Pagina 18 di 37 primaprima ... 8161718192028 ... ultimoultimo
Visualizzazione dei risultati da 171 a 180 su 367
[ROM][LP 5.0.x] Stock modded by BB72 per LeEco Le1S | Basata su ROM indiana [X500]
  1. #171
    Senior Droid L'avatar di esperanza
    Ringraziato 146 volte in 109 Posts
    titanium backup
    Sono ben accettati i ringraziamenti, grazie
    http://www.stampicementofaidate.altervista.org/
  2. I seguenti 3 Utenti hanno ringraziato esperanza per il post:
    250652 (10-04-16),BB72 (09-04-16),zotorov (09-04-16)
    Androidiano L'avatar di laikexpert
    Feb 2016
    CyberSpace
    Le 2 Pro X625
    Ringraziato 87 volte in 51 Posts
    BB72
    What is the problem with Yahoo Weather app in BB72 012S ROM ?
    (Does not operate normally)
    Why Yahoo Weather app comes preinstalled with BB72 012S ROM ?
    When I uninstall Yahoo Weather app from my phone
    and do
    reboot or shut down
    and
    phone turns on
    Yahoo Weather app exists installed on my phone ?
    (then offering update of Yahoo Weather app in Play Store)
    -When I start this app does not work!
    -When I do the update and start this new app does not work!
    Allow to operate normally Yahoo Weather app
    and no needs Root access and anything like that.
    BB72 you've set that Yahoo Weather app comes preinstalled with BB72 012S ROM
    (I think that's the main problem)
    Please make a patch for this problem.
    Ultima modifica di laikexpert; 10-04-16 alle 04:23 - Motivo: correzione
    Le 2 Pro X625 [Official Stock ROM] 5.9.026S
  5. #173
    Quote Originariamente inviato da laikexpert Visualizza il messaggio
    BB72
    and do
    reboot or shut down
    and
    phone turns on
    Yahoo weather is default app into x507 Indian rom...I didn't modify it...
    EDIT:
    To solve the problem before uninstall yahoo weather then just go to system/vendor/operator/app with some root explorer and delete yahoo_weather directory... Then reboot and install it from playstore
  6. Il seguente Utente ha ringraziato BB72 per il post:
    laikexpert (10-04-16)
  7. #174
    Senior Droid L'avatar di Nion88
    Pisa
    H7300,Zopo zp100,M PAI ROYALTY
    Ringraziato 64 volte in 48 Posts
    Per informazione:il link di Dolby atmos non funziona più (dicitura errore temporaneo ,sto riprovando).
    Nion88
    L'odio è un liquore prezioso, un veleno più caro di quello dei Borgia; perché è fatto con il nostro sangue, la nostra salute, il nostro sonno e due terzi del nostro amore.Bisogna esserne avari.
    Charles Baudelaire
    Quote Originariamente inviato da Nion88 Visualizza il messaggio
    Da PC funziona....
  9. #176
    Pisa
    Da PC funziona....
    Mi spiace ,forse dovrò provare un altro browser .Ma da prima ad ora da pc(riavviando anche il browser crome) mi da errore.
    Nion88
    Charles Baudelaire
    Io uso Firefox... Fammi sapere se risolvi...
  11. #178
    Pisa
    Niente anche installando Mega sync ed utilizzando firefox ...riproverò più tardi potrebbe essere un problema mio .Alquanto strano dato che contemporaneamente scaricavo la tua Rom ,che anche non avendola provata credo sia perfetta e di questo ti ringrazio sempre.
    Nion88
    Charles Baudelaire
    prova QUI........
  13. Il seguente Utente ha ringraziato BB72 per il post:
    Nion88 (10-04-16)
  14. #180
    Pisa
    prova QUI........
    Grazie ,questo link funziona.Ciao.
    Nion88
    Charles Baudelaire
  15. Il seguente Utente ha ringraziato Nion88 per il post:
    BB72 (10-04-16)
