Pagina 20 di 76 primaprima ... 1018192021223070 ... ultimoultimo
Visualizzazione dei risultati da 191 a 200 su 756
[ROM] CyanogenMod 7.2
  1. #191
    Caserta
    P20 / P10
    Ragazzi i changelog sono al link in prima pag ma negli ultimi giorni e spesso down, cmq aggiornare conviene sempre quindi procedete. Potete o fare installazioni pulita o aggiornare
    Inviato dal mio LG-P500 con Tapatalk 2
    Caserta
    P20 / P10
    Ritoccato il primo post e riscritto il secondo.
  4. #193
    Androidiano VIP L'avatar di Cosmogenesis
    Nov 2010
    Lg Optimus One, Galaxy Nexus
    Ringraziato 191 volte in 163 Posts
    Changelog della RC2:
    unzip: fix a second bug in warning fixes (android_external_busybox)
    fix most sign and variable initialization warnings (android_external_busybox)
    Safeguard against dumping large amounts of memory if SP is bogus. (android_system_core)
    toolbox: remove TARGET_RECOVERY_PRE_COMMAND, defined in libreboot (android_system_core)
    Update Pepephone Internet APN (android_vendor_cyanogen)
    Update Telenor Online apn settings (android_vendor_cyanogen)
    p500: Fix non-repeating ringtones (android_device_lge_p500)
    Busybox 1.20.0 squashed commit for gingerbread (android_external_busybox)
    init.rc: update the permission of /data/local. (android_system_core)
    Restrict zygote to system user. (android_system_core)
    Applying theming to more framework items. (android_frameworks_base)
    Implementing Sunfire-related fixes (android_frameworks_base)
    This will expand the build time GCC check to include 4.7.x (android_external_webkit)
    Implement a new use case where the phone has a one-stage camera button only (sunfire). (android_packages_apps_Camera)
    Make absolutely sure the keyboard is never shown over the dialer. (android_packages_apps_Contacts)
    Fix call forwarding indication. (android_packages_apps_Phone)
    Fix for a Phone app crash related to multiradio operation. (android_packages_apps_Phone)
    Bluetooth: Fixup problems with the SDP records (android_external_bluetooth_bluez)
  5. I seguenti 2 Utenti hanno ringraziato Cosmogenesis per il post:
    marce (14-05-12),Sid220 (14-05-12)
  6. #194
    Androidiano VIP L'avatar di Sid220
    Apr 2011
    Como
    Xiaomi Redmi 3 Pro
    Ringraziato 205 volte in 186 Posts
    Scarico e installo!
    <---SE TI SONO STATO D'AIUTO USA IL TASTO THANKS
    Leeco Le2 X526 -> Poco F1 coming soon
    ROM:Pixel Experience
    Previous devices: LG P500 Optimus One, Galaxy S2 - S4, Xiaomi Redmi 3 Pro
  7. #195
    Forano
    LG p500 optimus one
    Grazie del changelog cosmo
    Inviato dal mio LG-P500 usando Androidiani App
    Samsung Galaxy S5 (SM-G900F)
    ROM: Stock (with root) (Android 5.0 Lollipop)
    KERNEL: Stock
    RECOVERY: TWRP 2.8.5.0
  8. #196
    Forse la nightly precedente la rc2 è migliore, almeno per quanto riguarda l'audio delle chiamate, ritornato basso nell'uso delle cuffie..
    Inviato dal mio LG-P500 usando Tapatalk
  9. #197
    Ragazzi stamattina ho provato a fare l'aggiornamento alla rc2 da rom manager.... ora sono in fastboot mode on.... ho trovato delle guide in giro ma non riesco a far riconoscere il telefono al pc. Ho installato i driver del p500 scaricandoli dal sito lg su tre pc diversi e con tutti l'installazione hardware fallisce. cosa posso fare per far riconoscere il cel? in questo modo non posso fare la procedura di ripristino dell'immagine della recovery tramite sdk!!!!!!!!
  10. #198
    Caserta
    P20 / P10
    Ragazzi non smetterò mai di ripeterlo, evitate di usare rom manager e come recovery usate la amonra che nell'ultima versione é decisamente migliore della cwd. Cmq nella mia guida di aggiornamento alla baseband v20 c'è anche la procedura per il fastboot
  11. #199
    Apr 2011
    Como
    Xiaomi Redmi 3 Pro
    @alfonsus: non ho ancora testato ció, dovrei avere ancora sul pc lo zip fixer delle librerie audio, provo e faccio sapere
    Ultima modifica di Sid220; 17-05-12 alle 12:45
  12. #200
    Apr 2011
    Como
    Xiaomi Redmi 3 Pro
    Probabile bug: avendo attivato i comandi musicali sulla lockscreen ma senza spunta su "mostra sempre", ogni tanto mi appaiono senza che vi siano cuffie collegate o app musicale aperta
LinkBacks (?)
  1. 04-06-12, 14:49
