Grazie perfetto. Tutto fatto!!
Se mi vuoi davvero ringraziare, un "Thanks" devi lasciare
Sapete come si disintalla l'anti-theft di avast? Quello con i permessi di root! Le ho provate tutte ma non ci riesco!!!
Inviato dal mio SMARTPAD810C usando Androidiani App
finte potresti upparmi il FW 1.0.21 della prestigio su megaupload o su altro? dal sito ufficiale della prestigio è lentissimo![]()
First of all: HAPPY NEW YEAR!!
Second: THANK YOU Finte, I've reading all this thread and you allways are there.
Sorry but I'm spanish, and if google translate this (like traslate when i'm reading...) you can't understand me (horrible!).
2 or 3 weeks ago I bought the BQ Kepler, and when i discovered this forum no more offical ROMs :-)
I installed your 2.6 and all goes withouth problems (during 10 days all goes OK).
But whit this 2.6.1 something goes wrong.
I've tried 2 versiones, one called "FIXED" and other "FIXED2" (One comment about this: what about if you put in the first page the checksum of the file? No more problems about what is the good version, isn't it?)
The "FIXED2" reboots the tablet (in the first 10 minutes trying to configurate it reboots 3 or 4 times). Then I changed with the "FIXED" and the problem is that all is frezze and some FC (configuring the google account and trying to insert in the Market). Imposible to work.
I dont know what is the problem (mine is 8GB and I supposse you have 4GB, and you can try in a Kepler.
Download again? I'll do but I've installed 2 versions.
If you need something about me, trying or anything I'm here for that. I don't know anything about programming or creating images, but i can use linux...
Thank you very very much.
Goito.
Ultima modifica di goito69; 03-01-12 alle 18:28
fintematic (03-01-12)
Direi che non devi preoccuparti, il 3g mi riservo di usarlo occasionalmente... Da quando esistono, per completezza ho sempre flashato rom con 3G (che sono anche quelle più 'avanti') : prova questa ROM così com'è ... a mio giudizio non ti deluderà neppure sull'autonomia. L'autonomia dipende da enne fattori e il 3G, specialmente se non utilizzato, direi è quasi irrilevante. Poi c'è chi ci scrive, forse anche giustamente, delle pagine a proposito. Ma quando comunque hai 1/2 giornata d'uso contuinuo, mi stanco prima io ... Tu che dici?
Ciao
Quoto Otticus,la batteria con questa rom di Finte 2.6.1 dura davvero tanto.....
@Fintee grazie mille per app.......
ho provato a collegare per la prima volta il pad al televisore davvero ottimo come reattività e fruizione di video e img ma è normale che una volta collegato si spengne il monitor del pad?
Diventa un pò difficoltoso l'utilizzo in questa modalità... qualcuno mi sa illuminare?
SAMSUNG SII
ROM:stock> cyano>aosp> paranoid > >jelly beam> avatar >chameleon > omnirom
Hi goito,
I do not know what could happen, I can assure you that I use every day and no still nothing has happened to me, is the newest version fixed2 .. to other forum members who have used it nothing happened like that ... You can try the version riflashare fixed2 and let me know .. I can not do more than that because as I wrote I have not had this type of problem
I too am using google translate so you may not understand what you write
Hi
Finte![]()
