Utente della settimana: bluemask con ben 18 Thanks ricevuti negli ultimi sette giorni
Visualizzazione dei risultati da 1 a 10 su 22
[KERNEL] [June 20] [Sense] [GPE] ElementalX
    Androidiano VIP L'avatar di ultimo125
    Brindisi (Prov)
    new "HTC ONE M8"
    Ringraziato 1,479 volte in 1,230 Posts
    Post
    Kernel per HTC One M8 - Sense e Google Play Edition
    (Non per Sprint o Verizon)
    FEATURES
    • Easy installation with Aroma installer
    • overclocking
    • gboost for enhanced gaming performance
    • choose voltage profile in installer
    • full user voltage control
    • underclock CPU or GPU
    • i/o schedulers: FIOPS, SIO, CFQ, NOOP, ROW, deadline
    • optional sweep2sleep
    • optional custom wake gestures (no motion required!)
    • optional pocket detection (with custom wake gestures)
    • option to disable volume button wakes camera (with custom wake gestures)
    • High Definition Audio capability
    • optional USB fastcharge
    • option to reduce vibration strength
    • remove /system write protection
    • NTFS r/w, CIFS, exFAT support
    • option to disable fsync
    • option to disable magnetic cover
    • /dev/frandom support
    • color control
    • DriveDroid support
    • optimized -O3 linaro 4.9.1
    DOWNLOADS
    NOTE: Custom wake gestures are a WIP. If you have problems with the proximity sensor, reinstall with stock gestures option
    Sense (4.4.3 - 2.22 base only):
    ElementalX-m8-1.02-Sense
    Sense (4.4.2):
    ElementalX-m8-0.19-Sense
    GPE (4.4.4)
    ElementalX-m8-1.02-GPE
    GPE (4.4.3)
    ElementalX-m8-1.00-GPE
    GPE (4.4.2):
    ElementalX-m8-0.18-GPE
    Previous Versions:
    INSTALLAZIONE
    1. Installare lo zip da Recovery
    2. Seguire le istruzioni, se non sapete cosa scegliere, lasciate le impostazioni preselezionate
    3. Riavviare
    NB. Se non c'è la connessione wifi dopo l'installazione, provare a reinstallare e pulire cache.
    NOTE
    ElementalX Configuration File
    Your choices in the Aroma installer are used to build a configuration file. The config file is located at /etc/elementalx.conf. You can edit this file to change kernel settings. Whatever is set in this file will take effect when the device is booted (unless other scripts or apps interfere!)
    If settings are not sticking:[*]Make sure you have busybox installed correctly and updated to the latest version[*]Make sure the file permissions for /etc/init.d/99elementalx are set to execute.[*]Check to see if any /etc/init.d scripts or apps (such as Kernel Tuner or TricksterMod) are interfering with your settings.
    ElementalX Log File
    Every boot, a log file is created at /data/local/tmp/elementalx-kernel.log. This file shows the date and time and all settings that have been applied. Use this to verify and troubleshoot configuration options.
    Overclocking
    Overclocking is optional. The installer lets you choose the maximum frequency. Whatever frequencies you chose in the installer will be set at boot for each CPU. Not all devices can handle overclocking. I don't recommend overclocking, this device is fast enough. If you overclock, the CPU frequency will likely be throttled due to heat. I recommend the stock frequencies, as this device is plenty fast.
    CPU voltages
    The installer allows you to choose from several undervolting options: stock, -15mV, -30mV, or -45mV. This only undervolts the lowest frequency, which happens to be the frequency used the most, and this is safer. Be careful, lowering voltages can cause instability.
    gboost
    gboost enhances gaming performance by giving a slight boost to cpu frequencies when the graphics load is high (e.g. while gaming). It should have no effect on battery life during regular usage, so it's safe to leave it enabled all the time.
    fsync
    fsync can be disabled if you're looking for the last ounce of performance. I recommend leaving it enabled as there is a slight risk of data loss if your phone shuts off unexpectedly before filesystems are synced.
    Installing a new ROM
    If you install a new ROM, it will probably replace this with the stock kernel and will definitely overwrite /etc/init.d/99elementalx and /etc/elementalx.conf so you will lose your settings and certain features. So always reinstall the kernel after installing a ROM.
    Sweep2sleep
    Sweep2sleep allows you to put your device to sleep by swiping right to left across the bottom of the screen where the back, home, recent buttons are. I find this useful since the stock motion gestures do not provide a good way to turn off the screen.
    /sys/android_touch/sweep2wake
    0= disabled
    1= sweep2sleep right enabled
    2= sweep2sleep left enabled
    3= sweep2sleep left and right enabled
    USB fastcharge
    USB fastcharge is optional. This will allow you to charge at a faster rate when connected to a USB port. The default limit for USB ports is 500ma, this increases it to 1100ma. Be sure that the computer/laptop/whatever you are plugged into can handle it. Some will automatically cap it at 500ma. Please note that this does not force AC charge mode like previous implementations of force fastcharge. Your battery setting will still say USB mode. You can edit /etc/elementalx.conf to change the setting on boot.
    Wake Gestures
    There are three modes
    • Mode 1: Stock Motion Launch Gestures
      For stock motion launch gestures, /sys/android_touch/wake_gestures, /sys/android_touch/sweep2wake and /sys/android_touch/doubletap2wake must all be set to 0. Enabling any of these overrides the stock gestures. Obviously Motion Launch Gestures must be enabled in the system settings.
    • Mode 2: Remove motion requirement
      For this, you must set /sys/android_touch/wake_gestures to 1 and enable at least one gesture in /sys/android_touch/sweep2wake or /sys/android_touch/doubletap2wakeand Motion Launch Gestures must be enabled in system settings. In this mode, when you sweep or doubletap, the appropriate input events are generated and acted upon the EasyAccessService (i.e., the system app that handles gesture actions).
    • Mode 3: Traditional S2W/DT2W
      In this mode, wake gestures and actions are handled entirely by the kernel. The gestures will turn on the screen and that's it. For this, you must set /sys/android_touch/wake_gestures to 0 and enable at least one gesture in /sys/android_touch/sweep2wake or /sys/android_touch/doubletap2wake. It doesn't matter if Motion Launch Gestures is enabled or disabled in system settings, the gestures don't interact with it in this mode.
    Options
    For modes 2 and 3, there are several options.
    • Sweep2Wake
      Gesture........Value
      Sweep right......1
      Sweep left........2
      Sweep up.........4
      Sweep down....8
      Add up the values for each gesture you want to enable and put the total in /sys/android_touch/sweep2wake. For example, to enable all gestures, the value is 15 (1+2+4+8). To enable sweep right, sweep left and sweep up, the value is 7 (1+2+4)
    • DoubleTap2wake
      Set /sys/android_touch/doubletap2wake to 1 to enable DT2W, and set to 0 to disable it.
    • Pocket Detection
      Set /sys/android_touch/pocket_detect to 1 to enable pocket detection, and set to 0 to disable it. Pocket detection is experimental right now, I'd say it's about 90% functional, but there is an occasional bug where it either doesn't work or works too well.
    • Vibration Strength
      Haptic feedback can be enabled for the wake gestures in /sys/android_touch/vib_strength. This setting takes a number between 0 and 60. Default is 20, which is the same vibration as the stock gestures. Setting this to 0 disables haptic feedback.
    DevDB Information
    ElementalX-m8, a Kernel for the HTC One (M8)
    Contributors
    flar2
    Kernel Special Features:
    Version Information
    [B]Status: Beta[B]
    Current Beta Version: 0.18
    Beta Release Date: 2014-05-27
    Created: 2014-04-04
    Last Updated: 2014-05-27
    Thanks to "flar2"
    fonte
    Ultima modifica di ultimo125; 12-08-14 alle 15:24
    SE TI SONO STATO UTILE PUOI RICAMBIARE CON UN "THANKS"
    Twitter ---- Google+
  2. Il seguente Utente ha ringraziato ultimo125 per il post:
    Brindisi (Prov)
    new "HTC ONE M8"
    CHANGELOG
    Aug 8, 2014: ElementalX-m8-1.02
    -update fauxsound drivers
    Aug 3, 2014: ElementalX-m8-1.01-Sense
    -update installer
    Aug 3, 2014: ElementalX-m8-1.01-GPE
    -update HTC source code for GPE 4.4.4
    -update installer
    -fix touch driver not loading
    Ultima modifica di ultimo125; 12-08-14 alle 15:18
  5. Il seguente Utente ha ringraziato ultimo125 per il post:
  6. #3
    Brindisi (Prov)
    new "HTC ONE M8"
    RISERVATO
  7. #4
    Administrator L'avatar di iLuke
    Jan 2011
    Ringraziato 5,317 volte in 3,365 Posts
    thread e titolo aggiornati all'ultima versione...
    ed elementalx appena installato sul mio M8
    :::::::::::: REGOLAMENTO DEL FORUM | FAQs | TAG BBCode ::::::::::::
  8. I seguenti 2 Utenti hanno ringraziato iLuke per il post:
    ultimo125 (21-06-14)
  9. #5
    alexis77
    ma.......a consumi si notano differenze sostanziali?
  10. #6
    Moderatore L'avatar di sirioo
    Naples
    Oneplus 11 16/256
    Ringraziato 1,287 volte in 1,060 Posts
    Quote Originariamente inviato da kalel77 Visualizza il messaggio
    si...ultimamente dopo vari test con vari kernel mi succedeva una cosa strana applicando i setting da trickster mod , in pratica non teneva i setting delle frequenze o under volt ...Ho risolto installando da fastboot il boot.img compreso nello zip del kernel
    Device : OP11 Grey - 16/256 | Rom : OOS 14 BA | Audio Mod : Dolby Atmos + ViperFX RE | Kernel: Stock | Recovery : Stock
    NON ACCETTO RICHIESTE DI AIUTO IN PRIVATO
    ****RISPETTA IL REGOLAMENTO DEL FORUM****
  11. Il seguente Utente ha ringraziato sirioo per il post:
  12. #7
    Androidiano L'avatar di shot84
    Jan 2010
    Hero - Sensation - One X - M8
    Ringraziato 30 volte in 26 Posts
    Sono usciti diversi aggiornamenti per questo kernel.
    Il più recente è di qualche giorno fa (8 Agosto)
    è basato sull'ultimo firmware 2.22 ed è solo x la sense
    lascio qui il link per il download chiunque fosse interessato
    Device: HTC U11
    Status: S-OFF Temp/S-ON with Cid 034
    Firmware: 2.33.401.19
    Recovery: T.W.R.P 3.2.1-0
    Rom: ViperU 2.3.0 STABLE
    Kernel: Stock
  13. Il seguente Utente ha ringraziato shot84 per il post:
    ultimo125 (11-08-14)
  14. #8
    Brindisi (Prov)
    new "HTC ONE M8"
    Quote Originariamente inviato da shot84 Visualizza il messaggio
    Primo Post Aggiornato !
    Grazie per avermelo ricordato ...
  15. #9
    Oct 2009
    Ragazzi ho appena installato questo kernel ... Ho un pvs=10. .. com'è? Fin quanto posso spingermi con l undervolt?
  16. #10
    Naples
    Oneplus 11 16/256
    Quote Originariamente inviato da trunks986 Visualizza il messaggio
    Prova -50 se tiene bene salì a -60
