[ROM] MetroEvo3d
    Baby Droid L'avatar di TEED
    [ROM] MetroEvo3d
    ciao a tutti, mi sono appena iscritto e presentato. ho usato la funzione search ma non ho trovato quello che cercavo e ho deciso di aprire un nuovo thread, se ho scazzato qualcosa chiudete pure. tempo fa avevo letto di una rom su XDA con windows phone per il nostro terminale chiamata MetroEvo3d e mi ero abbastanza interessato, ma visto che era ancora in funzione beta non mi ero arrischiato a provarla. qualcuno l'ha provata?(non ho nemmeno capito se è per moduli CDMA o anche GSM)
    WELCOME TO MetroEvo3D - Brought to you by SOSA Developers
    This is Windows Phone 7 for your Evo 3D! By Supreme OS Android
    Here's the Goods (Taste the simplicity)
    -Based on CyanogenMod 7.4 by KMeyers
    -DigitalHigh's Modified Tiamat Kernel with multitouch support
    -As Bloat-free as I could get it! (Only uses 38 MB app space, leaving you with 1.1 GB of app space)
    -MetroUI (Launcher7)
    -Windows Phone 7 Theme (By JudasLucifer)
    -WP7 Music Player (InstaMusic)
    -WP7 Lockscreen (WP7Lock Lite)
    -Gapps Preinstalled (Removed setupwizard.apk, was causing issues on first boot, just set up your account via the settings menu or opening the market)
    -CyanogenMod Settings still available (will change name to WP7 Settings later)
    -New, simpler, smaller file manager (Fo File Manager)
    -WP7 Mail (WP7 Mail)
    -WP7 Notifications (WP7 Notifications)
    -WP7 Boot animation (by abhi0n0nakul)
    -Custom SOSA Wallpapers APK (Thanks Thoughtlesskyle for teaching me how to do this) all set to 540x960 qHD resolution to fit the phone screen perfectly!
    -->To set wallpaper, at the launcher 7 Homescreen with your tiles, tap the menu button, hit "Launcher7 Settings", then (so the wallpaper shows up, rather than a black or white BG) hit "Background Wallpaper" and choose "System Wallpaper". Then lastly, hit "change wallpaper" and choose the means in which your app that you will get the wallpaper from (check out mine too btw!)
    As you can see, its not super loaded. My goal in this case was to make a Rom that was battery efficient and as small as possible (100+ extra MB in app space is a lot better than most people think). This was just a personal modified Rom for personal use, but I figured what the hell, someone might be looking for this, so here you go , if you use it, GREAT, if you dont, thanks for giving this your time
    Prerequisites:
    -On First boot, DO NOT RUN THE LAUNCHER 7 Setup wizard, press the "back" key on your phone, or press "create tiles" on the app and say yes to skipping, and add the tiles yourself! This is a bug I'll iron out later
    --->If you alread set the tiles and your app force closes, you will have to open the settings and wipe Launcher7's data
    -If the Lock screen force closes, ignore it, I'll iron that out later too
    Plans for second/third release:
    -WP7 Contacts
    -WP7 Phone with Facebook Integration
    -Xbox Live App
    -Minimalistic Gallery (Will probably use Gallery ICS, photo safari force closes when trying to open pictures in from texts/emails)
    -Voice Control App (nice little twist, and a cool feature)
    -Video Player of some sort (Zplayer costs money, so this is sort of a road block to find a wp7 video player, probably gonna have to theme the original one)
    -More Google apps that are similar to WinPho7 experience (Google Drive=Live Skydrive, etc.)
    -Very themed out UI on more personal apps like Instagram, Facebook, Twitter, etc.
    -WP7 style app switcher (BIG PROJECT!! Working on it now, running into systemUI compilation issues)
    -Beats Audio
    -Bravia Engine (if possible)
    IF YOU HAVE ANY REQUESTS, PM ME AND ILL SEE IF I CAN DO IT
    non riesco a mettere il link del download perchè sono un babbo però confido che riusciate a trovarlo fatemi sapere, bye
    Ultima modifica di TEED; 19-06-12 alle 16:53
    DEVICE: HTC EVO 3D rooted s-off
    ROM: King Cobra 3D-ICS v1.0
    KERNEL: 3.0.16 - htc kernel -
    RADIO: 11.73.3504.00U_11.23.3504.09_M2
    RECOVERY: 4ext Recovery touch v1.0.0.4 RC3
    Androidiani Power User L'avatar di iGuich
    Cattolica
    Ringraziato 2,998 volte in 2,007 Posts
    Quote Originariamente inviato da TEED Visualizza il messaggio
    Prerequisites:
    -WP7 Contacts
    -Xbox Live App
    -Beats Audio
    Non puoi metterlo perchè hai pochi messaggi
    Comunque, non penso sia per il gsm dato che non l'ho mai vista, ma puoi benissimo controllare tu su xda leggendo se è sotto gsm development o cdma.
    Detto questo, non saprei, mai vista e sentita, per questo suppongo sia per cdma
    Send with Tapatalk
  4. Il seguente Utente ha ringraziato iGuich per il post:
    TEED (19-06-12)
  5. #3
    che cretino hai ragione c'è scritto cdma development comunque sai niente tu di altre eventuali rom con wp7 per l'evo?
  6. #4
    Cattolica
    Per gsm non ce ne stanno
    Ah, per curiosità, perchè uno smartphone android se poi vuoi wp?
    Send with Tapatalk
  7. #5
    mi piace semplicemente l'interfaccia grafica pulita elegante e minimale, ho provato il launcher che c'è sul market ma mi laggava in una maniera insopportabile quindi volevo provare una rom con wp giusto per curiosità. sia chiaro, non lo preferisco minimamente ad android se non da un punto di vista grafico, tutto qui.
  8. #6
    Cattolica
    Era per curiosità, non per creare casino eh
    Comunque, non ce ne stanno, potresti cercare dei temi ma non penso ci siano
    Send with Tapatalk
