Pagina 16 di 17 primaprima ... 614151617 ultimoultimo
Visualizzazione dei risultati da 151 a 160 su 169
CyanogenMod7 KANG build
  1. #151
    Androidiano VIP L'avatar di pado11
    Polesella (Ro)
    OnePlus 5, Nexus 5, Lg p970
    Ringraziato 589 volte in 469 Posts
    Ragazzi,Boype ha terminato il suo lavoro con la CM7...ha rilasciato un'ultima versione giusto ieri e ha spiegato che sarà l'ultima ROM Gingerbread 2.3.7 che sviluppa... In attesa del rilascio di ICS da parte di Lg e quindi di iniziare i lavori per una CM9 e si spera una CM10 anke x il nostro Black... Riporto il suo post:
    Hi again,
    the OP has been updated with a new version. Here's the changelog:
    cm-7-package-20120905-p970-boype
    Reverted RIL to v11b due to occasional loss of signal problems
    Reverted camera libs to v11b due to the first two seconds of video recording being black
    Set touchscreen refresh rate slightly above the display refresh rate for smoother scrolling (71 Hz)
    Reverted Wifi scan interval to 20 seconds (CM7 default) to counter some Wifi (re-)connect issues
    Updated Play Store and ROM Manager to latest version
    All CM7 commits up to September 5, 2012
    Kernel: Reverted CPU transition latency to 15ms (LG default)
    Compiled Kernel and ROM with default CM7 toolchain (GCC 4.4.3) for maximum compatibility and as few bugs as possible. Linaro caused strange behavior sometimes!?
    As I was on vacation, it's been a while since I last looked into this thread.
    The version I have just posted may well be the last CM7 version I will realease, if there are no new major bugs occurring. As ICS should be available within a foreseeable future, I see no point in continuing to work with CM7. The bugs that are left are left for a reason - I do not believe I am able to fix any of them (I tried, believe me). If there are, however, any major commits from the CM7 repository, I'll make a new build.
    After ICS is released for our device, I'll put some effort in contributing to the CM repositories (fixing bugs, etc.). Probably I will also release a custom Kang.
    I'd like to thank everyone for providing me with input for improvements, and also everyone among the almost 12,000 downloaders for trying / using my ROM!
    Best regards
    Da xda-developers - View Single Post - [ROM+KERNEL] [GB 2.3.7] [2012-SEP-05] boype's modded CyanogenMod 7
    Aggiorno il post in prima pagina...
    Ho la boype di agosto...devo fare wipe data per mettere questa?
    Inviato dal mio LG-P970 usando Androidiani App
  4. #153
    Polesella (Ro)
    No...durante l'installazione tramite AROMA dovrebbe chiederti quale tipologia di installazione vuoi fare...tu scegli "Update CM7"...
  5. #154
    mikimaiki
    Montata ieri cm sempre ottima rom stabile cn possibilità di overclock fino a 1200MHZ.... A questa frequenza si può tenere in daily use?
  6. #155
    Polesella (Ro)
    In teoria si...anke se non so quanto possa migliorare...anzi forse ci potrebbe essere un consumo leggermente maggiore... Cmq non dovrebbe avere problemi in teoria...
  7. #156
    nessuno di voi ha problemi col fix dei satelliti gps? da quando ho installato questa Rom (boype) ho mole più perdite dis egnale rispetto alla v0q originale, qualcuno ha qualche idea per risolvere l prob? Grazie
  8. #157
    ma visto che con l ultima boype è stato aggiornato il play store vuol dire che una serie di applicazioni non saranno piu aggiornate essendo una rom non ufficiale e lo sviluppo della stessa è terminato?
  9. #158
    Polesella (Ro)
    Non capisco cosa tu voglia dire...perdonami...spiegati meglio...
    Inviato dal mio LG-P970 con Tapatalk 2
    Senza ordine non esisterebbe nulla, senza caos non evolverebbe nulla...
  10. #159
    Quote Originariamente inviato da madiweb Visualizza il messaggio
    Gli aggiornamenti delle app continueranno ad arrivarti normalmente....
  11. #160
    Polesella (Ro)
    ...ma quello mi sembra ovvio...cosa centrano le app con le ROM? Al massimo non ti vengono visualizzate proprio quelle non installabili...
