Utente del giorno: kroko con ben 1 Thanks ricevuti nelle ultime 24 ore
Pagina 10 di 59 primaprima ... 8910111220 ... ultimoultimo
Visualizzazione dei risultati da 91 a 100 su 587
[HELP] Thread per aiuti, malfunzionamenti, dubbi per il modding HTC EVO 3D
  1. #91
    D/AudioSystem( 238): AudioSystem::get_audio_flinger() in at 53
    D/AudioSystem( 238): gLock get at 55
    D/AudioSystem( 238): leave AudioSystem::get_audio_flinger() at 81
    D/WifiService( 238): ACTION_SCREEN_ON
    D/ConnectivityService( 238): onUidRulesChanged(uid=10151, uidRules=0)
    D/PhoneStatusBarPolicy( 325): ServiceState ss: 0
    D/PhoneStatusBarPolicy( 325): Network Type: 8
    D/CAT ( 463): CatService: Return current sInstance
    D/SurfaceFlinger( 114): Screen about to return, flinger = 0x142a9b0
    I/SurfaceFlinger( 114): void android::SurfaceFlinger::updateHwcHDMI(bool) en=0
    D/MP-Decision( 691): UP Nw:2.700000 Tw:180 rq:6.700000 seq:199
    D/FlexNetS(15381): CampNetworkInWhiteBlackList had check current PLMN =22288
    D/WifiStateMachine( 238): [DriverStartedState] CMD_START_DRIVER
    D/WifiService( 238): Got ACTION_UPDATE_WIFI_STATE
    D/WifiService( 238): updateWifiState(): disable hotspot
    D/WifiService( 238): updateWifiState(): enable and start wifi
    W/AlarmManager( 238): RemoveAPPAlarmPendingIntent has no PendingIntent operation
    D/SmartSyncDataLinkTurnOffReceiver(15395): DataLink: SMARTSYNC_SERVICE_BROADCAST_SCREEN_ON
    D/HtcLockScreen( 238): HtcLockScreen: onInterceptTouchEvent ACTION_DOWN
    D/HtcLockScreen( 238): HtcLockScreen: onInterceptTouchEvent ACTION_UP
    D/IdleScreen_base( 416): onRingUnlockStart
    D/dalvikvm(15310): GC_CONCURRENT freed 1755K, 53% free 4545K/9507K, paused 2ms+17ms
    D/BatteryService( 238): updateBatteryStats ======================================
    I/BATT_ALG( 129): charging time: 0
    I/BATT_ALG( 129): batt_alg_overtemp_check:temp:278, isOver_temp:0
    I/BATT_ALG( 129): set_battery_voltage_alarm level=36, alarm_config=25, batt_alarm_config=25
    I/BATT_ALG( 129): vol=3787;curr=-361;dis_curr=0;temp=278;id=2;level=36;chg_src=1;ch g_en=1;isOver_temp=0;timer=60;safety_count=0
    D/HtcPowerSaver( 238): Recived battery changed intent.
    D/HtcPowerSaver( 238): Checking...
    I/HtcPowerSaver( 238): >> updateStatus
    I/HtcPowerSaver( 238): currentStatus=8000, currentLevel=36, enableLevel=20, enable=false, popDialog=false, statusChangeTo=-1
    I/HtcPowerSaver( 238): << updateStatus
    D/BatteryService( 238): UEvent updateBatteryStats
    D/PowerManagerService( 238): runHtcPowerSaverCheck ======================================
    D/UsbnetService( 238): BroadcastReceiver::onReceive+
    D/UsbnetService( 238): onReceive BATTERY_CHANGED
    D/UsbnetService( 238): --> pluggedType = 2, mPluggedType = 0, mScreenOff = false
    D/UsbnetService( 238): BroadcastReceiver::onReceive-
    D/PackageManager( 238): Failed to get PackageInfo!, pkg:com.htc.demoflorebooter, flags:1
    D/WifiService( 238): ACTION_BATTERY_CHANGED pluggedType: 2
    D/NotificationService( 238): mIntentReceiver() Intent.ACTION_BATTERY_CHANGED
    D/PowerUI ( 325): closing low battery warning: level=36
    D/PowerUI ( 325): plugged = true, health = 2, mBatteryLevel = 36, mPluggedBatteryLevel = 34, mLowBatteryWarningLevel2 = 25, mshowLowChargingWarning2 = true
    D/KeyguardViewManager( 238): hide()
    D/StatusBarManagerService( 238): disable what =0, token = android.os.Binder@410d7a90, pkg = android, mBar = com.android.internal.statusbar.IStatusBar$Stub$Pro xy@40fdeed0
    D/PhoneStatusBar( 325): disable: < expand icons alerts ticker system_info BACK HOME recent* clock >
    D/SensorManager( 238): [SensorManager] registerListener: delay = 200000
    D/SensorService( 238): enable: get sensor name = MPL accel
    D/Sensors ( 238): handle : 4 en: 1, v09.2-1-Store Calibration, landscape support - Add log for block issue
    D/Sensors ( 238): Andy: MPLSensor::enable: lock1
    D/Sensors ( 238): mEnabled = 0x10
    D/Sensors ( 238): set_power_states++: enabled_sensors: 16 dmp_started: 0
    D/Sensors ( 238): Before if statment: cs:0 rs:1 en_ped:0 da_ped:0 en_g:0 da_g:0
    D/Sensors ( 238): STOP timerirq_1
    D/Sensors ( 238): Starting DMP
    I/ ( 238): mpu3050_resume: Resuming to 0070
    D/Sensors ( 238): Exit: Starting DMP
    D/Sensors ( 238): set_power_states--
    D/Sensors ( 238): Andy: MPLSensor::enable: unlock1
    D/Sensors ( 238): MPLSensor::enable--1
    D/SensorService( 238): SensorDevice::activate--: handle = 0x4, enabled = 0x1
    D/SensorService( 238): pid=238, uid=1000
    D/PhoneStatusBar( 325): disable: < expand icons alerts ticker system_info back* home* recent clock >
    D/FlickrReceiver(15422): onReceive , action=ACTION_USER_PRESENT
    D/Twitter-MessageReceiver(15422): action android.intent.action.USER_PRESENT
    D/FlickrReceiver(15422): Intent.ACTION_USER_PRESENT SyncInterval=3600000,currTime=1357561812255
    D/FlickrReceiver(15422): Intent.ACTION_USER_PRESENT lastStreamSyncTime=1357561812266,lastFriendSyncTim e=1357561812266
    D/memalloc( 416): /dev/pmem: Unmapping buffer base:0x543f9000 size:31313920 offset:29224960
    D/memalloc( 416): /dev/pmem: Unmapping buffer base:0x56ad7000 size:23027712 offset:20938752
    D/memalloc( 416): /dev/pmem: Unmapping buffer base:0x58189000 size:14622720 offset:12533760
    E/ActivityThread(15422): Failed to find provider info for com.htc.settings.accountsync.SYNC
    D/UsbConnectedReceiver(13166): action = android.intent.action.USER_PRESENT
    D/PSCommon(13166): usb_cable_connect = 1
    D/UsbConnectedReceiver(13166): isScreenLockAndStopMountingDisk = false
    E/ActivityThread(15439): Failed to find provider info for com.htc.settings.accountsync.SYNC
    D/MessageService(15422): Intent.ACTION_USER_PRESENT syncInterval=3600000,currTime=1357561812401
    D/MessageService(15422): Intent.ACTION_USER_PRESENT lastStreamSyncTime=1355204300677,lastFriendSyncTim e=1357561812402
    D/dalvikvm( 416): GC_EXPLICIT freed 284K, 53% free 3073K/6499K, paused 2ms+6ms
    D/memalloc( 238): /dev/pmem: Unmapping buffer base:0x5a49b000 size:19058688 offset:17039360
    E/SurfaceTexture( 114): [Keyguard] abandon: SurfaceTexture(0x0x14b22b8) has been abandoned!
    W/InputManagerService( 238): Window already focused, ignoring focus gain of: com.android.internal.view.IInputMethodClient$Stub$ Proxy@4148fe98
    D/dalvikvm( 416): GC_EXPLICIT freed 17K, 53% free 3058K/6499K, paused 10ms+2ms
    I/wpa_supplicant( 316): wpa_driver_wext_combo_scan: Start
    D/MP-Decision( 691): DOWN Ns:2.100000 Ts:270 rq:0.601990 seq:400 (Up time:1801)
    D/PhoneStatusBarPolicy( 325): isCdma():false mSimState=UNKNOWN gprsState=0 mDataState=2 dataActivity=2
    D/PhoneStatusBarPolicy( 325): hasService:true mPhone.htcModemLinkOn:false
    D/dalvikvm(15310): GC_CONCURRENT freed 1412K, 49% free 4921K/9507K, paused 2ms+15ms
    D/memalloc(15310): /dev/pmem: Unmapping buffer base:0x54866000 size:14745600 offset:14622720
    I/wpa_supplicant( 316): wpa_disabled_ssid_list_clear - type=1
    D/Tethering( 238): interfaceStatusChanged wlan0, true
    E/SurfaceTexture( 114): [Toast] abandon: SurfaceTexture(0x0x14b31a0) has been abandoned!
    D/PhoneStatusBarPolicy( 325): isCdma():false mSimState=UNKNOWN gprsState=0 mDataState=2 dataActivity=0
    D/PhoneStatusBarPolicy( 325): isCdma():false mSimState=UNKNOWN gprsState=0 mDataState=2 dataActivity=3
    D/AutoSetting(13166): service - mRequestRunnable: screen on delay 10s, request NLP now
    D/AutoSetting(13166): service - requestNLP() to last request within 2hrs, don't request 1328714
    D/memalloc(15310): /dev/pmem: Unmapping buffer base:0x54866000 size:17465344 offset:17039360
    D/memalloc(15310): /dev/pmem: Unmapping buffer base:0x55931000 size:17891328 offset:17465344
    W/InputManagerService( 238): Window already focused, ignoring focus gain of: com.android.internal.view.IInputMethodClient$Stub$ Proxy@4195bfe8
    D/MP-Decision( 691): UP Nw:2.700000 Tw:180 rq:3.200000 seq:198
    E/SurfaceTexture( 114): [AtchDlg:org.jtb.alogcat/org.jtb.alogcat.LogActivity] abandon: SurfaceTexture(0x0x14b22b8) has been abandoned!
    D/MP-Decision( 691): DOWN Ns:2.100000 Ts:270 rq:1.400000 seq:285 (Up time:285)
    D/memalloc(15310): /dev/pmem: Unmapping buffer base:0x54866000 size:14868480 offset:14622720
    puo bastare?
  4. #93
    Androidiano VIP L'avatar di Snoob
    Torino
    HTC EVO 3D X515m
    Ringraziato 443 volte in 384 Posts
    non potevi allegare un file zip con dentro il log?? :P non riesco a capire cosa succeda, leggo un paio di errori ricorrenti ma non mi sembrano tragici! in questo log che azioni hai fatto??
    Clicca QUI per registrarti a dropbox! Guadagneremo entrambi 500mb di spazio in più
  5. Il seguente Utente ha ringraziato Snoob per il post:
    Sergiomax (08-01-13)
  6. #94
    Scusa ma da perfetto ignorante non riesco ad inserire il file zip..come si fa?
    per il comne ho fatto,ho avviato il programma logcat e ho fatto crascare la home poi ho aspettato un paio di secondi ed ho salvato la schermata del file...
  7. #95
    ho letto da qualche parte che per poter fare il ripristino bisogna rimettere l' s-on che avevo tolto tramite htc dev..
    Qual'è la procedura piu veloce e meno invasiva per tornare all'origine?
    Grazie e scusate la mia ignoranza..
  8. #96
    Nessun aiuto?..
  9. #97
    Torino
    HTC EVO 3D X515m
    ma non ti conviene installare un'altra rom?? o comunque l'originale tramite recovery??
  10. Il seguente Utente ha ringraziato Snoob per il post:
    Sergiomax (11-01-13)
  11. #98
    Quote Originariamente inviato da Snoob Visualizza il messaggio
    Ecco.... o comunque l'originale tramite recovery...ma come si fa?..io sono proprio zero in questo campo...
  12. #99
    Torino
    HTC EVO 3D X515m
    se non hai già installato la recovery segui QUESTA guida, per installare una nuova rom devi entrare in recovery, prima fare wipe data, wipe cache e wipe dalvick (in pratica cancelli i dati personali, e due partizioni di cache), poi fai "install zip from sd" e scegli il file zip della rom in questione se vuoi quella stock ECCOLA
  13. Il seguente Utente ha ringraziato Snoob per il post:
  14. #100
    Ciao Snoob..ho seguito la guida ma al passaggio seleziona recovery...non mi apre nulla..semplicemente si riaccende da capo...dove sbaglio?
