Pagina 34 di 117 primaprima ... 2432333435364484 ... ultimoultimo
Visualizzazione dei risultati da 331 a 340 su 1163
[ROM] ViperOneM8 5.0.0 | Sense 7
  1. #331
    Androidiano VIP L'avatar di ultimo125
    Brindisi (Prov)
    new "HTC ONE M8"
    Ringraziato 1,479 volte in 1,230 Posts
    Quote Originariamente inviato da dado750 Visualizza il messaggio
    si, solo con il file della viper...
    ho montato esfile explorer e mi vede sia la memoria interna che esterna.....
    allora non saprei ... uso da sempre solo ES File Explorer !!!
    SE TI SONO STATO UTILE PUOI RICAMBIARE CON UN "THANKS"
    Twitter ---- Google+
    Androidiano L'avatar di dado750
    B.go Sabotino (LT)
    Quote Originariamente inviato da ultimo125 Visualizza il messaggio
    ok grazie...
    casomai provo a chiedere su xda.
  4. #333
    Moderatore L'avatar di sirioo
    Naples
    Oneplus 11 16/256
    Ringraziato 1,287 volte in 1,060 Posts
    ViperOneM8 2.5.0 (August maybe today)
    • Updated Verizon carrier files to official 2.21.605.2 base
    • Updated T-mobile carrier files to official 2.22.531.6 base
    • Updated HTC Gallery 8.27.808455
    • Updated Google Play Services 6.1.07
    • Updated HTC Sync Manager 1.8.23.0
    • Updated HTC Scribble (Notes) (Full rom only)
    • Updated TWRP recovery 2.8.0.6 with working UMS and MTP (Full rom only)
    • Fixed build.prop issue for Sprint devices
    • Fixed SystemUI FC when pulling statusbar on immersive mode
    • Fixed broken Android Data Usage
    • Fixed "Always Display Data Icon"
    • Fixed background on contact card when clicking NEQS user card
    • Fixed long press Quiet Hours HEQS icon
    • Fixed screen on time in vertical HTC quick settings
    • Fixed notification count icon
    • Fixed OpenVPN
    • Fixed FlashPlayer - Thanks to mackentosh
    • Fixed revealing venomnavbar not working properly in landscape
    • Fixed HTC Calendar widget not working on 3rd party launchers
    • Fixed FC when entering invalid hexcode in venomtweaks
    • Fixed issue with multiple actionbar buttons when the activity is resumed from recent apps
    • Fixed FC issue when clicking the url icon
    • Fixed Notification widget/Blinkfeed clock not showing custom weather correctly
    • Fixed mixed up Sense animations
    • Fixed UMS(Mass storage) on Sprint
    • Rewrote QuietHours:
      - Muting whatsapp notifications work now(...stupid whats app devs, not following coding guidelines how to play a notification sound)
      - Dim option works properly now, without interfering with charging led
    • Added old venom battery icon back
    • Added option to start EPS when quiethours starts and exiting when quiethours ends
    • Added option to configure apps to show red led color on incoming notifications
    • Added toggle in icon theme view to set background to black, so see "white icon packs"
    • Apps are ordered alphabetically now when customizing icon packs
    • Added toggle to open normal menu when on blinkfeed page
    • Added hiding htc sync icon
    • Enabled call recording
    Device : OP11 Grey - 16/256 | Rom : OOS 14 BA | Audio Mod : Dolby Atmos + ViperFX RE | Kernel: Stock | Recovery : Stock
    NON ACCETTO RICHIESTE DI AIUTO IN PRIVATO
    ****RISPETTA IL REGOLAMENTO DEL FORUM****
  5. I seguenti 3 Utenti hanno ringraziato sirioo per il post:
    iLuke (25-09-14),ultimo125 (25-09-14)
  6. #334
    Scusate la domanda, ma questa rom può essere installata anche con S-on? ho provato ad usare Firewater, ma alla fine compare la scritta "device patched by HTC, you are out of luck"
  7. #335
    Brindisi (Prov)
    new "HTC ONE M8"
    Quote Originariamente inviato da Sal91 Visualizza il messaggio
    certo che puoi anche da S-ON, a patto che tu abbia aggiornato il telefono al nuovo firmware 2.22.xxx.x
  8. Il seguente Utente ha ringraziato ultimo125 per il post:
    Sal91 (25-09-14)
  9. #336
    Ok, Grazie!
  10. #337
    Sep 2014
    Ma questo aggiornamento è per tutti i modelli? Non lo trovo da nessuna parte....come mai?
  11. #338
    Brindisi (Prov)
    new "HTC ONE M8"
    Quote Originariamente inviato da ippoglosso Visualizza il messaggio
    ormai dovresti averlo ricevuto
    quale CID ha il tuo ONE ?
    e
    quale versione firmware ?
  12. #339
    Naples
    Oneplus 11 16/256
    dopo l'aggiornamento alla 2.5.0 + Viperdark 2.5.0 , apk della galleria non si apre...come non fosse più installata ...a voi ?
  13. #340
    Ringraziato 39 volte in 34 Posts
    e quale versione firmware ?
    Salve ragazzi, anche a me non è ancora arrivato, il mio cid è T-MOB101
    Inviato dal mio HTC One_M8 usando Androidiani App
    Ultima modifica di iLuke; 26-09-14 alle 01:24
