Pagina 30 di 33 primaprima ... 202829303132 ... ultimoultimo
Visualizzazione dei risultati da 291 a 300 su 330
[GUIDA] LeTV LeEco LE2 X520 QUALCOMM installazione rom BB72
  1. #291
    Moderatore L'avatar di mariomac66
    MILANO
    tutti i leeco e molti altri
    Ringraziato 515 volte in 422 Posts
    did you do all the wipe? from recovery. go to wipe and put the flag under system, date, cache dalvik, and then repeat the flash of cuoco92 ROM. the le2 heats up enough. especially if it is connected to the charger. I do not know kernels for that ROM which is based on EUI. sorry for my English.
    RICORDATI IL THANKS MI RACCOMANDO!!!!!!!!!!!!!
    E importante, se vuoi che la tua richiesta venga condivisa con tutti. ricordati il THANKS
    Sempre pronti, anche quando no sembra.
    Aug 2018
    Hi my Friend!
    When you say... ''put the flag under system'' what do you mean???
    In the Flash rom i do anyting wipe, again the same... Also when flash of cuoco92 ROM, the device information see processors snapdragon 821 while my device has snapdragon 625
    I do not understand what really happens...
    Thank you, however, for your interest!!
    When I came to put it, the 20s Rom the device opened normally arrived to the point that reads Sim card (network cards)...did not see any of the two and got stuck...
    sorry and from me for my English!
    Ultima modifica di mariosalex; 25-08-18 alle 20:25
  4. #293
    MILANO
    Yes. that's a bug. also on other ROM for 652 it happens. but it's just the build.prop of the phone. you can wait and see if it continues to heat up. the background ROM update of all google services is very hot. if you want to try something similar. you can try the gizrom 1.4 now I send you the link.
    https://rom.gizchina.it/leeco-le-2/
  5. #294
    Androidiani Power User
    Sep 2014
    Ringraziato 5,328 volte in 4,413 Posts
    Quote Originariamente inviato da mariosalex Visualizza il messaggio
    Hello my Friends!
    I have one Le 2 x520 and after Flash some roms, whit the last "X527-ROW-5.9.028S_VR10_CUOCO92" . After "maybe" the last rom the phone by turning it on heating.
    I believe I think it was done with Kernel....
    Please if anyone knows something let help me.
    Thank You!
    This is an Italian forum, you have to speak Italian, in case use translator.
    Ultima modifica di complicazio; 25-08-18 alle 20:59
  6. #295
    Aug 2018
    I will try and rom you say gizrom 1.4
    Thank you!
    The problem who does not read Sim card has happened to you???
  7. #296
    Sep 2014
    Thank you!
    What you did not understand?
    Inviato da Mi MIX 2
  8. #297
    Aug 2018
    Ok! mi perdoni!
  9. #298
    Sep 2017
    ciao a tutti come al solito devo aver fatto un po di casino,mi è arrivato un le 2 x 526 ed ho sbloccato il bootloader poi installato sempre da fastboot con adb la twrp 3.2.1-0-s2.img ed è andato tutto ok quando però sono andato a riaccendere il cell mi chiede di inserire una password per avviare android... cosa posso fare??? avevo letto qualcosa ma non avrei voglia di andare a rileggermi tutti i forum..qualcuno può aiutarmi??grazie
  10. #299
    MILANO
    Devi decriptare facendo il format data. Cancellerai i dati ma non la ROM. Riavvio decripta e poi rimetti in twrp e flash della ROM
  11. #300
    Sep 2017
    ma da dove lo faccio il format data ?in realtà non ho ancora deciso che rom mettere per ora stavo solo sbloccando il boot loader e twrp e fare il root
  12. Il seguente Utente ha ringraziato vdm71 per il post:
    mariomac66 (28-08-18)
