Utente del giorno: robnovi con ben 1 Thanks ricevuti nelle ultime 24 ore
Pagina 1 di 8 123 ... ultimoultimo
Visualizzazione dei risultati da 1 a 10 su 79
[ROM] MaximusHD | 10.0.0 | Android 5.0.1 | Sense 6.0 | EYE | OTA | 4.16.401.9
    Androidiano VIP L'avatar di ultimo125
    Brindisi (Prov)
    new "HTC ONE M8"
    Ringraziato 1,479 volte in 1,230 Posts
    Post
    System Information:
    • Based on HTC One (M8) 4.16.401.9
    • Android 5.0.1 (LRX22C)
    • Sense 6.0
    • Amazing battery life
    • Fast and Stable
    • Tweaked for Best Performance
    • OTA Updates
    • APM
    • Auto-Kernel Flash
    • OpenGL ES 3.0
    • Deodexed
    • Zippaligned
    • Rooted
    • Aroma Multi-Language Setup (Supports 26 languages now)
    • Option to remove unneeded apps
    • Option to install additional mods
    • Support of init.d
    • Always newest ROM bases
    • And many more
    • Make sure your device is unlocked or have s-off
    • Download ROM and put it on internal sdcard
    • Put device in bootloader mode (Power + Volume Down)
    • Enter Recovery and do wipe first
    • Find in Recovery "Choose zip from sdcard" choose appropriate zip file
    • Proceed steps that Aroma installer gives
    • Reboot device after finishing installation
    MaximusHD 10.0.0
    Full Wipe OBBLIGATORIO se si proviene da una base KitKat
    TWRP 2.8.4.0 o superiore consigliata per l'installazione!
    Firmware 4.16.401.9 altamente raccomandato (non obbligatorio ma raccomandato)
    • M8_UL
    • M8_UL_CA AT&T
    • M8_UL_CA T-Mobile USA
    • M8_UL_CA Telus
    • M8_UL_CA Roger
    • M8_UHL
    Thanks to LlabTooFeR
    Fonte XDA
    Ultima modifica di iLuke; 18-01-15 alle 20:01
    SE TI SONO STATO UTILE PUOI RICAMBIARE CON UN "THANKS"
    Twitter ---- Google+
  2. Il seguente Utente ha ringraziato ultimo125 per il post:
    iLuke (02-07-14)
    Brindisi (Prov)
    new "HTC ONE M8"
    Q&A
    Q. Can I use this ROM on S-ON devices?
    A. Yes, you can use it, but you might face some issues like long reboot, missing boot animation, higher battery consumption , Wi-Fi issues and etc.
    Q. My Wi-Fi doesn't work
    A. You must update firmware to latest 4.xx.xxx.x
    Q. Will new firmware wipe my device? Should I be S-OFF
    A. It won't wipe your device, but your device must be S-OFF.
    Q. My camera doesn't want to take pictures due to insufficient permissions and I don't see my files, what should I do?
    A. Probably you wiped your internal storage with twrp recovery in the past. Install Terminal Emulator program out of Google play. Execute this command
    codice:
    su
    restorecon -FR /data/media/0
    Thanks buttie for tip[/INDENT]
    [/SIZE][/FONT]
    [/CENTER]
    Ultima modifica di iLuke; 18-01-15 alle 19:06
  5. #3
    Brindisi (Prov)
    new "HTC ONE M8"
    MaximusHD 10.0.0
    --January 17th--
    • Based on 4.16.401.9
    • Android 5.0.1
    • Updated Kernel
    • Updated OEM Apps
    • Material Design
    • Project "Volta"
    • Added New Camera Modes
    • Added Settings Search
    • Recent apps: Multiple Pages Support
    • Overall Performance Improvements
    • Audio improvements
    • Camera improvements
    • Battery improvements
    • Reworked Aroma Scripts
    • Many other changes
    Ultima modifica di iLuke; 18-01-15 alle 19:48
  6. #4
    Administrator L'avatar di iLuke
    Jan 2011
    Ringraziato 5,317 volte in 3,365 Posts
    Se provenite da un'altra Custom rom ( basata su Android 4.4.2 - hboot 3.16) o da quella stock, avete bisogno di aggiornare il firmware del telefono prima di poter installare la rom.
    Se avete già l'ultimo firmware andate direttamente al punto 5.
    1. Scaricate il firmware dai link nella sezione download
    2. installate il firmware con i comandi
      codice:
      fastboot oem rebootRUU
      fastboot flash zip firmware_2.12.401.3.zip
    3. Nel caso in cui il flash del firmware darà esito FAILED (è normale, lo fa quasi sempre) non allarmatevi e non scollegate nulla, rischierete di brickare irrimediabilmente il vostro device, piuttosto rieseguite subito il comando
      codice:
    4. Se non riuscite a flashare il firmware ricevendo un messaggio tipo questo
      codice:
      sending 'zip' (31010 KB)... OKAY
      writing 'zip'... INFOzip header checking...
      INFOzip info parsing...
      INFOchecking model ID...
      INFOchecking custom ID...
      FAILED (remote: 42 custom id check fail)
      significa che il vostro cid non è compatibile, cosa fare?
      1. O Editate il file android-info.txt contenuto nel zip del firmware ed aggiungete il proprio cid
      2. Oppure cambiate il cid al proprio device (come ho fatto io), con il comando
        codice:
        fastboot oem writecid AAA__123
        Ovviamente sostituite AAA e 123 con il cid scelto. Assicuratevi di star digitando un cid lungo complessivamente 8 caratteri.
    5. Una volta aggiornato il firmware potete installare la MaximusHD
      • Scaricate la ROM e copiarla nella Sdcard
      • Riavviare in bootloader mode (Power + Volume Down)
      • Avviare la Recovery ed effettuate un backup della vostra rom corrente per sicurezza
      • Effettuate un full wipe/factory reset
      • Selezionare "Choose zip from sdcard" e selezionare il zip della rom
      • Seguire i passi dell'Aroma installer ed avviare l'installazione
      • Riavviate il cellulare al termine dell'installazione
      • Enjoy MaximusHD
    Ultima modifica di iLuke; 08-07-14 alle 09:27
    :::::::::::: REGOLAMENTO DEL FORUM | FAQs | TAG BBCode ::::::::::::
  7. I seguenti 2 Utenti hanno ringraziato iLuke per il post:
    ultimo125 (04-07-14)
  8. #5
    Apr 2010
    Quote Originariamente inviato da -Luke- Visualizza il messaggio
    Tra le FAQ
    In pratica in S-ON si avvia ma siccome il firmware non è l'ultimo ci potrebbero essere dei problemi...
    ps, io l'ho appena installata
    Per i più inesperti aggiungo queste considerazioni (domani scriverò una mini-guida in questo post)
    • Il firmware va flashato con i comandi
      codice:
    • Nel caso in cui il flash del firmware darà esito FAILED (è normale, lo fa quasi sempre) non allarmatevi e non scollegate nulla, rischierete di brickare irrimediabilmente il vostro device, piuttosto rieseguite subito il comando
      codice:
    • Se non riuscite a flashare il firmware ricevendo un messaggio tipo questo
      codice:
      2. Oppure ambiate il cid al proprio device (come ho fatto io), con il comando
        codice:
    • Flash MaximusHD da recovery
    Poi se torni alle rom con la vecchia base devi rimettere il firmware precedente altrimenti laudio non funziona 😊
  9. #6
    Jan 2011
    Quote Originariamente inviato da anomalos Visualizza il messaggio
    Poi se torni alle rom con la vecchia base devi rimettere il firmware precedente altrimenti laudio non funziona ��
    Si ovvio, bisogna downgradare il firmware, infatti ora ho hboot 3.18 oppure aspettare che aggiornino le altre rom
    Senior Droid L'avatar di kintaxfuera
    Nov 2010
    HTC ONE M8, NEXUS 7 LTE
    Ringraziato 47 volte in 46 Posts
    Tra le FAQ
      codice:
      codice:
      codice:
        codice:
    maaaa questa guida funziona anche con l' s-on??
  11. #8
    Jan 2011
    Quote Originariamente inviato da kintaxfuera Visualizza il messaggio
    Il firmware si può flashare solo in s-off
    Nov 2010
    Tra le FAQ
      codice:
      codice:
      codice:
        codice:
    ok fatto l s off, fatto il flash del firmware, ma ora il telefono si è bloccato sulla scrita htc con la banda verde sotto di fine caricamento.... devo fare qualche reboot??
    fatto grazieeeeeee
    Ultima modifica di kintaxfuera; 04-07-14 alle 15:32
  13. #10
    Apr 2010
    ok fatto l s off, fatto il flash del firmware, ma ora il telefono si è bloccato sulla scrita htc con la banda verde sotto di fine caricamento.... devo fare qualche reboot?? grazie
    Si devi riavviare da adb
