Pagina 5 di 9 primaprima ... 34567 ... ultimoultimo
Visualizzazione dei risultati da 41 a 50 su 85
[Supporto Modding] Thread di Supporto alle Operazioni di Modding (Mate 8)
  1. #41
    Huawei Mate 8,Letv 1
    prova allora "fastboot oem get-bootinfo". Purtroppo ho il telefono in assistenza e non posso provare
    Ultima modifica di gafran; 17-06-16 alle 20:08
    Senior Droid L'avatar di giorgio704
    Nov 2009
    Afghanistan
    padfone2
    Ringraziato 120 volte in 74 Posts
    Quote Originariamente inviato da gafran Visualizza il messaggio
    C:\adb>fastboot "oem get-bootinfo"
    usage: fastboot [ <option> ] <command>
    commands:
    update <filename> reflash device from update.zip
    flashall flash boot, system, vendor and if found,
    recovery
    flash <partition> [ <filename> ] write a file to a flash partition
    erase <partition> erase a flash partition
    format[:[<fs type>][:[<size>]] <partition> format a flash partition.
    Can override the fs type and/or
    size the bootloader reports.
    getvar <variable> display a bootloader variable
    boot <kernel> [ <ramdisk> [ <second> ] ] download and boot kernel
    flash:raw boot <kernel> [ <ramdisk> [ <second> ] ] create bootimage and
    flash it
    devices list all connected devices
    continue continue with autoboot
    reboot reboot device normally
    reboot-bootloader reboot device into bootloader
    help show this help message
    options:
    -w erase userdata and cache (and format
    if supported by partition type)
    -u do not first erase partition before
    formatting
    -s <specific device> specify device serial number
    or path to device port
    -l with "devices", lists device paths
    -p <product> specify product name
    -c <cmdline> override kernel commandline
    -i <vendor id> specify a custom USB vendor id
    -b <base_addr> specify a custom kernel base address.
    default: 0x10000000
    -n <page size> specify the nand page size.
    default: 2048
    -S <size>[K|M|G] automatically sparse files greater
    than size. 0 to disable
    C:\adb>"fastboot oem get-bootinfo"
  4. #43
    Ti mando in privato il link della guida che ho seguito
  5. #44
    Nov 2009
    Afghanistan
    padfone2
    ho dovuto sbloccare il mate 8, era bloccato ma strano che c'erano quelle icone. ma adesso quando flasho con fastboot la recovery, sembra che va tutto bene, invece quando tento di andare in recovery mi porta ad una schermata huawei recovery mi devo collegare tramite wifi,che e configurata sembra si collega invece mi da errore "getting package info failed"
  6. #45
    Apr 2014
    Ciao a tutti ho bisogno di alcuni chiarimenti: Ho scaricato i file necessari per fare il root al mate 8 Mi trovo questi file BETA-SuperSU-v2.65-TWRP-3.0.2-BLACK-BLUE e minimal_adb_fastboot_v1.3.1_setup .Prima domanda: ADB e' compreso nel setap fastboot quindi in un unico setap? Seconda domanda: Quali drive devo installare? Bastano quelli del programma SUITE Huawei? Terza domanda: Una volta fatto il root eventualmente volessi tornare indietro per esempio dalla b180 alla b170 posso farlo..? Quarta domanda: Il programma dc-unlocker2client_1.00.1308 per lo sblocco del boot e' il programma giusto? Attendo risposta alle mie domande.. Grazie anticipatamente per la vostra pazienza e la vostra disponibilità.
  7. #46
    S22 Ultra,Find X2 pro,Mi 10
    Quote Originariamente inviato da sung80 Visualizza il messaggio
    Pazienza e disponibilità ne abbiamo moltissima! Purtroppo esperienza sul Mate 8 di meno. Quindi penso che dovrai fare riferimento a discussioni estere per avere notizie più precise. Hai dato uno sguardo su XDA?
    Sto Guidando (cit. Dieguccio)
  8. #47
    Apr 2014
    Grazie per avermi risposto. Fra le tante cose acquisite una mi sfugge.Una volta roottato il Mate8 non riesco a capire se posso tornare in dietro per esempio dalla b180 alla b170...ricordandomi il note 3 neo una volta roottato era possibile andare solo avanti e non indietro..Purtroppo su XDA questo importante particolare non viene menzionato. Idem in altri blog.
  9. #48
    Apr 2014
    Ciao @govema noto che il tuo root e' andato a buon fine potresti aiutarmi a chiarire i miei dubbi? te ne sarei grato .dopo i tanti dubbi almeno per la teoria comincio a vedere la luce infondo al tunnel .Pero' mi rimane ancora qualcosina da capire.Dopo aver fatto sto benedetto root e nel caso in qui volessi riflashare un firmware stock.Posso flasharlo dalla recovery TWRP o pure devo flasharlo da FastBoot? Fatto questo perdo il Root e recovery? giusto ? I file per il root presi su XDA sono compatibili per la NXT-L29C432B170 e NXT-L29C432B180 Grazie mille.
  10. #49
    Maledico il momento in cui ho rootato il Mate 8. Quando si cerca di entrare in modalità download, si avvia invece la TWRP che non legge la memoria interna del telefono. Ho letto che bisognerebbe flashare una boot image decrittata ma non ho idea dove posso trovarla
    Ultima modifica di gafran; 01-07-16 alle 14:21
  11. #50
    Apr 2014
    Invece di flashare firmware e super su dalla recovery e' possibile provare da fastboot.. ma non sono sicuro che funzioni.. aspettiamo altre risposte. Comunque giro vangando in rete per risolvere il problema della sd interna consigliano di fare i wipe principali. Dopo di che la TWRP dovrebbe riconoscere la memoria interna.
  12. Il seguente Utente ha ringraziato sung80 per il post:
    gafran (01-07-16)
