Pagina 14 di 71 primaprima ... 412131415162464 ... ultimoultimo
Visualizzazione dei risultati da 131 a 140 su 706
[KERNEL][LP]Dorimanx per LOLLIPOP[LG G2]
  1. #131
    Androidiano VIP L'avatar di edoardomarco
    GNexus/Nexus4/LG G2/Note4
    Ringraziato 989 volte in 796 Posts
    Kernel 3.5
    *Merged updates to ARM and IRQ
    *Merged updates to CPUFREQ stats code.
    *Merged updates to QsecCom driver.
    *Merged updates to SPI_QSD driver.
    *Merged change to allocate 2MB RAM more for sound driver to prevent crash!
    *Merged MMC change that allow to boost write performance or reduce bu save power.
    *Added new control option in Dorimanx App for MMC power/performance.
    till now we had it set to powersave. now we can have faster MMC.
    *Merged Update to all CPU GOVS that allow correct CPU freq limit checks.
    *Merged tuning to WIFI suspend mode.
    *Set heavy protection from NULL POINTER DEFERENCE'S causing panic in kernel.
    Android default is 32K lowest ram limit. i have set 64K to maximize protection.
    *Merged updates to CPUSET CGROUP as i have seen that some kernel panics came from it.
    *Restored min RAM for apps to 16MB was 64MB this was my change to fight with panic bugs.
    but it's was no helping. just reduced allowed RAM for apps. the null pointer protection should help.
    *integrati update a arm e irq
    *integrati update al codice cpufreq stat
    *integrati update ai driver qseccom
    *integrati update ai driver spi_qsd
    *integrati i cambiamenti per allocare 2mb di ramin piu per i driver audio
    *integrati i cambiamenti al mmc per ridurre consumi e aumentare le oerformance
    *integrati update a tutti i gov cpu
    *integrati i settaggi alla modalita sospensione wifi
    *integrati update a cpu set cgroup
    *ripristinata la ram minima per app a 16mb
    26/06/15
    Kernel 3.4
    *Updated AIO FS code. cleaned old hacks from it. now in sync with 3.10.y by 98%
    not all can be ported without more changes.
    *Restored MMC code change that needed for LP, i have removed it in early builds 1.xx
    with KK it's crash MMC. but here it's was by default from stock... so i have tested and restored.
    *Cleaned wakelock check/clean on every check for charger... to many checks, can lead to bugs.
    we dont need it any more, was made for KK.
    *Merged fix to Selinux perms in case used in enforce mode by @Blastagator
    *Merged Google Services power drain and wakelock fix by @Alcolawl
    *Merged fix for switch mutex guards from KK kernel.
    *Merged fix to speedup I/O for SSD flash.
    *aggiornato il codice aui fs
    *ripristinati i cambiamenti al coidice mmc
    *integrati update ai permessi selinux
    *integrati fix al consumo di batterya del gioogle play services
    *integrtai i fix per il cambio mutex guards da kitkat
  2. Il seguente Utente ha ringraziato edoardomarco per il post:
    DreamReaper (28-06-15)
    Androidiano VIP L'avatar di kRel
    Pixel 9Pro-GalaxyTabS8Ultra
    Ringraziato 713 volte in 588 Posts
    Quote Originariamente inviato da liberaccio Visualizza il messaggio
    Ciao kRel. Lo carichi da spento o da acceso? Starò attento durante la carica, e riporterò le mie impressioni.
    Da acceso (era sottointeso). Non l'ho mai più spento da mesi.
    Che scaldi è normale, siamo anche in estate. L'importante è che non diventi molto caldo al contatto...
    Ricorda che ci sono delle opzioni specifiche che spengono uno o più cores della cpu se la temperatura eccede i limiti pre--impostati...
    Ultima modifica di kRel; 28-06-15 alle 15:30
    Serenità e bellezza vanno cercate nelle piccole cose (kRel)
    smartphone: invece di semplificare la vita la complica, invece di far risparmiare tempo ce ne fa perdere tanto
    Spendere tanto è l'unico svantaggio, spendere poco comporta problemi e disagi. Spendere troppo poco equivale a perdita certa
  5. #133
    Androidiani Power User
    Lo sto usando con illuminazione al massimo da circa mezz'ora, bello fresco, settimana scorsa, con la versioni precedenti era diventato caldissimo.
    Soddisfatto
  6. #134
    Androidiano VIP L'avatar di liberaccio
    wp7,desire,g100,HOX,G2
    Ringraziato 439 volte in 379 Posts
    Quote Originariamente inviato da kRel Visualizza il messaggio
    Io tendo a caricarlo da spento durante la notte (solito giochino per resettare le statistiche di carica della batteria). Raramente lo carico da acceso.
    Devi dire che però dopo il deep sleep ho avuto di nuovo un po' di lag. Continuo qualche giorno ancora in default e poi smanetterò un po' nei settaggi.
    Ultima modifica di liberaccio; 28-06-15 alle 15:58
    From G2 to OP3... nice to meet you OP3
    Il serve a ringraziare...Lo sapevi?
  7. #135
    Androidiano L'avatar di MarticusDroid
    Sep 2013
    System 32
    Salve, posso chiedere qual'è la miglior configurazione per il dorimanx con buone prestazioni e ottima durata di batteria? Ho letto che con le impostazioni di default non è granché come kernel, ma che bisognerebbe perderci tempo a smanettarci. Ho la versione d802, qualche consiglio?
  8. #136
    Ringraziato 63 volte in 47 Posts
    Quote Originariamente inviato da th3D0ct0r Visualizza il messaggio
    Soddisfatto
    Ma con i settaggi stock?
  9. #137
    Senior Droid L'avatar di Sku89
    Jul 2010
    Forlì
    LG G2 D802 Black
    Ringraziato 28 volte in 21 Posts
    Messa la 3.5 da kernel stock stiamo a vedere.
    Nel caso volessi spostare i primi parametri per non andare a toccare cose delicate su cosa devo puntare?
  10. #138
    Quote Originariamente inviato da MarticusDroid Visualizza il messaggio
    In prima pagina ci sono i link
    Quote Originariamente inviato da elvi92 Visualizza il messaggio
    Ho messo il governor alucard e basta
    Quote Originariamente inviato da Sku89 Visualizza il messaggio
    Puoi iniziare con il modificare il governor
  11. Il seguente Utente ha ringraziato th3D0ct0r per il post:
    elvi92 (28-06-15)
  12. #139
    Jan 2014
    è possibile effettuare un backup del sistema su OTG? non ho spazio nel telefono
  13. #140
    Quote Originariamente inviato da seba92r Visualizza il messaggio
    Certamente, basta collegare la chiavetta e selezionarla come destinazione
  14. Il seguente Utente ha ringraziato th3D0ct0r per il post:
    seba92r (28-06-15)
