Pagina 6 di 44 primaprima ... 4567816 ... ultimoultimo
Visualizzazione dei risultati da 51 a 60 su 433
[GUIDA] Moto X - Come flashare un firmware + Guida aggiornamento OTA
  1. #51
    Mar 2014
    <?xml version="1.0"?>
    <flashing>
    <header>
    <phone_model model="PRO_CFC_ATT" />
    <software_version version="ghost_att-user 4.4 13.11.1Q2.X-69-3 5 bldacfg,release-keysMSM8960PRO_BP_2323.026.100.00R" />
    <interfaces>
    <interface name="AP" />
    </interfaces>
    </header>
    <steps interface="AP">
    <step operation="getvar" var="max-download-size" />
    <step operation="oem" var="fb_mode_set" />
    <step operation="flash" partition="partition" filename="gpt.bin" MD5="4A74372A529557CB16DE2B05AC975AAA" />
    <step operation="flash" partition="motoboot" filename="motoboot.img" MD5="44467DAF3011254E66C2F3892F8EE165" />
    <step operation="flash" partition="logo" filename="logo.bin" MD5="187908E994F5B42710D13DBB5126D6D2" />
    <step operation="flash" partition="boot" filename="boot.img" MD5="0C89F1FC2EAF9BA8E22CCDB716AF6F1F" />
    <step operation="flash" partition="recovery" filename="recovery.img" MD5="597797E8E8D2DB3281CD8CDA3D040421" />
    <step operation="flash" partition="system" filename="system.img" MD5="4D09BB5A96FF6612206728C310CCB647" />
    <step operation="flash" partition="modem" filename="NON-HLOS.bin" MD5="3A3F6FFFB382820F0BFF3EB954EFADE5" />
    <step operation="erase" partition="modemst1" />
    <step operation="erase" partition="modemst2" />
    <step operation="flash" partition="fsg" filename="fsg.mbn" MD5="A96C5D1C3EAD20818D9D7E1EA1C1000C" />
    <step operation="erase" partition="cache" />
    <step operation="erase" partition="userdata" />
    <step operation="erase" partition="customize" />
    <step operation="erase" partition="clogo" />
    <step operation="oem" var="config carrier att" />
    <step operation="oem" var="fb_mode_clear" />
    </steps>
    </flashing>
    Fresco fresco di .zip
    Moderatore L'avatar di solocchi
    Pixel 10 Pro XL
    Ringraziato 982 volte in 793 Posts
    Quote Originariamente inviato da albixema23 Visualizza il messaggio
    Se flesha scrivi uno per uno nella finestra di dos questi comandi:
    fastboot oem fb_mode_set
    fastboot flash partition gpt.bin
    fastboot flash motoboot motoboot.img
    fastboot flash logo logo.bin
    fastboot flash boot boot.img
    fastboot flash recovery recovery.img
    mfastboot flash system system.img
    fastboot flash modem NON-HLOS.bin
    fastboot erase modemst1
    fastboot erase modemst2
    fastboot flash fsg fsg.mbn
    fastboot erase cache
    fastboot erase userdata
    fastboot erase customize
    fastboot erase clogo
    fastboot oem config carrier att
    fastboot oem fb_mode_clear
    Edit: Se ti fa storie quando arrivi al "mfastboot flash system system.img" scarica quest'altro pacchetto files adb&fastboot:
    https://mega.co.nz/#!rINTCL7b!A1mXr0...w__hJgki3fOjrQ
    Ultima modifica di solocchi; 18-03-14 alle 00:47
  4. #53
    Mar 2014
    al comando "fastboot flash partition gpt.bin" la risposta sul cellulare e stata
    "downgraded security version
    update gpt_main version failed
    preflash validation failed for GPT
  5. #54
    Pixel 10 Pro XL
    Niente lo sente come un downgrade. Se fossi in te se è questione di giorni aspetterei il firmware 4.4.2 AT&T così fai un'installazione pulita. Altrimenti bisogna sbloccare il bootloader in qualche modo e dopo con il Toolkit fai il downgrade in automatico.
  6. #55
    Mar 2014
    perche il downgrade non si puo fare senza sbloccare il bootloader? colpa di AT&T?(curiosità) tu puoi downgradeare quando vuoi con il tuo?
  7. #56
    Pixel 10 Pro XL
    Questa è una domanda che mi sono posto anch'io. No non è colpa di AT&T è Motorola e credo anche altre case costruttrici che impediscono i downgrade con il bootloader bloccato. Io ho sbloccato il bootloader per avere il root e sperimentare alcune cose. Non ho sbloccato il bootloader per il downgrade anche perché per i Moto X europei non esiste un firmware più vecchio dei KitKat 4.4.2.
  8. #57
    Ringraziato 54 volte in 43 Posts
    Quote Originariamente inviato da solocchi Visualizza il messaggio
    dal 4.4.2 non si puo piu fare il downgrade anche se hai il bootloader sblocatto
    come detto solocchi pare che provi di fare downgrade
    che versione avevi su moto x?
    questo e il 4.4 ultima disponibile
    http://sbf.droid-developers.org/down...evice=0&file=4
    scaricalo e prova a flasharlo
    da quello che so io At&t non ha il bootloader sblocabile e puo essere anche per quello che ricevi sti errori
  9. #58
    Pixel 10 Pro XL
    Quote Originariamente inviato da danielvicol Visualizza il messaggio
    Perché fino a adesso cosa ha provato a fare? Quasi sicuramente l'errore che continua ad avere è dovuto al fatto che ha mescolato due firmware il suo e quello en.EU e con molta probabilità il suo X ha caricato una secure version più aggiornata rispetto a quella installata sul 4.4 del AT&T quindi quando cerca di ripristinare il firmware il telefono crede di dover eseguire un downgrade. Poi io non avendo un Moto X USA posso solo supporre questo.
  10. #59
    Mar 2014
    Quest'oggi è uscito l'aggiornamento AT&T 4.4.2 ma non c'e nella lista droid-developer, quanto ci mettono di solito a caricarlo?
  11. #60
    Pixel 10 Pro XL
    Dipende. Generalmente sono abbastanza veloci nel reperire il firmware e postarlo.
