Utente del giorno: kroko con ben 1 Thanks ricevuti nelle ultime 24 ore
Pagina 3 di 11 primaprima 12345 ... ultimoultimo
Visualizzazione dei risultati da 21 a 30 su 101
Enomther The Official
  1. #21
    Senior Droid L'avatar di theanswer
    Sep 2009
    Ringraziato 126 volte in 93 Posts
    Quote Originariamente inviato da snakkuzzo Visualizza il messaggio
    Ora cé la 2,13 cosa cambia??
    Queste sono le novita' che porta la versione 2.13.2
    10/11/2010 - v2.13.2 - New!
    - fixed - Wysie's Contacts dialer no longer FC's
    ---- (but had to remove the haptic feedback ... this is temporary till I get a proper .3 out)
    10/11/2010 - v2.13.1
    - updated - Base code to AOSP-2.2.1_r1-FRG83
    --- This is the main intent of this update, FRG83 includes quite a few fixes in and of itself.
    --- There were lots of bug-fix requests that may/may-not be fixed by FRG83 update, please check and re-report if need be.
    --- Also there were a lot of feature requests that did not make it into this build, as the FRG83 update was enough for me at present.
    - fixed - HTCCamera now relies on a fake sysfs entry for 5MP detection (so you can use other kernels like pershoot's)
    - fixed - You can now use the stagefright toggle under all circumstances (but I recommend leaving it enabled)
    - fixed - the included Terminal App is now visible for launch from AppDrawer
    - fixed - FC's with certain Apps like Weatherbug, etc.
    NOTE: If you use the StockGallery with the HTCCamera and would like better ordering of pictures/videos ...
    ----- See Jack_R1's thread here for his MOD. [MOD][FIX] Gallery3D - with high-res patch, for stock and HTC cameras - xda-developers
    ----- Just didn't have enough time to fully test/think-through for incorporation this go around. Thanks Jack!
    NOTE: ThemeTemplates updated and virtually all apks/jars updated, so please use the new ones.
    Io l'ho flashata ieri... se e' possibile mi sembra che sia ancora piu' longeva come autonomia delle 2.12, per il resto perfetta veloce e funzionante al 100%!
    Androidiano VIP L'avatar di snakkuzzo
    Jun 2010
    roma
    Ringraziato 106 volte in 87 Posts
    Bella
    Sent from my HTC Desire using Tapatalk
    Le vie del signore sono infinite...ecco togliti da davanti che ti schiaccio!
  4. #23
    Androidiani Power User L'avatar di Lultima
    Sep 2010
    Ringraziato 122 volte in 75 Posts
    Quote Originariamente inviato da theanswer Visualizza il messaggio
    Answer la batteria è infinita...il kernel di enom è una vera BOMBA!!! inoltre devo dire che le enom's sono tra le rom più stabili in assoluto...
    Se il mio intervento ti ha aiutato clicca sul pollice giallo in basso a destra con scritto Thanks... !!!
  5. #24
    Jul 2009
    Ringraziato 26 volte in 16 Posts
    voglio proprio provarla vediamo se è così ottima come dite
    Rom: CyanogenMod-6.0.0-N1-RC3 build FRF91
    Kernel: 2.6.34.4-cyanogenmodshade@toxygene #1
    Recovery: RA_Nexus 1.7.0.1
    GAPPS: FRF91+
    Radio: 32.36.00.28H_4.06.00.12_7
  6. #25
    Senior Droid L'avatar di zenzip
    Mar 2010
    Ringraziato 20 volte in 20 Posts
    la proverò anche io, anche se ho passato Kang-O-Rama e Cyano secondo me sarà difficile trovare ROM migliori...
    trattative concluse positivamente con: Ghizmo, chiasottis, Cozzieri, LeftyHernandez, mabima2, venum e tanti altri...
  7. #26
    Sep 2009
    Quote Originariamente inviato da Lultima Visualizza il messaggio
    Per ora a stabilita' non c'e' stata nessuna cyano che ha battuto questa! Io ho trovato la pace dei sensi! E' perfetta! La consiglio a tutti!
  8. #27
    Jun 2010
    roma
    si aspetto l'arrivo della sd da 8 g,e metto su questa
  9. #28
    Jul 2010
    ha la radio fm?...
  10. #29
    Mar 2009
    Nexus One & Nexus S
    Quote Originariamente inviato da stexlex Visualizza il messaggio
    ha la radio fm?...
    no
    Realizzazione siti web dinamici - Posizionamento nei motori di ricerca - Creazione loghi e grafiche - Short URL - Analizzatore Serp online
    http://fedepupo.it
  11. #30
    Sep 2010
    Una volta te lo dissi ...
