Pagina 57 di 258 primaprima ... 747555657585967107157 ... ultimoultimo
Visualizzazione dei risultati da 561 a 570 su 2571
DjangoManouche 1.2 - Renaissance - Dedicated to Superskill and Topogigi
  1. #561
    Senior Droid L'avatar di carburano
    Rimini, Italy
    Xperia Z3 Copper
    Ringraziato 476 volte in 163 Posts
    DJANGO MANOUCHE 0.7
    3 versions:
    - Stock (with 95Mb compcache and with optimization inspired by Zeppelinrox Supercharger 5.2)
    - Stable (with HP SR2 and with optimization inspired by Zeppelinrox Supercharger 5.2)
    - Spica (with RC11-R and PP10, Zeppelinrox Supercharger 5.2 is available as a script in /system/xbin/v6sc.sh)
    Changelog:
    - Completely rebuilt on a mix of 20o/Gr6 from Modaco
    - Settings.apk without OSP
    - 20i ril (15 days without signal drops)
    - Back to old Wpa_supplicant (to solve wifi reboots...)
    - Optimized tweak in init.d folder (removed useless ones)
    - Added modified 90script by Vadonka for better ram management (inspired by Zeppelinrox Supercharger... Don't care about free ram amount... )
    - Zeppelinrox Supercharger 5.2 script available in /system/xbin/v6sc.sh
    - Maniacdave's Camera Mod
    - BBA support
    - Cyanogen apn
    - Dalvik binary fron ICS
    - Modded Battery Autocalibration script by SEO (Normal one doesn't work because it's not compatible with P990)
    - Busybox v1.19.3 by wraithdu
    - Patched SQlite from Spica's PP10 (better I/O and good scrolling)
    - 3 Transformation packs from Gabriesu (ICS, Icecomb and Swish)
    - Updated Facebook app
    - Updated TB
    - Other things I don't remember now
    DOWNLOAD
    DjangoManouche 0.7 EXT3 Stock Supercharged: Download
    DjangoManouche 0.7 EXT3 SR2 Supercharged: Download
    DjangoManouche 0.7 EXT4 RC11-R PP10: Download
    DJANGO MANOUCHE 0.7 Transformation Packs by Gabriesu!
    ICS Transformation Pack: Download
    Swishstyle Transformation Pack:Download
    IceComb Transformation Pack: Download
    Screenshots:
    IF YOU LIKE MY WORK YOU CAN:
    DONATE TO "EMERGENCY" (To help war hospital) HERE
    or you can offer me a beer
    HERE
  2. Il seguente Utente ha ringraziato carburano per il post:
    docmoody (05-02-12)
    Apr 2011
    HTC One
    Ho appena messo la nuovissima 0.7 SPICA + transformation pack ICS (della 0.6, perchè mi piace la batteria circolare con percentuale visibile). Al momento ho le stesse, belle, sensazioni della 0.5. Veloce, fluida. A 1.1 GHz faccio sempre un eccellente 3200 a quadrant. Devo provare la videochiamata con gtalk (mi pareva non funzionare con la 0.5) ma al momento tutto perfect.
    Grazie a Carburano per aver fatto volare un cellulare che la casa madre ha lasciato alla deriva.
  5. #563
    Androidiano L'avatar di docmoody
    Apr 2011
    Prato
    Samsung Galaxy S5
    Ciao si puoi disinstallare il launcher , e metterne uno tipo che funzioni non go launcher consigli ?
    Ultima modifica di docmoody; 05-02-12 alle 11:17
    Se pensi che io ti sia di aiuto stato, un grazie sarà sempre ben accettato, premi quindi il pulsante che a tal scopo è stato impostato
  6. #564
    Quote Originariamente inviato da admad Visualizza il messaggio
    Sai che non lo so!!
    Prova magari con titanium,forse da li riesci!?
    Inviato dal mio LG-P990 usando Tapatalk
    Fatto! Grazie mille!
  7. #565
    Apr 2011
    HTC One
    Ma c'è la camera mod di maniacdave? Mi sembra quella stock con frame rate basso..
    Carburano, puoi mica controllare, please? Grazie
  8. #566
    Androidiano L'avatar di virtvs
    Vicenza
    LG Optimus Dual, LG P880 4X HD
    in download....aspettavo da molto quest'aggiornamento...grazie carburano!!
    IN MEDIO STAT VIRTVS
  9. #567
    Philippines
    samsung galaxy s3
    salve ragazzi se metto questa rom DjangoManouche 0.7 EXT4 RC11-R PP10 non devo fare il wipe vero?ora o la rc11 r...grazie e volendo mettere swih trasformer come devo fare?
  10. #568
    Vicenza
    Quote Originariamente inviato da isola Visualizza il messaggio
    è sempre consigliato fare gli wipe prima di installare una qualsiasi rom...
  11. #569
    Philippines
    samsung galaxy s3
    grazie virtus me li devo fare tutti i wipe?
  12. #570
    Vicenza
    si...i tre wipe...così sei sicuro di non incorrere in problemi, tranne i soliti delle nuove rom
