Super Droid
I seguenti 5 Utenti hanno ringraziato ANDROIDPC per il post:
Byteater (25-04-12),MajinJoko (30-04-12),Marco95 (20-03-12),mattia76 (16-04-12),vismo (06-03-12)
Super Droid
Ultima modifica di ANDROIDPC; 20-03-12 alle 21:47
Smartphone: Samsung Galaxy NeXuS i9250
ROM: Stock JOP40D - JB 4.2.1 Rooted
Kernel: Stock 3.0.31
Super Droid
Continuano a proliferare Kernel per ICS/CM9!
Karsh Kernel e HP Kernel (Si, Spica stà lavorando adesso su questo fronte).
Aggiornati in prima pagina!!!
Super Droid
Aggiornamento al Gueste Kernel 1.5 per ROM Stock!
Changelog:
- versions with normal, lite and DS battery driver (credits to their initital creators, I got lite+DS from vadonka's git repo)
- Android Logging completely disabled in kernel (saving some juice)
- changes in cpu speed stepping (eye on good battery)
- enormous and unbelievable increase in smoothness (scrolling,..) while keeping power consumption low at the same time, no trade-offs - achieved through many days and nights of testing; special THX to Horst77 (mod @ handy-faq.de) for his outstanding testing work!!
- exclusively introducing GuesteOC tool for overclocking and 2nd Core testing; tool mady in mane hours of work by TrymHansen exclusively for guestekrnL (you are my hero, Trym, thank you very much!! ) -- attention, tool won't work with other kernels
- first and only kernel featuring "liquid-scroll" technology introduced by me for best scrolling smoothness
- reverted/deleted cherry-picks from SR3 kernel out of 13 files (git is showing 15, I mistakenly altered additional files); it increased the smoothness even more
- lowered max. ScreenOff frequency to 456 MHz for better power saving - wakeup from sleep is still quick
- various power consumption tweaks
- Switched from fb_earlysuspend to console_earlysuspend and thus breaking compatibility with AndrevOC -- but we have GuesteOC now as full replacement -- the screen-off settings are gone as they have no effect because limit of 456 Mhz on screenOff is hard-coded directly in kernel
- attempt to fix Fast Dormancy bug directly in kernel -- please test on an un-patched ROM, didn't have time for. fd log spamming should eventually be gone -- Edit: not possible to test as I disabled kernel logging will have to test separately!
- slightly increased low corner voltages for better stability
- lowered power comsumption during sleep (and use too of course)
- smallest stock-based kernel (+ smallest kernel modules)
- additional build flags by spica1234 for better performance
- removed BLX
- init.d now working on all ROMs, doesn't matter on which ROM you flash the kernel, even on ROMs with non-working init.d it will work afterwards
Secondo l'autore dovrebbe aumentare la fluidità del cellulare contenendo sempre il risparmio energetico.
Da testare.
Link sempre in prima pagina..
Super Droid
Anche Spica continua i suoi sviluppi del Kernel HP sulla CM9 giunto già alla versione RC1!
Sempre in prima pagina il LINK!
Super Droid
Super Droid
Aggiornamento Kernel ETANA per CM7/MIUI
..basato su Kernel 3.0.27 di Imperticus
Si aggiorna anche Hourse Power per ICS di Spica alla versione RC1-R con le seguenti modifiche:
+(RC1-R) Fully Optimized for 10% more responsiveness and UI fluidity than all previous HP ics builds (RC1-R)
+(RC1-R) very quick application opening and multi tasking than all previous HP ics builds (RC1-R)
+(RC1-R) Low Latency Relatime Processing optimized, Application opening extra smooth than all previous HP ICS builds (RC1-R)
+(RC1-R) Fully optimized for 2D accelarated UI smoothness and responsvieness(Although in impresence of full GPU accelaration) (RC1-R)
+(RC1-R) OTF gpu ram hack(Thanks to vadonka) (RC1-R)
+(RC1-R) Full fixed mobile data usage limit ( Thanks to harsh bhaila) (RC1-R)
+(RC1-R) Fully KSM(Kernel Samepage Merging) compatible (RC1-R)
+(RC1-R) hybrid tool chain compilation. Modules seperately compiled with gcc-4.5 for more run time stability, while seperately kernel compilation with gcc-4.7(seems stable than 4.6) (RC1-R)
+(RC1-R) More Robust charging BSOD prevention than all previous HP ics builds (RC1-R)
+(RC1-R) More freeze free than all previous HP ics builds (RC1-R)
+(RC1-R) OpenGL and ELS optimized by GCC Flags(smoother game play) (RC1-R)
+(RC1-R) OTF application now saving values after re-opening (RC1-R)
+(RC1-R) 20% more battery life rather than previous hp builds (RC1-R)
+(RC1-R) More ROBUST memory management after days constant usage (RC1-R)
+(RC1-R) More CrystalClear voice definition(16Bits/96KHz) during media playback and optimized InCall volume frequency(RC1-R)
+(RC1-R) Fully overall optimization to feel not the impresence of GPU accelaration (RC1-R)
+(RC1-R) Multi-Thread Thumb-2 GCC optimizations for cortex-a9 multi-core performance (RC1-R)
+(RC1-R) Fully GCC ARM Graphite code implementation for faster loop unrolling and faster do -go to- kernel codes access (RC1-R)
..aggiornata la 1° pagina..
Super Droid
Nuovi aggiornamenti Kernel:
Per ICS
Karsh Kernel ICS 3.0.28
Kernel SuperNova RC4 by hei1125
Per CM7
Imperticus Kernel 3.0.27
Etana 3.0
Per ROM Stock
GuesteKernel 1.6.1
Aggiornate in prima pagina le diciture, tenendo fede che in ogni modo quando viene aggiornato un Kernel automaticamente venite reidirizzati al link della nuova versione su XDA.
Rinvio sempre a XDA per changelog e download.
Ultima modifica di ANDROIDPC; 21-04-12 alle 09:09
Super Droid
AGGIORNATO IN PRIMA PAGINA:
Per ROM Stock
1) AdrenalineForce Kernel based on SR3R
Per ROM CM7/MIUI:
1) Etana Kernel
Per ROM CM9:
1) Harsk Kernel
2) Nova Kernel
3) Jarvis Kernel
Il seguente Utente ha ringraziato ANDROIDPC per il post:
- Non puoi inserire discussioni
- Non puoi inserire risposte
- Non puoi inserire allegati
- Non puoi modificare i tuoi messaggi
Regole del Forum
