Pagina 8 di 258 primaprima ... 6789101858108 ... ultimoultimo
Visualizzazione dei risultati da 71 a 80 su 2571
DjangoManouche 1.2 - Renaissance - Dedicated to Superskill and Topogigi
  1. #71
    Androidiano L'avatar di docmoody
    Apr 2011
    Prato
    Samsung Galaxy S5
    Non sapevo di questo 'problema' causato dallo swap memory, puoi citare alcune fonti che parlano di questo ?
    carburano che ne pensi ?
    Jul 2010
    Dal punto di vista tecnologico le memorie flash hanno un numero di scritture limitato.
    Le vecchie flash prevedevano circa 10k scritture, quelle nuove arrivano al milione. Dipende tutto dal numero di accessi in scrittura che il sistema operatvo fa sulla memoria stessa. Ora se ne fa un centinaio al giorno, tutto ok, ma se ne fa >10k in meno di un anno hai rovinato la SD.
    Memory wear
    Another limitation is that flash memory has a finite number of program-erase cycles (typically written as P/E cycles). Most commercially available flash products are guaranteed to withstand around 100,000 P/E cycles, before the wear begins to deteriorate the integrity of the storage.[8] Micron Technology and Sun Microsystems announced an SLC NAND flash memory chip rated for 1,000,000 P/E cycles on December 17, 2008.[9]
    The guaranteed cycle count may apply only to block zero (as is the case with TSOP NAND devices), or to all blocks (as in NOR). This effect is partially offset in some chip firmware or file system drivers by counting the writes and dynamically remapping blocks in order to spread write operations between sectors; this technique is called wear leveling. Another approach is to perform write verification and remapping to spare sectors in case of write failure, a technique called Bad Block Management (BBM). For portable consumer devices, these wearout management techniques typically extend the life of the flash memory beyond the life of the device itself, and some data loss may be acceptable in these applications. For high reliability data storage, however, it is not advisable to use flash memory that would have to go through a large number of programming cycles.
    [fonte wikipedia]
    Senza una implementazione del BBM o di ottimizzazione del wareout della memoria il sistema rischia un lento degrado. Se questa implementazione esiste a basso livello (il controller della flash) allora non dovrebbe essere un problema se la memoria per lo swap é abbastanza grande.
  4. Il seguente Utente ha ringraziato 4lph4 per il post:
    docmoody (05-01-12)
  5. #73
    Senior Droid L'avatar di alezzandro86
    Ringraziato 51 volte in 27 Posts
    ragazzi perdonate l'ignoranza, ma tra questa e la cyanogenmod quale delle due fa si che la batteria duri di più? e quali presenta meno bug con le applicazioni varie che si posson installare dal market?
    un ultima domanda ho letto che è possibile decidere l'OK e l'UV ma sapreste dirmi come??
  6. #74
    Senior Droid L'avatar di carburano
    Rimini, Italy
    Xperia Z3 Copper
    Ringraziato 476 volte in 163 Posts
    NEWS:
    DjangoManouche 0.5 Spica ONLINE!
    Changelog:
    2 versions: Spica and ICS
    - ICS Edition with theme by ghostaldinov (Great Job, man!)
    - No Wipe!
    - EXT4
    - Edited Framework.jar for smooth scroll (INCREDIBLE) (thanks AndroidON)
    - Increasing ringtone disabled
    - Added ICS transition animations in framework-res.apk (thanks Capez)
    - Solved issue with Polaris Office
    - Updated Titanium Backup
    - More tweaks added for stability, performance and memory management.
    - Solved TW and launchers crashes
    - Added FD log tweak by Gueste
    - Added Init.d tweak by Vadonka (Thanks man!)
    - Added Sqlite by Gueste - Better Scroll (and removed initd entry by Spica)
    - Updated Twitter
    DjangoManouche 0.5 Spica ICS Edition: DOWNLOAD
    DjangoManouche 0.5 Spica: DOWNLOAD
    Special thanks for this version to Gueste, HDBlog, Androidiani and Facebook Group "LgDual"
    FPS will follow... Stock will be back in 0.6
  7. #75
    Androidiano VIP L'avatar di mats25101979
    Bologna
    Huawei Mate 10 pro
    Ringraziato 278 volte in 240 Posts
    Pronti allo scaricamento....... Via ahahahaah grande carburano.
  8. #76
    Bologna
    Huawei Mate 10 pro
    Quote Originariamente inviato da carburano Visualizza il messaggio
    NEWS:
    Changelog:
    - No Wipe!
    - EXT4
    - Updated Twitter
    Carburano volevo chiederti se è possibile avere il thema ics anche sulla rom spica normale. Il motivo è che mi trovo molto bene con la tastiera LG e quella nella rom spica ics non riesco proprio a usarla però mi piace molto la grafica delle icone di ics. Quindi o metto il thema ics sulla rom spica oppure installo la tastiera LG (e non saprei come fare) sulla rom spica ics. Ti ringrazio già per una eventuale risposta. La rom va che è una meraviglia domani testerò i consumi e il navigatore ma per ora non posso che dire, ancora un ottimo lavoro.
    Inviato dal mio LG-P990 usando Tapatalk
  9. #77
    Androidiano L'avatar di venom84
    Ringraziato 21 volte in 12 Posts
    Ragazzi io ho la 0.4 stock, va una meraviglia, giusto il fatto che ogni tanto (mi è capitato 3 volte da domenica) mi perde il segnale (X) o visualizza si le tacche ma sono irraggiungibile se mi chiamano!
    Questa cosa proprio non mi va giù, io sotto ho la BB824, che dite potrebbe essere quello?
    Voi cosa mi consigliate e avete anche voi questi problemi?
  10. #78
    Bologna
    Huawei Mate 10 pro
    Quote Originariamente inviato da venom84 Visualizza il messaggio
    Ciao venom io ho la bb 725 e non ho mai avuto il problema che hai avuto tu, io come operatore ho vodafone però. Io ti consiglerei di mettere la 725.
  11. #79
    Quote Originariamente inviato da mats25101979 Visualizza il messaggio
    Anche io ho Vodafone!
    Perciò dovrei riflashare il tutto...(mi potresti dare i link della BB e RIL?)..e poi mettere la ROM! Giusto?
  12. #80
    Baby Droid L'avatar di ROSSOBLU
    Zena
    LG Optimus Dual
    Complimenti ancora!!! Installato la 0.5 ICS........ Superlativa!!!!!!
    L'unico peggioramento l'ho riscontrato nell'icona della batteria.... davvero illeggibile e, imho, più brutta della precedente!
    GARRONE SANTO SUBITO!!
