Utente del giorno: hobin con ben 2 Thanks ricevuti nelle ultime 24 ore
Pagina 1 di 15 12311 ... ultimoultimo
Visualizzazione dei risultati da 1 a 10 su 144
[ROM][GPE] SkyDragon Google Play Edition | Android 5.0.1 Lollipop
    Androidiano VIP L'avatar di nightcervant
    HTC ONE
    Ringraziato 638 volte in 485 Posts
    SkyDragon Google Play Edition Version 4.2.1♦
    ♦Best Performance & Battery Life♦
    (Any Bootloader-Unlocked *GSM-ONLY* M8)
    [SIZE=5]♦Android Version: L - 5.0.1♦
    ♦Firmware base: 3.11.1700.2♦
    ♦Rom Version: SD GPE v4.2.1♦
    ♦Built from %100 stock and clean base♦
    ♦Init.d Built-in♦
    ♦Busybox Built-in♦
    ♦Rooted with SuperSU♦
    ♦Zip-aligned on boot♦
    ♦SQLite optimization on boot♦
    ♦Build.prop tweaks♦
    ♦System R/W♦
    ♦Stock Kernel Rooted♦
    ♦Aroma Installer♦
    - Optional GPS Location Selection
    - Optional Apps
    - GAPP Removal
    - Font Selection
    ♦ScreenShots♦
    Philz Recovery 6.25.x is Recommended! Don't use 6.41.x+!
    * Make a nandroid backup
    * Make sure your device is ♦BOOTLOADER UNLOCKED♦ S-On is fine
    * Download ROM and put it on external sdcard
    * Put device in bootloader mode
    - - (Power+Volume Down if device off. If on, Power+Volume Up and soon as screen goes black switch from Volume Up to Volume Down)
    * Enter Recovery and do 'Clean To Install A New Rom'(wipe system/data/cache/dalvik)
    * Find in Recovery "Choose zip from sdcard" choose Rom zip file
    * Proceed steps that Aroma installer gives
    * Reboot device after finishing installation
    * Select "No" to install recovery prompt if given
    * Follow setup wizard and enjoy!
    Downloads in Second post!
    Ultima modifica di nightcervant; 14-12-14 alle 22:07
    HTC ONE
    SkyDragon Version 4.2.1 Full Rom
    Recommend clean flashing this one!
    MD5: 2d34374e6ddfda098f116616fcbc14c5
    AFH Mirror
    SDCard Read/Write flashable fix for 4.2.0
    Lyapota Mod Pack for 4.2.x
    SKYDRAGON KERNEL 3.0.7
    DOWNLOAD
    CHANGELOG:
    * Kernel Built with latest SaberMod 4.9.3 Toolchain
    * Ofast Optimization throughout kernel
    * Universal Kernel for all m8's running GPE 5.0.1
    * Flar2 Wake gestures
    * Kexec Hardboot for Multirom support
    * Graphite Optimization on GPU
    * Added schedulers: BFQ/FIFO/FIOPS(default)/SIO/TRIPNDROID/VR/ZEN
    * Added Governors: DanceDance/Interactive/Wheatley/Adaptive/SmartassV2/Lionheart/Lagfree/IntelliDemand/IntelliActive
    * Arm CPU Topology
    * Linaro enhancements (Power Effecient Workqueue's, flags, etc)
    * Overclocked slimbus for better audio
    * All TCP profiles enabled (Westwood/veno/reno/bic/highspeed/hybla/htcp/vegas/scalable/lp/yeah/illinois)
    * Undervolting capable (Thanks to Flar2)
    * Added 2-way Stereo call recording support
    * Latest Optimized LZ4 Compression/Decompression
    * FastCharge Support
    * LCD KCAL Support
    * Sound Control Support
    * HD Audio enabled
    * Franco's High Performance Sound
    * Battery Life Extender
    * Idle-Stats Reporting (faux clock app)
    * Dev/Frandom
    * Arch Random
    * Tons of background fixes to give better battery and performance
    ♦Other Stuff♦
    See original page on xda
    Ultima modifica di nightcervant; 09-01-15 alle 22:37
    HTC ONE
    Changelog
    V4.2.1
    V4.2.1
    *Updated HTC Gallery to latest - Works!
    *Updated skydragon kernel to 3.0.4
    -- Update High Performance Sound
    *Added Lyapota's Modpack v006 (Thanks @Lyapota!)
    *Fixed SDCard write permission
    *Updated aroma for all the things!
    *Added fixed up Housekeeping script
    *Tweaked 96Tweaks script for screen mirroring
    V4.2.0
    *Rebased to Official Lollipop LRX22C.H5
    *APM courtesy of DigitalHigh
    *Added Sense camera/gallery option in aroma
    *Added SkyDragon Kernel by me(HolyAngel)
    V4.1.3
    *Framework files fixup
    V4.1.2
    *Moved GAPPS back to system partition to fix constant update issue
    *Fixed Init.d
    *Fixed and updated busybox
    *Removed Google Wallet due to FC
    V4.1.1
    *Rebased to LRX22C.H2
    *Added APM courtesy of Lyapota & DigitalHigh
    *Tweaked Ramdisk for better performance
    *Tweaked Init.d Scripts for better performance
    *Updated Aroma
    -- Latest removal
    -- New apps
    -- Updated some of the fonts courtesy of ckpv5
    V4.0.5
    *Rebased to LRX21P Release-keys
    *SELinux set to permissive by default - Finally!
    *Optimized init.d Scripts - Thanks again to PwnCakes193
    *Updated Busybox to 1.23
    *Updated Aroma
    -- Added hacked exchange mail - No pin/pass required
    -- Added Ad-blocking script
    V4.0.5
    *Updated Aroma
    V4.0.4.1
    *Added tweaks from PwnCakes193 and lagfix zip
    *Disabled ZRAM Completely
    *Added stock MMS app option in aroma(Android L Messenger)
    *Fixed IR issue
    *Updated HTC Service Pack
    *Selinux set permissive
    V4.0.3
    *Rebased on Android L 5.0 LRX21M
    *Rooted with SuperSU 2.19
    *Unsecured and rooted stock kernel
    *Added init.d and busybox
    *Tweaked up build.prop for added speed and battery life
    *Remade and Cleaned up Aroma for L
    -- Remade install process
    -- Removed xposed and modules
    -- Removed Themes
    -- Removed a couple apps
    -- Fixed up Gapp removal
    -- Removed kernel selection
    Ultima modifica di nightcervant; 09-01-15 alle 22:38
    Administrator L'avatar di iLuke
    Jan 2011
    Ringraziato 5,317 volte in 3,365 Posts
    Quote Originariamente inviato da nightcervant Visualizza il messaggio
    Aggiornate i link è uscita la versione 4.0.3.1 la sto usando io e mi trovo da Dio. Flashata con twrp 2.8.1.0 e tutto è andato a buon fine. Se avete l'ultimo fw sense non dovete flashare il fw GPE... tra un paio di cicli vi dirò la batteria come va
    Aggiornato.. fammi sapere come va
    Ultima modifica di iLuke; 14-11-14 alle 02:20
    :::::::::::: REGOLAMENTO DEL FORUM | FAQs | TAG BBCode ::::::::::::
    Quindi raga da come ho capito non bisogna convertire il dispositivo in google play edition, ora monto la sense skydragon, basta scaricare la ROM e flasharla direttamente tramite custom recovery giusto ??
    HTC ONE
    Quote Originariamente inviato da Moxy Visualizza il messaggio
    No basta avere il Firmware SENSE 4.4.4 (quello che installi per far funzionare correttamente la ViperOne) e non hai bisogno di conversioni. Aggiungo che io ho installato la ROM via cavo OTG. Per chi avesse problemi con i file nella SD Card ecco la soluzione: [NOV 13] SkyDragon | GPE - Lollipop 5.0.0 | v4.0.3 | 3.09.1700.2 - Post #2283 - XDA Forums
    Nov 2014
    Buonpomeriggio ragazzi, ho un problemone. HTC One M8 è da quasi un ora che è fermo sulla boot animation di android Lollipop con rom skydrow. Ho paura di aver sbagliato qualcosa. E' possibile tornare alla recovery?
  9. #8
    Androidiano L'avatar di eddy75
    Foggia
    Honor view 10 lite
    Quote Originariamente inviato da matteomagrini Visualizza il messaggio
    Prova a tenere premuto volume - e power fino a che non rientra in modalità bootloader
  10. #9
    Nov 2014
    Quote Originariamente inviato da eddy75 Visualizza il messaggio
    devo tenerlo premuto più a lungo rispetto a quando ci entro da spento?
    niente non entra..
  11. #10
    Foggia
    Honor view 10 lite
    niente non entra..
    Prova a tenere premuto per circa un minuto il tasto power on/off
