Pagina 223 di 279 primaprima ... 123173213221222223224225233273 ... ultimoultimo
Visualizzazione dei risultati da 2,221 a 2,230 su 2783
  1. #2221
    Lamezia Terme
    Ringraziato 20 volte in 17 Posts
    Si devi avere i permessi root e dal play store puoi scaricare la seguente app https://play.google.com/store/apps/d...imations&hl=it
  2. Il seguente Utente ha ringraziato Gennaro97 per il post:
    darto16 (15-04-14)
    Androidiano VIP L'avatar di lucaarx
    Sant'Angel!!!
    LG Optimus 4X HD
    Ringraziato 564 volte in 418 Posts
    Quote Originariamente inviato da unreal67 Visualizza il messaggio
    Qualcuno sa come posso tradurre il mio post in inglese? il primo che ho messo in questa discussione. Vorrei farlo con il google traduttore ma da quanto ho visto traduce malissimo.
    Sono parecchio arrugginito ma ci provo.... se qualcuno vede delle oscenità me lo faccia pure notare!
    I know that build a rom it's not that easy, and make it stable and fully working it's even harder. I also know that drivers and blobs are closed-source, so it's hard to make a device fully working.
    But I wanna give some advice, because who want to mod his phone finds about 30/40 roms all unstable and full of bugs.
    In my opinion, it's useless to release a rom if it isn't finished, wifi or bluetooth doesn't work, apps force-close, phone reboots randomly or maybe drinks the battery in 2 hours.
    Lags in games, the home screen lags with 3/4 widgets. Maybe after a clean install the rom performs well but then you discover that it's not so good.
    Let's not forget also that despite the roms are not finished, many times they aren't update any more to solve the bugs, or they are updated but the bugs remain.
    I don't mean that ALL the roms have ALL the bugs, but each rom has at least two of those problems.
    Some people may say that there are hardware limits to justify the bugs. Or maybe that the battery has to be changed. But those are only excuses considering that on three pages of roms, ONLY one performs well.
    I have always been told “you have to change the battery”, or “the phone has got few ram” to justify the bugs. But why with the FluidRom gType (an Italian rom) I manage 24 hours with a normal usage (mobile data always on, wifi, background apps, little playing with games, several calls, facebook and whatsapp)? No lags in games, home and browser. So I assume that “change the battery” and “we have few ram” are only excuses.
    If you release a rom only to show that you are able to develop something but then it’s full of bugs, stop. Don’t release it. Or release it when it performs really well.
    The 4X it’s a 2012 flagship phone, but the roms are badly developed. So let’s not blame the hardware.
    Some people may say “who forces you to change rom?” People try new roms because modders promise improvements.
    Maybe this topic will be closed to restrict freedom of speech. But mine are only suggestions.
    Ultima modifica di lucaarx; 16-04-14 alle 17:11
    C'è chi è stato ammaestrato e subisce col capo chinato... noi no...
    Chi non ha mai vomitato ubriaco, chi ha servito lo stato.... noi no....
    Chi ha amore per il potere, chi ti dirà "Sissignore!!"... noi no...
    Chi un'opinione la gira a seconda del vento che tira.... noi no....
  5. Il seguente Utente ha ringraziato lucaarx per il post:
    unreal67 (16-04-14)
  6. #2223
    Senior Droid L'avatar di unreal67
    Sep 2013
    Xperia P,Z/Lg4x/s3/s2/lumia520
    Ringraziato 51 volte in 50 Posts
    Quote Originariamente inviato da lucaarx Visualizza il messaggio
    Guarda non so come ringraziarti. Ho provato con google traduttore, ma per quanto io ne so poco di inglese mi sono accorto che traduce con i piedi, anzi avvolte neanche hanno senso le frasi.
    Grazie ancora.
  7. #2224
    Androidiano VIP L'avatar di antyavi
    Salerno
    LG G2,LG 4X,LG L9,LG3D
    Ringraziato 416 volte in 272 Posts
    Sul 4X solo le ROM basate su stock vanno bene, scordatevi le Cyano, MiUi o simili.
    Se sono stato d'aiuto un thanks è sempre gradito
  8. #2225
    Sep 2013
    Non e proprio vero. Ci sarebbero anche delle rom kitkat, per esempio la beanstalk old blobs 8-03-14. Con la quella si riesce ad avere ottime performance ed una buona autonomia. Funziona il tutto apparte il tethering che avvolte da problemi. Ma anche alcune mokee. Ma purtroppo i modder hanno abbandonato le old blobs per concentrarsi sulle cm e grouper blob. Ottime performance ma piene di bug.
    Alla fine io proprio non capisco cosa conta avere piu performance se poi la camera non va oppure ogni volta bisogna usare patch e scripts per riuscire a fare un video. Se poi molte applicazioni crashano, o varie cose non vanno tipo wifi gps o NFC. Bhooo
  9. #2226
    Senior Droid L'avatar di lou84
    Napoli
    Lg G2
    Ringraziato 119 volte in 116 Posts
    Io sto provando la beanstalk basata su cm,e' del 13,e' presente solo tra i commenti su xda,con kernel iodakv9.95,e devo dire che va molto bene anche meglio della old blobs,ho apprestato alcuni accorgimenti con trickstermod per il risparmio energetico (per chi e' interessato chieda che mando le screen),inoltre ha un'apposito tweek per il risparmio energetico...a me piace la ROM stock ma sono più per la funzionalità e rapidità, e' tutta una questione di gusti...antyavi ti propongo quando avrai finito lo sviluppo della gtype e se ne avrai voglia di cimentarti in una ROM leggera come le aosp
    Ultima modifica di lou84; 19-04-14 alle 12:08
  10. #2227
    Salerno
    Ma come fate a dire che le cyano sui tegra vanno bene?
  11. #2228
    Senior Droid L'avatar di paolotheking
    Oct 2013
    Puglia
    GAce-4XHD-G3-Gflex2-N5X-H6X-G6
    Ringraziato 104 volte in 100 Posts
    Questo topic è già ridicolo qui, c'era bisogno di aprilo anche su xda?
    For modders Only bug rooms STOP - xda-developers
    Le risposte lasciate sono già abbastanza esaustive.
    Se ti sono stato d'aiuto dammi un tank, magari un Leopard.
  12. #2229
    Sep 2013
    Quote Originariamente inviato da paolotheking Visualizza il messaggio
    Si perché i modder non sanno fare una pippa. Promettono miracoli invece rilasciano cavolate. Solo rom piene di bug. Neanche sistemano i bug che gia rilasciano altre versioni 2-3 versioni. Oltrettutto hanno il coraggio di dire MORE PERFORMANCE MORE BATTERY . Ma se devi smanettare 2 ore per abbassare i settaggi in modo da arrivare a mezzogiorno con la batteria, meta delle applicazioni crashano e neanche funziona tutto.
    E tuo xda e androdiani per caso? ognuno metter quello che li pare. Se a te vanno bene quelle bug rom ottimo, ma uno nuovo che prova a migliorare il suo telefono si trova almeno 20 rom buggate e una buona. Quindi sarebbe meglio che i modder le sistemano invece di aggiungere temi e varie personalizzazioni inutili.
    Oltretutto nessuno ti obbliga a leggerlo tanto meno commentare con discorsi inutili.
    Ecco un esempio : 20 (se non di piu) pagine di rom su xda tutte piene di bug e con componenti non funzionanti in continuo aggiornamento. Antyavi ne rilascia una ogni tanto e vanno benissimo, niente bug e ottima autonomia. Dovrebbero prendere esempio.
  13. #2230
    Sep 2013
    Quote Originariamente inviato da antyavi Visualizza il messaggio
    Non so se sbaglio ma mi pare che prendono i driver o blobs (come si chiamano) sal nexus 7 o simili in modo far funzionare il tutto.
