Pagina 13 di 16 primaprima ... 31112131415 ... ultimoultimo
Visualizzazione dei risultati da 121 a 130 su 151
[ROM]CyanogenMod 9 test.
  1. #121
    Jan 2011
    Brindisi
    HTC Wildfire
    Nuova versione uscita oggi: update-cm-9.0.0-RC0-buzz-KANG-signed.zip
    questi i cambiamenti:
    ew update, check out the OP!
    Updates worth mentioning regarding the Wildfire
    General updates
    Adjustment of the large notification icon size in the expanded status bar (such as the contact avatar when you get an sms)
    Adjustment of the size of "recent apps"
    Please note that both size adjustments still need some finetuning, but I'm having some problems with building so it can take a while. In the mean time, I didn't want to withold this update from you all ;-)
    The only thing I fear, regarding this recent app view, is if I make the width full screen (now the thumbnail stops as +/- 75% of the screen) that you won't be able to see anything because of the low resolution of our screen. Let me know your thoughts!
    Things on my to-do list:
    Finetuning of the large icon size and the recent apps list
    See how performance goes when applying this patch, perhaps in combination with this one. Recently heared from Arco that the "side effects" are only minor.
    Found some threads regarding the camera. I will look in to it, but I'm not hopefull.
    Look in to the gallery issue
    Best regards,
    Erwin
    Orvieto (TR)
    Motorola Motosmart
    a me da installation aborted... ho provato a fare tutti i wipe ma nessun risultato, qualcuno può aiutarmi?
    Il mio HTC Wildfire:
    Versione Kernel 2.6.35.14-nFinity arco@tuxbox #1
    Overclock Max. 710.4 MHz Min. 352 MHz
  4. #123
    Orvieto (TR)
    Motorola Motosmart
    Ho provato a riscaricare il file e adesso funziona pero non riesco a vedere i video di YouTube
    Inviato dal mio Wildfire usando Androidiani App
  5. #124
    HTC One S, HTC Wildfire
    Ringraziato 19 volte in 19 Posts
    Quote Originariamente inviato da TheProspi Visualizza il messaggio
    Nelle funzioni c'è qualcosa che non funziona oltre a quello? Rispetto a prima cosè cambiato? E' più fluida? Funzionano le app non di sistema?
    HTC Wildfire, what else...
  6. #125
    Orvieto (TR)
    Motorola Motosmart
    Quote Originariamente inviato da Inesistente Visualizza il messaggio
    ma guarda per quel poco che ho potuto usarla, ho notato che la velocità complessiva è abbastanza migliorata, delle varie applicazioni che ho scaricato l' unica che ogni tanto si chiude è l' applicazione "IlMeteo", il browser di default anche se migliorato rimane un pò lento quindi utilizzo opera mini, il lettore musicale una volta attivato rallenta moltissimo il sistema, quindi bisogna decidere se ascoltare la musica ho utilizzare il telefono. Come applicazione per la galleria uso quickpic scaricabile dal market. Ah queste considerazioni le ho fatte con un settaggio del processore di 710mhz di massima e 264mhz di minima e l' ho impostato su performance e dall' indicatore della frequenza attuale leggo quasi sempre 710 mhz... tutto sommato rimane utilizzabile come rom di tutti i giorni a proposito qualcuno sa come far funzionare la fotocamera??
  7. #126
    ragazzi non vorrei allarmarvi ma e uscita la prima alpha della rom miui con android 4.0.3 per il nostro Wildfire io la sto scaricando e provando sperando non sia un fake
    Ultima modifica di Djmark; 26-02-12 alle 15:41 - Motivo: Word's
  8. #127
    Quote Originariamente inviato da Djmark Visualizza il messaggio
    Vedi che in realtà è ms-dos per wildfire
    Metti il link di XDA o di dove l'hai trovato pleaseee
  9. #128
    ecco qua
    cmq a me funziona !!!
    e in inglese però
    [ROM] MIUI v4 for Wildfire | 26/02/12 | Released! - xda-developers
  10. #129
    ecco qua
    e in inglese però
    E funziona bene? È fluida? Le app del market funzionano? Particolari rallentamenti?
    Inviato dal mio HTC Wildfire
  11. #130
    Senior Droid L'avatar di JakoWildfire
    Lecce
    SGS2, HTC Wildfire, Folio 100
    Ringraziato 79 volte in 43 Posts
    OMG!!! Miui per Wildfire?! xD
    • Samsung Galaxy S2 (i9100) • HTC WildFire S-Off Roted •
    Rooted con : Alpharev X S-Off
    Versione Android: 2.3.7
    Versione Kernel: 2.6.35.13-nFinity arco@tubox #1
    Overclock cpu: MIN: 245 MAX: 729
    Versione MOD: CyanoGenMod 7.1 NIGHTLY buzz
    Versione browser: Webkit 3.1
    Se ti sono stato utile, clicca THANKS qui sotto
