Pagina 168 di 258 primaprima ... 68118158166167168169170178218 ... ultimoultimo
Visualizzazione dei risultati da 1,671 a 1,680 su 2571
DjangoManouche 1.2 - Renaissance - Dedicated to Superskill and Topogigi
  1. #1671
    Androidiano VIP L'avatar di jumperman
    Sep 2010
    NEXUS 5 32GB
    Ringraziato 112 volte in 98 Posts
    Quote Originariamente inviato da sreeprajay Visualizza il messaggio
    you are right...You can use the Myrt+HP app for settings. I thank you for trying this Kernel. I am sure you will not repent for flashing.Battery life is really great friend.Smooth scrolling too.Thanks to Spica for the guidance and tool
    I had a big problem at the end of a call. The screen is no longer active, I waited 10 minutes (I was doing other things) and I had to disconnect the battery. when the system was restart, the battery was 1%! First it was at 60% :-(
    Problem 2: the wifi don't work property. my home connection arise out range.
    For the last installation i wiped all and the system is clean
    Inviato dal mio LG dual core usando il cervello B-)
    Ultima modifica di jumperman; 08-06-12 alle 15:48
    Bangalore, India
    ofcourse LG O2X
    Ringraziato 19 volte in 9 Posts
    Quote Originariamente inviato da jumperman Visualizza il messaggio
    looks your device is one of the devices which dont like the OC....increase the voltage by +25mV by using Systemtuner app in the system settings.
    Thanks for trying
  4. #1673
    Sep 2010
    NEXUS 5 32GB
    Thanks for trying
    I don't use oc, max frequence is 1050mhz. The wifi problem is a router problem, the problem with the call was isolated, i take other call without problem.
  5. #1674
    Androidiano VIP L'avatar di Frango
    LG Optimus 2x. iPod 4
    Ringraziato 209 volte in 165 Posts
    la nuova baseband è compatibile? se la risposta fosse si dovrei flasharla con smartflash (perderei tutti i dati???) e dopo mi ritrovo con la nuova baseband e ancora la django?
    LG OPTIMUS DUAL
  6. #1675
    Sep 2010
    NEXUS 5 32GB
    Io ti consiglio di non insegue a tutti i costi l'aggiornamento, 1 perché carburano ha sviluppato la sua rom su un altra base e poi perché chi ti dice che la nuova base sia migliore della precedente?
    Io ti consiglio di aspettare anche perché la rom cosi come é direi che é perfetta
    Ultima modifica di jumperman; 09-06-12 alle 01:25
  7. #1676
    Senior Droid L'avatar di polmone76
    Apr 2011
    S7 Edge - S3 - Asus TF300
    Ringraziato 23 volte in 20 Posts
    Quote Originariamente inviato da Frango Visualizza il messaggio
    Compatibile lo è, io ho fatto un backup, flashato la bb, ripristinato backup, messo il ril e tutto funziona, solo bisogna vedere se va bene con una base di 20q... Proverò... Al massimo monto la rebuild e aspetto una django basata su 20s ;-)
    Paolo Soave - Photography -
    www.paolosoave.com
  8. #1677
    Mi tengo la v20q.. in effetti va benissssssimo
    LG OPTIMUS DUAL
  9. #1678
    Sep 2010
    NEXUS 5 32GB
    Quote Originariamente inviato da polmone76 Visualizza il messaggio
    Si ma non capisco che senso ha abbandonare una rom come la django per una stock by LG che non si sa nemmeno se é valida
  10. #1679
    Apr 2011
    Per me non è una questione di abbandonare, anzi... Io sono ancora con la django, ma la bb se è stata migliorata perché non sfruttarla?
    Per me che ho tre come operatore e uso solo il 3g è importante che la linea sia stabile e si senta bene, anche perché l'audio della 20q non mi esaltava...
    Proverò questa ;-)
    www.paolosoave.com
  11. #1680
    Sicilia
    Lg 4x HD
    Ragazzi ma come siamo con i lavori della django? a che beta siamo arrivati? Che bug ci sono visto che è ancora in fase di beta
