Pagina 238 di 302 primaprima ... 138188228236237238239240248288 ... ultimoultimo
Visualizzazione dei risultati da 2,371 a 2,380 su 3012
[ROM][LP 5.0.x] Stock modded by Cuoco92 per Nubia Z7 Mini [NX507J]
  1. #2371
    Androidiano L'avatar di frabrevi
    Pixel 5, OnePlus 3T
    Ringraziato 24 volte in 20 Posts
    Quote Originariamente inviato da petarda01 Visualizza il messaggio
    Hello everyone, I apologise for using English. I am currently on the 3.88 version and I found out that I sometimes can't recieve SMS messages. The sender gets a confirmation that the SMS got delivered but on my Z7 mini nothing shows up. Only after switching the SIM slot did I recieve a newly sent SMS... I don't think it's because one of the slots is bad because I haven't been able to recieve any SMS messages while using the other slot a few days back in exactly the same way as now... Any thoughts?
    Probably you solved your problem switching the 2 sim cards. Try to re-switch the 2 sims.
  2. Il seguente Utente ha ringraziato frabrevi per il post:
    petarda01 (11-04-16)
    May 2015
    I only use one Sim card. Changing the slots does help, but I first have to find out that someone sent me a message that didn't get through to me which isn't exactly ideal...
  5. #2373
    Pixel 5, OnePlus 3T
    I mean, probably you will not have problems again. If I am not wrong, changing the sim makes the phone re-set the right configuration. And this kind of problem is not so common, so making that one time will definetly solve your problem. So, take a second sim (your friend's one, if you have not another one), put it into your slot, than put back yours.
    I hope I've understood your problem and I helped you. If not, we will wait for someone else's anwer. Good luck!
    Ultima modifica di frabrevi; 11-04-16 alle 01:54
  6. Il seguente Utente ha ringraziato frabrevi per il post:
  7. #2374
    ZTE Z7 Mini
    Ciao,
    come si fa a riabilitare la possibilità di bloccare il telefono semplicemente cliccando nell'angolo in alto a destra sull'orario?
    Grazie mille.
  8. #2375
    Super Droid L'avatar di Cuoco92
    Sardegna
    #Z7-Z9 MAX #Z7 MINI #K3 NOTE
    Ringraziato 3,958 volte in 1,624 Posts
    Quote Originariamente inviato da borrosmac Visualizza il messaggio
    Ciao,
    Grazie mille.
    Nella 3.88 nn l'ho implementato. Lo farò con un aggiornamento OTA
    Gesendet von meinem NX505J mit Tapatalk
  9. I seguenti 4 Utenti hanno ringraziato Cuoco92 per il post:
    eddie1967 (11-04-16),icomei (11-04-16),nevrastenek (11-04-16),RobbyBtheOriginal (11-04-16)
  10. #2376
    Quote Originariamente inviato da fabri77 Visualizza il messaggio
    Sei sicuro che l'installazione vada a buon fine? Hai tolto la spunta a wipe cashe?
    Inviato dal mio NX507J utilizzando Tapatalk
    Grazie. Purtroppo non mastico molto android.....cmq fatto come tu hai detto e aggiornato. Ora noto una cosa pero, tutto OK su tutto tranne un cadimento della linea. Ho sullo slot 1 la Tim e sul 2 la tre. Prima a casa prendevano il.max ora solo una linietta........come mai.....a volte la tre non ha campo addirittura....
  11. #2377
    Oct 2013
    Ringraziato 76 volte in 64 Posts
    Quote Originariamente inviato da sguenc Visualizza il messaggio
    Non saprei, non credo sia colpa della rom. Io ho Tim e Vodafone e prendono bene entrambi. Forse stanno lavorando sui ripetitori nella tua zona. Vedi se quando ti sposti migliora.
  12. #2378
    HuaweiP1/XiaomiRed/NubiaZ7mini
    Ringraziato 43 volte in 39 Posts
    Anche io con Tim ho notato un decadimento del segnale con l'ultima ROM.
  13. #2379
    ZTE Z7 Mini
    Quote Originariamente inviato da Cuoco92 Visualizza il messaggio
    Grande!!! Era una features utilissima.
    Provo a chiedere se sei a conoscenza che non si riesce a fare la ricerca di contatti su un account Exchange, sarebbe comodissmo e purtroppo non ha mai funzionato con le tue release, sono disponibile a fare da "cavia".
    Grazie mille.
  14. #2380
    Cmq dopo l aggiornamento il problema del segnale e serio ...praticamente lo aggancia e lo perde in continuazione. Prima non era cosi....anzi era ottimo. Cuoco se puoi risolvere con qualche dritta altrimenti personalmente non posso più utilizzare il tel. Mi serve per lavoro e sono quasi sempre irraggiungibile da stamani ovvero dopo l aggiornamento....grazie
