Utente della settimana: 9mm con ben 4 Thanks ricevuti negli ultimi sette giorni
Visualizzazione dei risultati da 1 a 10 su 43
[Huawei Ascend G330]Come compilare il kernel Huawei v3.0.21
    Senior Droid L'avatar di Ikon
    Dublino
    Moto G 2ng Gen 5" Dual SIM
    Ringraziato 61 volte in 45 Posts
    PROCEDURA:
    - Installate Linux (e.g. Ubuntu, Linux Mint)
    - Installare Android SDK
    - Installare la toolchain:
    sudo apt-get install gcc-arm-linux-gnueabi
    - Scaricate e decomprimete il kernel da QUI supponiamo in ~/android/u8825-1_3.0.21_kernel
    - Collegate il device alla USB e assicuratevi che sia connesso:
    adb devices
    - Scaricate la configurazione con i comandi:
    cd ~/android
    adb pull /proc/config.gz
    gunzip config.gz
    mv config ./u8825-1_3.0.21_kernel/.config
    - Salvate questa patch nel file ~/android/gcc-4.7-arm-linux-gnueabi.patch:
    codice:
    diff -uNr kernel.huawei/arch/arm/include/asm/swab.h kernel.patched/arch/arm/include/asm/swab.h
    --- kernel.huawei/arch/arm/include/asm/swab.h    2013-02-16 02:28:59.000000000 +0000
    +++ kernel.patched/arch/arm/include/asm/swab.h    2013-06-30 16:17:50.454997000 +0100
    @@ -15,6 +15,8 @@
     #ifndef __ASM_ARM_SWAB_H
     #define __ASM_ARM_SWAB_H
    +#pragma GCC diagnostic ignored "-Wmaybe-uninitialized"
     #include <linux/compiler.h>
     #include <linux/types.h>
    diff -uNr kernel.huawei/arch/arm/mach-msm/board-msm7627a-io.c kernel.patched/arch/arm/mach-msm/board-msm7627a-io.c
    --- kernel.huawei/arch/arm/mach-msm/board-msm7627a-io.c    2013-02-16 02:28:34.000000000 +0000
    +++ kernel.patched/arch/arm/mach-msm/board-msm7627a-io.c    2013-06-30 16:18:00.319927000 +0100
    @@ -11,6 +11,8 @@
     #include <linux/platform_device.h>
     #include <linux/regulator/consumer.h>
     #include <linux/gpio_event.h>
    diff -uNr kernel.huawei/arch/arm/mach-msm/board-msm7x27a.c kernel.patched/arch/arm/mach-msm/board-msm7x27a.c
    --- kernel.huawei/arch/arm/mach-msm/board-msm7x27a.c    2013-02-16 02:28:33.000000000 +0000
    +++ kernel.patched/arch/arm/mach-msm/board-msm7x27a.c    2013-06-30 16:18:14.202866000 +0100
    @@ -9,6 +9,9 @@
      * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
      * GNU General Public License for more details.
     #include <linux/kernel.h>
     #include <linux/init.h>
    @@ -1489,7 +1492,9 @@
         msm7x2x_init_host();
         msm7x27a_pm_init();
         register_i2c_devices();
    +#if (defined(HUAWEI_BT_BLUEZ_VER30) || defined(HUAWEI_BT_BTLA_VER30) || (!defined(CONFIG_HUAWEI_KERNEL)))
         msm7627a_bt_power_init();
    +#endif
         msm7627a_camera_init();
         msm7627a_add_io_devices();
         /*7x25a kgsl initializations*/
    diff -uNr kernel.huawei/arch/arm/mm/dma-mapping.c kernel.patched/arch/arm/mm/dma-mapping.c
    --- kernel.huawei/arch/arm/mm/dma-mapping.c    2013-02-16 02:28:24.000000000 +0000
    +++ kernel.patched/arch/arm/mm/dma-mapping.c    2013-06-30 16:18:21.698612000 +0100
    @@ -9,6 +9,9 @@
      *  DMA uncached mapping support.
    +#pragma GCC diagnostic ignored "-Warray-bounds"
     #include <linux/module.h>
     #include <linux/mm.h>
     #include <linux/gfp.h>
    diff -uNr kernel.huawei/drivers/md/dm.c kernel.patched/drivers/md/dm.c
    --- kernel.huawei/drivers/md/dm.c    2013-02-16 02:32:05.000000000 +0000
    +++ kernel.patched/drivers/md/dm.c    2013-06-30 16:18:36.946233000 +0100
    @@ -5,6 +5,8 @@
      * This file is released under the GPL.
    +#pragma GCC diagnostic ignored "-Wunused-value"
     #include "dm.h"
     #include "dm-uevent.h"
    diff -uNr kernel.huawei/drivers/md/dm-table.c kernel.patched/drivers/md/dm-table.c
    --- kernel.huawei/drivers/md/dm-table.c    2013-02-16 02:32:05.000000000 +0000
    +++ kernel.patched/drivers/md/dm-table.c    2013-06-30 16:18:30.895208000 +0100
    @@ -5,6 +5,8 @@
     #include "dm.h"
    diff -uNr kernel.huawei/drivers/media/radio/radio-tavarua.c kernel.patched/drivers/media/radio/radio-tavarua.c
    --- kernel.huawei/drivers/media/radio/radio-tavarua.c    2013-02-16 02:34:12.000000000 +0000
    +++ kernel.patched/drivers/media/radio/radio-tavarua.c    2013-06-30 16:18:42.589053000 +0100
    @@ -10,6 +10,9 @@
      * Qualcomm Tavarua FM core driver
    diff -uNr kernel.huawei/drivers/video/msm/mdp.c kernel.patched/drivers/video/msm/mdp.c
    --- kernel.huawei/drivers/video/msm/mdp.c    2013-02-16 02:33:33.000000000 +0000
    +++ kernel.patched/drivers/video/msm/mdp.c    2013-06-30 16:18:52.850181000 +0100
    @@ -15,6 +15,8 @@
    +#pragma GCC diagnostic ignored "-Wsequence-point"
     #include <linux/sched.h>
    diff -uNr kernel.huawei/net/ipv4/netfilter/nf_nat_amanda.c kernel.patched/net/ipv4/netfilter/nf_nat_amanda.c
    --- kernel.huawei/net/ipv4/netfilter/nf_nat_amanda.c    2013-02-16 02:34:49.000000000 +0000
    +++ kernel.patched/net/ipv4/netfilter/nf_nat_amanda.c    2013-06-30 16:18:58.813161000 +0100
    @@ -8,6 +8,8 @@
      * 2 of the License, or (at your option) any later version.
    +#pragma GCC diagnostic ignored "-Waddress"
     #include <linux/skbuff.h>
    diff -uNr kernel.huawei/net/ipv4/netfilter/nf_nat_h323.c kernel.patched/net/ipv4/netfilter/nf_nat_h323.c
    --- kernel.huawei/net/ipv4/netfilter/nf_nat_h323.c    2013-02-16 02:34:49.000000000 +0000
    +++ kernel.patched/net/ipv4/netfilter/nf_nat_h323.c    2013-06-30 16:19:02.683096000 +0100
    @@ -9,6 +9,8 @@
      * Jozsef Kadlecsik <kadlec@blackhole.kfki.hu>
     #include <linux/tcp.h>
     #include <net/tcp.h>
    diff -uNr kernel.huawei/net/ipv4/netfilter/nf_nat_irc.c kernel.patched/net/ipv4/netfilter/nf_nat_irc.c
    --- kernel.huawei/net/ipv4/netfilter/nf_nat_irc.c    2013-02-16 02:34:49.000000000 +0000
    +++ kernel.patched/net/ipv4/netfilter/nf_nat_irc.c    2013-06-30 16:19:07.529518000 +0100
    @@ -10,6 +10,8 @@
     #include <linux/moduleparam.h>
    diff -uNr kernel.huawei/net/ipv4/netfilter/nf_nat_standalone.c kernel.patched/net/ipv4/netfilter/nf_nat_standalone.c
    --- kernel.huawei/net/ipv4/netfilter/nf_nat_standalone.c    2013-02-16 02:34:49.000000000 +0000
    +++ kernel.patched/net/ipv4/netfilter/nf_nat_standalone.c    2013-06-30 16:19:14.541022000 +0100
    @@ -5,6 +5,9 @@
      * it under the terms of the GNU General Public License version 2 as
      * published by the Free Software Foundation.
     #include <linux/icmp.h>
    diff -uNr kernel.huawei/net/netfilter/xt_qtaguid.c kernel.patched/net/netfilter/xt_qtaguid.c
    --- kernel.huawei/net/netfilter/xt_qtaguid.c    2013-02-16 02:34:37.000000000 +0000
    +++ kernel.patched/net/netfilter/xt_qtaguid.c    2013-06-30 16:19:27.875687000 +0100
    @@ -8,6 +8,8 @@
      * There are run-time debug flags enabled via the debug_mask module param, or
      * via the DEFAULT_DEBUG_MASK. See xt_qtaguid_internal.h.
    - Applicate la patch con il comando:
    cd ~/android/u8825-1_3.0.21_kernel
    patch -p1 < ../gcc-4.7-arm-linux-gnueabi.patch
    - Compilate il kernel con il comando:
    export ARCH=arm
    export SUBARCH=arm
    export CROSS_COMPILE=arm-linux-gnueabi-
    make
    - Al termine della compilazione, l'output mostrerà (non necessariamente nella parte finale):
    Kernel: arch/arm/boot/Image is ready
    Kernel: arch/arm/boot/zImage is ready
    ATTENZIONE! L'autore del topic non si assume nessuna responsabilità dei danni o problemi che potrete riscontrare seguendo la procedura descritta.
    Ultima modifica di Ikon; 06-07-13 alle 16:54
    Dublino
    Come testare il boot del kernel compilato [FUNZIONANTE]
    - Installare abootimg:
    sudo apt-get install abootimg
    - Recuperare il boot.img (TODO: Descrivere come. So la procedura, ma per ora l'ho preso da ROM tarattata)
    - Riscrivere il boot.img:
    abootimg -u boot.img -k zImage
    - Tentare il boot:
    fastboot boot boot.img
    - Il cellulare dovrebbe riavviarsi
    Come compilare CM10.1 per G510 (kernel 3.4) [WORK IN PROGRESS]
    - Scaricare il kernel da >> QUI << e decomprimerlo supponiamo in ~/kernel
    - Correggere il file arch/arm/configs/cm_msm8x25_defconfig sostituendo la riga 213:
    codice:
    CONFIG_IOSCHED_VR= y
    con:
    codice:
    CONFIG_IOSCHED_VR=y
    - Eseguire
    codice:
    cd ~/kernel
    export ARCH=arm
    export SUBARCH=arm
    make cm_msm8x25_defconfig
    make
    - Attualmente riscontro l'errore:
    codice:
      CC      block/vr-iosched.o
    block/vr-iosched.c: In function ‘vr_add_rq_rb’:
    block/vr-iosched.c:75:25: error: void value not ignored as it ought to be
    block/vr-iosched.c:79:7: error: void value not ignored as it ought to be
    block/vr-iosched.c: At top level:
    block/vr-iosched.c:417:1: error: unknown field ‘elevator_queue_empty_fn’ specified in initializer
    block/vr-iosched.c:417:1: warning: initialization from incompatible pointer type [enabled by default]
    error, forbidden warning: vr-iosched.c:417
    make[1]: *** [block/vr-iosched.o] Errore 1
    make: *** [block] Errore 2
    - Non posso continuare ora che devo uscire... continuo quando torno. Se potete datemi qualche indicazione.
    Ultima modifica di Ikon; 14-07-13 alle 17:27
    Dublino
    Riservato per usi futuri
    Ultima modifica di Ikon; 30-06-13 alle 18:53
    Senior Droid L'avatar di dark706i
    Ringraziato 114 volte in 105 Posts
    Non cambia molto se devo portare il 3.0.31?
    Dublino
    Quote Originariamente inviato da dark706i Visualizza il messaggio
    Penso che tu debba provare a compilare questo. Se compila, allora ti procuri le patch da 3.0.21 a 3.0.31 e provi ad applicarle. Se applicano provi a ricompilare... se va probabilmente funziona, ma bisogna sempre verificare.
    Androidiano VIP L'avatar di PrinceEndymion88
    Palermo
    Huawei Ascend G7 / Tab 2
    Ringraziato 272 volte in 178 Posts
    Io sono sotto esami all'università quindi sono in pausa da modding... finito riprovo! Grazie delle dritte ma quindi patchando il kernel dalla 3.0.21 alla 3.0.31 potremmo avere compatibilità anche con le rom jb? Ma poi mi chiedo, le 4.1.1 necessitano di un kernel 3.0.31 o superiore oppure va comunque bene il 3.0.21?
    Huawei Ascend G7
    {ROM} Emui 3.1 B331
    {Recovery} TWRP
    {Kernel} Stock 3.10.49
    {Root} Si
    Samsung Galaxy Tab2 7.0
    {ROM} Stock 4.1.2
    {Recovery}Stock
    {Kernel} Stock
    {Root} No
    agd
    agd non è in linea
    N/A
    nexus 5
    Ringraziato 52 volte in 51 Posts
    ciao, penso che il kernel 3.0.21 vada bene per jb perchè se vai su youtube e metti xperia u cm10, quando nei video vanno nelle impostazioni il kernel è il 3.0.8 quindi iil nostro dovrebbe funzionare, poi più in la c'è anche il 3.4 del g510 quindi le cose si potrebbero fare, io sto provando a compilare il kernel con la patch creata da ikon, purtroppo di più non posso fare perchè non conosco linguaggi di programmazione, quello che posso fare è provare a compilare il kernel, aggiungere overclock se riesco, volevo provare a compilare android o la cm10, ma il pc non ce la farebbe quindi per ora provo il kernel
    Quote Originariamente inviato da PrinceEndymion88 Visualizza il messaggio
  9. #8
    Palermo
    Ma compilando questo kernel, così com'è, abbiamo solamente una copia di quello che è il kernel già presente nelle rom stock! Al massimo può essere utile come base per un eventuale overclock..
    Huawei Ascend G7
    {ROM} Emui 3.1 B331
    {Recovery} TWRP
    {Root} Si
    {ROM} Stock 4.1.2
    {Recovery}Stock
    {Kernel} Stock
    {Root} No
  10. #9
    agd
    agd non è in linea
    N/A
    nexus 5
    Infatti e poi magari anche cambiare governor che di default è impostato su performance, a proposito qualcuno puó installare nofrills cpu e vedere se gli altri governor si possono cambiare? Che mi pare siano già inseriti
    Inviato dal mio HUAWEI U8825-1 usando Androidiani App
  11. #10
    Palermo
    si a vari governor tra cui ondemand, conservative, performance e altri
    Huawei Ascend G7
    {ROM} Emui 3.1 B331
    {Recovery} TWRP
    {Root} Si
    {ROM} Stock 4.1.2
    {Recovery}Stock
    {Kernel} Stock
    {Root} No
