Pagina 13 di 17 primaprima ... 31112131415 ... ultimoultimo
Visualizzazione dei risultati da 121 a 130 su 169
CyanogenMod7 KANG build
  1. #121
    Senior Droid L'avatar di vincevince55
    Ringraziato 108 volte in 102 Posts
    ho da poco quello di huexxx dopo aver avuto un paio di sod dopo l ultimo ripristino del backup e non ho avuto problemi simili...potrebbe davvero essere solo questione di governor...lo cambi in cyanogen> performance
    Fight the war, fuck the norm!!
    Androidiano VIP L'avatar di pado11
    Polesella (Ro)
    OnePlus 5, Nexus 5, Lg p970
    Ringraziato 589 volte in 469 Posts
    Nuova versione della Boypes
    Highlights of my CM7 Kang:
    • All CM7 commits up to August 3, 2012
    • Very smooth and snappy overall experience (smooth spinners, smooth indeterminate progress bar, different screen transition animations, some other things)
    • Enhanced audio experience (digital audio mixer, increased headphone volume, Beats Audio, more volume increments)
    • Increased battery life through kernel tweaks like writeback variables, underclocking, WLAN undervolting, and LED-button light dimming
    • CM7 Kernel with battery-optimized smartass2 governor, additional interactivex and ondemandx governors, default SIO i/o scheduler(2012 version), and battery optimized sysctl variables
    • G-key usable as a launch button for the camera app, as shutter key inside the camera app, and also as music play/pause key when the screen is locked
    • increased camera jpeg quality (pictures are ~ 1.3 - 1.7 MB)
    • Option to center the statusbar clock (not enabled by default) and change the clock's color (white by default)
    • Option to set the statusbar color (not enabled by default). You can choose between fully transparent, semi-transparent, and any custom color.
    • Optional 1.2 GHz overclocking via menu
    • Fixed GPS performance and largely fixed audio routing
    • Already integrated Google apps and some other useful apps
    • VPN support
    • G-recovery
    X tutto il resto vi rimando al thread su xda
  4. #123
    Sarebbe la CyanogenMod 7 modificata?
  5. #124
    Polesella (Ro)
    Dipende cosa intendi x "modificata", cmq,si...la nuova KANG di Boype...
  6. #125
    Androidiano L'avatar di MegaParty
    Ottimo, mi pare stia migliorando a vista d'occhio, tra poco potrei anche pensare di metterla!
    Inviato dal mio LG-P970 con Tapatalk 2
  7. #126
    ieri a causa di un mio errore la zeus v6.39 non partiva piu e gia che c'ero ho deciso di provare la boype (l'ultima)
    Ma..facendo un bench con quadrant ho notato che zeus vince 10 a 0..possibile? la cyano non dovrebbe essere piu prestante?
  8. #127
    Polesella (Ro)
    Ancora con sti Benchmark o simili?!?!? Ma lasciate stare sti cavolo di programmi! Non servono assolutamente a niente! Non rendono l'idea...cosa ti interessa se si hanno 500 punti in meno ma,nell'uso quotidiano non ci sono impuntamenti rallentamenti ecc... Sono più valide le impressioni personali che quelle cavolate di punteggi lì...!...almeno ognuno ha il suo modo di vedere le cose... E poi sono valutazioni troppo variabili (dipende dalle app che hai già su...quelle in funzione...come viene gestito il tutto...da quanto tempo la ROM è in funzione su quel terminale...)... Ognuno può fare tutte le valutazioni che vuole,ma è risaputo che i bench non servono a nulla!
  9. #128
    Non ti arrabbiare però. XD.. comunque non sono molto d accordo sul fatto che non servono ..io lo usavo per fare prove cambiando frequenza del processore per scegliere quella col miglior rapporto prestazioni consumi
    Inviato dal mio LG-P970 usando Androidiani App
  10. #129
    Polesella (Ro)
    No,tranquillo...mica mi arrabbio...
    Secondo me...x confronti "istantanei" sulla stessa ROM, i benchmark potrebbero ancora avere un senso,ma tra ROM diverse, in condizioni più o meno differenti proprio non servono (mia personale opinione ovviamente)...
  11. #130
    Boh pero la Zeus mi dava una sensazione di maggiore "potenza" del cellulare.. per caso la boype e poi pesante della cyano liscia?
