Pagina 28 di 31 primaprima ... 182627282930 ... ultimoultimo
Visualizzazione dei risultati da 271 a 280 su 310
[ROM/KERNEL][SENSE4.1] Snoob and howpathetic present: YAS4 /Yet Another Sense 4.1/
  1. #271
    Androidiano VIP L'avatar di Sduzz
    milano
    htc evo 3d, galaxy s3
    Ringraziato 476 volte in 391 Posts
    Di tutto ho ormai.... Avrò tipo 6 giga di roba fra mod script e altro....
    Androidiano VIP L'avatar di Snoob
    Torino
    HTC EVO 3D X515m
    Ringraziato 443 volte in 384 Posts
    Quote Originariamente inviato da Sduzz Visualizza il messaggio
    magari uppali da qualche parte, tipo mega.co.nz, così sono a tua disposizione quando vuoi senza tenerti spazio
    Clicca QUI per registrarti a dropbox! Guadagneremo entrambi 500mb di spazio in più
  4. #273
    Torino
    HTC EVO 3D X515m
    In arrivo in uno o due giorni
    Version 11:
    <*>Added KitKat BootAnimation</*>
    <*>Added Keep WiFi on during night tweak</*>
    <*>Fixed VoiceSearch</*>
    <*>Added Remove Quick Launch bar from SystemUI tweak</*>
    <*>Optimized PNG/JPG files</*>
    <*>Added some tweaks</*>
    <*>Updated some settings</*>
    <*>Added youtube fix</*>
    <*>Updated V4A</*>
    <*>Repaired tweaks
    <*>Increased sensitivity of touch screen and capatitive buttons</*>
    <*>Updated Zoneinfo</*>
    <*>Modified Framework settings</*>
    <*>Improved sound</*>
    <*>Improved camera</*>
    <*>Improved perfomance</*>
    <*>Improved stability</*>
    <*>FIXED LOWMEM ERRORS</*>
    <*>FIXED MULTITASKING</*>
    <*>FIXED WiFi for CDMA USERS ( NOT YET, BEING PREPARED )</*>
    <*>FIXED OOM ERRORS</*>
    <*>Google Hangouts NOT CRASHING ANYMORE</*>
    <*>Improved Smoothness / speed of the ROM</*>
    <*>Added more Spns and Apns</*>
    <*>Updated MIRAGE, Buttered Toast kernel</*>
    <*>Script for workaround bug in MiRaGe Kernel</*>
    <*>Fixed Camera launching</*>
    <*>Fixed Virgin/CDMA/GSM App incompatible app bug</*>
    <*>Updated all APPS ( NOT YET, I AM LAZY )</*>
    <*>Fixed some Updater script bugs</*>
    <*>Fixed Backlight Button bug</*>
    <*>Reworked DB tweaks</*>
    <*>Repaired cover album download, and playlists</*>
    <*>Fixed Media scan bug</*>
    <*>Added Anryl kernel</*>
    <*>Now profiles do not work in Leedroid tweaks ( Better then FC of SystemUI :P )</*>
  5. #274
    La flasheró subito attendo ansioso
  6. #275
    Torino
    HTC EVO 3D X515m
    Uscita la v11 YAS4 on PutLocker
    tra poco aggiorno il primo post
  7. Il seguente Utente ha ringraziato Snoob per il post:
    rspillo (08-02-14)
  8. #276
    Pavia
    Huaewi Mate 20 Pro
    Con la v11 e kernel Anryl sembrerebbero risolti i problemi di hot reboot, unica cosa, stupida per i +, non riesco a trovare la calcolatrice e la torcia htc, ed inoltre non mi compaiono i dati meteo, mi dice che l'applicazione non è installata, come potrei fare? Grazie, e complimenti per la splendida rom....
  9. #277
    Torino
    HTC EVO 3D X515m
    Quote Originariamente inviato da giangievo Visualizza il messaggio
    devi selezionarli all'installazione la torcia dovrebbe essere flashlight, calcolatrice calculator, e per il meteo installa qualcosa con weather! flasha lo zip, e poi fai add features, così ti aggiunge semplicemente quello che manca (oppure fai un'installazione sporca/dirty installation
    giusto per curiosità, hai fatto un'installazione pulita o hai fatto un'installazione sporca dalla versione precedente?
  10. #278
    Pavia
    Huaewi Mate 20 Pro
    In effetti mi devo essere perso un passaggio nell'installazione, fino alla 10 c'era la possibilità di selezionarla, mi sarà sfuggito.... Circa l'installazione ne ho fatta una pulita, con tutti i format e i wipe, unica cosa che ho lasciato com'era è la sd card..... Appena finisco col lavoro provo ad aggiungere le features, poi relaziono, grazie mille...... In ogni caso confermo che l'accoppiata v11/Anryl funziona davvero bene, fluida e soprattutto, incrociando tutto il possibile, senza reboots.....
  11. #279
    Torino
    HTC EVO 3D X515m
    è possibile che ti abbia preso due tocchi facendoti saltare un passaggio per i reboot non abbiamo la palla di cristallo siccome abbiamo avuto non troppo tempo di provare, ma ci siamo trovati decisamente meglio rispetto alle versioni precedenti
    anzi, scorpion90 ci è rimasto male perchè non riusciva a far riavviare la rom :P
    se riuscite fate caso anche al comportamento della fotocamera! non è ancora perfetta, ma mi sembra che crashi molto meno all'apertura, e sia più veloce nell'aprirsi
  12. #280
    Pavia
    Huaewi Mate 20 Pro
    In effetti devo aver saltato una pagina, problema risolto....... Confermo che la fotocamera è decisamente più veloce all'avvio, e per ora non ha mai crashato, ottimo......
