Pagina 7 di 9 primaprima ... 56789 ultimoultimo
Visualizzazione dei risultati da 61 a 70 su 84
[ROM] LeeDrOiD U - Oreo | Fast | Stable | Sense 9.5 | Shortcutter
  1. #61
    Androidiano L'avatar di Salvio66
    Cento
    Mi11 Lite 5G- HTC U11
    ma...aggiornamenti??? ... già morta questa Rom??
    ci sono alternative valide ???
    Cento
    LeeDrOiD U V3.5.0 - Oreo | January 31st 2019 | Fast | Stable |Shortcutter​
    CARATTERISTICHE
    Current Base: HTC Europe 2.33.401.19
    June 2018 Security Patches
    Android 8.0.0
    HTC Sense 9.5
    Optional Root with the latest SuperSU thanks to @Chainfire - Optional!
    Ability to run un-rooted & retain all customization! - + SafeteyNet Pass!
    Option to Root with Magisk! -+ SafeteyNet Pass! (Android Pay and PoGo can be used)
    International base with Sprint, US Unlocked & DUGL support!
    Massive Locales/Language list
    Optional Encryption!
    Partially De-odexed
    Zip-aligned for improved performance
    Partitions trimmed for improved performance
    init.d & su.d support
    All tamper props reset on boot
    Persistent ADB
    Disable error reporting & hrdump
    Stripped HTC logging & feedback
    BusyBox, SQlite3, Bash & Nano shell
    Package Signature Checking Disabled
    Performance, battery life & memory improvements
    HTC U11+ Smart Display
    100% working SystemUI Tuner!
    Android Logo font pack
    LeeDrOiD wallpapers
    System clean-up's
    Additional HTC Widgets
    HTC Gallery & Photo Editor
    HTC Music
    Custom LeeDrOiD Locales & Language support.
    An awesome community & outstanding user support!
    And so much more!
    All MOD's listed in LeeDrOiD Tweaks are hard coded into the ROM
    Aroma
    · Exchange mail admin hack
    · Customise your Applications & Widgets
    · Default Tweaks toggles
    LeeDrOiD Tweaks
    UI Tweaks
    · Sense Launcher Landscape Support
    · Custom sense home shortcut menu
    · Infinite Apps in Folders
    · Allow All Rotations
    · China Sense Recent App Style (Includes a RAM usage monitor & kill-all button)
    · Advanced power menu - powered by Shortcutter!
    StatusBar
    · Right Corner Quick - Quick settings pull down
    · Traffic Indicator (Up-stream & down-stream data speed)
    · Traffic Indicator Colour
    · MIUI Battery MOD
    · Disable NFC Notification
    · Disable USB Debugging Notification
    · Disable Power Saving Notification
    · Disable Android Sync Notification
    · Disable MTP Notification
    · Disable Heads Up Notification
    · Hide Night Mode Notification
    · QS Brightness slider toggle
    · Custom QS Rows & Columns
    · Signal strength in QS pull-down
    · force Expand Notifications
    · Pull down user switcher
    · Hide StatusBar Clock
    Buttons
    · Enable Navigation Bar & Disable capacitive keys
    · Navigation Bar Size
    · Disable button lights
    · Re-map recent apps key
    · Re-map long press recent apps
    · Re-map long press home.
    · re-map long press back
    · Long press volume media controls / flashlight
    · Remap short & long press recents - recents/menu/split screen
    · Double Tap Status Bar to put the device into sleep
    · Double tap power for Camera
    Power
    · Smoother Auto Brightness
    · Haptic feedback duration
    · Haptic feedback 2 duration
    Networks
    · Hide Photo Mask for low-res pictures
    · Show hide VOLTE Icon
    · 4G / LTE Notification Switch
    · Toggle Fast Dormancy
    Misc
    · Security Tweaks
    · Lock long press power when device locked
    · Always allow fingerprint unlocking - Allows bypass of pin, pattern & pass after reboot or timeout
    · Camera Mods
    · Force 100% Jpeg quality in Camera
    · Toggle Boot Audio
    · Toggle HTC/AOSP LockScreen
    · Default USB Mode (ADB/ADB MTP)
    · Default app install location
    Kernel
    · Double Tap FP To Sleep
    · Double Tap Latency
    · FP Vibration Strength
    · Button Lights Notifications
    · BLN When Charging
    · Gradient LED Charging
    · LED Pulse
    Advanced
    · Fix Permissions
    · ZipAlign apks
    · Mount System RW / RO
    · Trim Partitions
    · Wipe Cache
    · Wipe Dalvik-cache
    R2 LeeDrOiD U V3.5.0 - January 31st 2019
    Update Magisk V18.0
    LeeDrOiD Tweaks V10.2.13
    - Update Build tools & libraries
    - Add fix for Dual SIM & Google SMS
    Shortcutter V6.6.8
    - See app changelog
    App updates
    Busybox updated
    Update HTC Mail & Exchange Hack - Thanks @electronic Punk
    Update Cleanslate Kernel V3.7.18 - Thanks @TBAlden
    Remove SuperSU Root Option
    da fonte XDA​
  4. #63
    Moderatore L'avatar di sirioo
    Naples
    Oneplus 11 16/256
    Ringraziato 1,287 volte in 1,060 Posts
    questo fine settimana ci dovrebbe essere un altro update per quanto riguarda l'aggiornamento busybox per la compatibilità della nuova TWRP
    Device : OP11 Grey - 16/256 | Rom : OOS 14 BA | Audio Mod : Dolby Atmos + ViperFX RE | Kernel: Stock | Recovery : Stock
    NON ACCETTO RICHIESTE DI AIUTO IN PRIVATO
    ****RISPETTA IL REGOLAMENTO DEL FORUM****
  5. Il seguente Utente ha ringraziato sirioo per il post:
    Pasqui1978 (16-02-19)
  6. #64
    Cento
    Quote Originariamente inviato da sirioo Visualizza il messaggio
    attendo con ansia Pie....
  7. #65
    Naples
    Oneplus 11 16/256
    Quote Originariamente inviato da Salvio66 Visualizza il messaggio
    Non sei l'unico.
  8. #66
    Cento
    Non sei l'unico.
    mi sa che ci prendono per stanchezza....finché non perdo la pazienza e cambio device...
  9. #67
    Naples
    Oneplus 11 16/256
    Dall'ultimo Twitter hanno scritto ad aprile. Per mia scelta attendo dopo l'estate l'uscita del pixel 4 e poi decido per ora nessun device mi attira.
  10. #68
    Cento
    penso che al prox giro mi orienterò su Pocophone o Xiaomi...vediamo...
  11. #69
    Naples
    Oneplus 11 16/256
    Nemmeno a gratis avrei il coraggio di usarli...ma ripeto è una scelta mia personale..
    Ultima modifica di sirioo; 27-03-19 alle 15:57
  12. #70
    Cento
    why ??.. non sono abbastanza affidabili ??
