Pagina 210 di 302 primaprima ... 110160200208209210211212220260 ... ultimoultimo
Visualizzazione dei risultati da 2,091 a 2,100 su 3012
[ROM][LP 5.0.x] Stock modded by Cuoco92 per Nubia Z7 Mini [NX507J]
  1. #2091
    Nubia Z7 mini
    Ringraziato 24 volte in 21 Posts
    Qualcuno ha per caso provato a fare un video con musica ad alto volume con queste ultime release?
    Dec 2015
    Can someone help me out with some clarifications...
    1. I see that there are two new versions available 3.78 and 3.81. The 3.81 is called REV02_ what does that mean?
    I understand that I need to do factory reset for both this versions.
    2. I saw that some user had problem with BT, what was the problem?
    And then there was discussion about the way to install the fix, did you have to do two factory resets?
    Thanks
    Edit: I went ahead and installed 3.81 and everything went well except I'm not getting notifications. I know the same problem was there on 3.69 but that there was an app called Notification Manager where one could fixed the issue, that app is not in the phone now.
    Edit 2: I think I figured it out, thank god Spanish and Italian are both Latin language. So I had to first go down to version 3.63 and then back to 3.81. Going from 3.69 to 3.81 gives problem with notification even if you do factory reset.
    Ultima modifica di Leo8301; 21-02-16 alle 11:40
  4. #2093
    Androidiano L'avatar di icomei
    Jan 2015
    Ringraziato 53 volte in 41 Posts
    Qualcuno ha per caso "Nubia manager" o "Nubia neoSafe" tradotta?
    È comoda per controllare i permessi delle altre app ad esempio aliexpress (ma se non ricordo male, anche quella di amazon) accendono il Wi-Fi e/o gps in automatico.
    Questa è la schermata che mi compare dopo aver impostato a "chiedi" il permesso di accedere al WiFi da Nubia manager
    Edit:Avevo impostato a "chiedi" anche il permesso di modificare le impostazioni
    Ultima modifica di icomei; 21-02-16 alle 20:32
  5. #2094
    Quote Originariamente inviato da Cuoco92 Visualizza il messaggio
    Prova ad installare questo Fix dalla twrp.
    https://mega.nz/#!SJoCRDDZ!iJ-Y7IMrA...LVS7oVNp5-eeTU
    Devi poi fare un FACTORY reset
    Ho installato la 3.81 e devo dire che è una bomba...
    Solo ho notato un lieve consumo di batteria in più rispetto a prima... ma forse anche perchè stanno girando più app, cmq non arrivo a sera senza ricaricare...
    Invece il fix per il BT non ha funzionato ho ancora il problema delle disconnessioni quando uso le cuffie.... hai qualche altra soluzione nel cilindro...???
  6. #2095
    Oct 2013
    Ringraziato 76 volte in 64 Posts
    @cuoco 92
    Ciao, mi é comparso l'avviso dell'aggiornamento ota ma non mi parte il download. Volevo anche farti presente una cosa (non so se hai già risolto con le traduzioni inserite nell'aggiornamento) : questa notte, per motivi di lavoro, ho dovuto chiamare il 112. Al termine, nella lista delle chiamate, mi ritrovo questo
  7. #2096
    Super Droid L'avatar di Cuoco92
    Sardegna
    #Z7-Z9 MAX #Z7 MINI #K3 NOTE
    Ringraziato 3,958 volte in 1,624 Posts
    @fabry77
    Devi mettere il prefisso nazionale +39 (+39113) perché alcuni di questi numeri sono presenti anche Cina .
    Per gli aggiornamenti ota, se scarichi dalla rete mobile devi togliere la spunta da qui.
    Lo trovi sotto le impostazioni del programma di aggiornamento.
    Con l'aggiornamento OTA 2.99 per coloro che hanno il gestore TIM, non ci sarà più bisogno di inserire gli apn manualmente
  8. #2097
    Oct 2013
    Ok, grazie per le informazioni. L'aggiornamento non mi va in download ne dà rete mobile ne dà WiFi. Mi dice "impossibile ottenere lo stato del download"
  9. #2098
    HuaweiP1/XiaomiRed/NubiaZ7mini
    Ringraziato 43 volte in 39 Posts
    Quote Originariamente inviato da fabri77 Visualizza il messaggio
    Il download non va neanche a me
  10. #2099
    Sardegna
    Ci do uno sguardo
  11. Il seguente Utente ha ringraziato Cuoco92 per il post:
    nexuspolaris (24-02-16)
  12. #2100
    Sardegna
    Quote Originariamente inviato da araldico Visualizza il messaggio
    Vado un po' off-topic ma volevo informare cuoco92 che l'apn di default vodafone, web.omnitel.it è sbagliato, perché causa già dall'accensione del telefono un addebito di 6 euro da parte di Vodafone.
    Mi dici cortesemente qual'è l'apn corretto? Così lo aggiorno negli apns
    Grazie per il feedback 😉
