mai soddisfatto questa rom, infatti sono passato subito alla mik...
Guich666
Magari ti fa così xchè devi settare quel tasto dal tweak di leedroid....
Cmq anche io provata una volta e subito tolta x mettere la mik....
Inviato dal mio HTC EVO 3D X515m usando Tapatalk
l'ho usata solo un paio d'ore ma quando mi sono accorto che le foto 3d le fa visualizzare sfuocate (le scatta bene), l'ho tolta subito e rimesso la mik
Ragazzi ho questa rom da quando è uscita ... e vi assicuro che per goderne appieno delle prestazioni dovete scegliere questa configurazione:
Non installare Driver Samsung e non installate Beats Audio ( creano problemi e non incrementato la qualità audio del terminale)
e in piu vi consiglio di piazzare lo stock Kernel !
Io ci faccio quattro ore e mezza di display accesso e 23/24 ore complessive con uso moderato del terminale (qualche chiamata, qualche sms e un po di navigazione internet)
oppure ci faccio 2 ore e mezza di display acceso e circa 13 ore con uso bello intenso !
io mi trovo benissimo con la configurazione che vi ho consigliato ... ottima rom ... davvero ! PS: non vi consiglio di installare il kernel di lee che al contrario è un bidone .
gianluchiello
A me non piace, già quando l'ho installata non mi dava sicurezza, poi ne ho avuto la conferma...
Inoltre abbiamo tutti la possibilità di montare la sense 3.5 che va a meraviglia e quindi ho puntato su quella.
E comunque, se installi l'equalizzatore beats, cioè ti viene l'iconina quando l'attivi, ti migliora notevolmente il suono e potresti apprezzarlo con cuffie buone ;)
Guarda secondo il mio punto di vista, è piu che affidabile come rom ! ormai sono più di 10 giorni che la utilizzo e devo dire che con la configurazione che ti ho detto, sono pienamente soddisfatto !
Anche io penso che la Sense 3.5 a livello di prestazioni si mangi la sense 3.0, ma per mettere su la mik mik ho dovuto rinunciare ad un bel pò di cose ovvero:
Impossibilità di avviare giochi in 3d
Impossibilità di avviare altri giochi non in 3d come Shadowgun o Temple Run
Impossibilità di convertire una foto da 3d a 2d ( mancanza del bottone su in alto presente nella sense 3.0)
Assenza di una PROPRIA radio, e qui a Roma il segnale era parecchio ballerino (mentre con Rom stock e questa il segnale è moolto più stabile)
quindi per questi quattro motivi reputo sia meglio installare una rom 3.0 (che non ha tutte queste mancanze) rispetto ad una 3.5
PS: Per quanto riguarda l'equalizzatore Beats, secondo me l'Srs se lo mangia (ascolto parecchia musica con delle Skullcandy Titan) .
gianluchiello
Ciao, io con la mik riesco tranquillamente a convertire le foto in 2d col bottone modifica (la bacchetta magica) e per quanto riguarda la radio fm a me sembra uguale a quella stock...
Nn mi convince... Si impalla si riavvia consuma troppa batteria, crasha il programmino tweaks, dice che la si è occupata. Meglio la rom stock con root. Decisamente
Inviato dal mio HTC EVO 3D X515m usando Androidiani App
