Pagina 47 di 62 primaprima ... 37454647484957 ... ultimoultimo
Visualizzazione dei risultati da 461 a 470 su 615
[ROM] [Z7MAX] [Android 7.1] CM 14.1 unofficial
  1. #461
    Quote Originariamente inviato da marefix Visualizza il messaggio
    Scusate,per passare dal beta 8 al beta 9 bisogna solo flashare o anche i wipe....non ricordo......
    Solo wipe cache e dalvik
    Inviato dal mio NX505J utilizzando Tapatalk
    Nubia Z7MAX
  2. Il seguente Utente ha ringraziato PaoloW8 per il post:
    marefix (19-02-17)
    Feb 2017
    Is this ROM, you can overclock CPU and GPU?
  5. #463
    Quote Originariamente inviato da HugeDick Visualizza il messaggio
    no, overclock is not supported
    Nubia Z7MAX
  6. #464
    Feb 2017
    This means that you will never overclock? Did you could compile a custom kernel?
  7. #465
    Jul 2015
    Quote Originariamente inviato da PaoloW8 Visualizza il messaggio
    I got no launcher problem, after upgrade from beta8 to beta9. (wiped cache and dalvik)
    now I have been back to beta8 ... any idea?
  8. #466
    I will not add support to overclock in the kernel so don't ask
    Quote Originariamente inviato da securecrt Visualizza il messaggio
    you using the stock launcher (trebuchet) ? if yes you can try to use another launcher like nova
    @all
    this is the italian discussion so please write in italian here
    for english support use the english discussion: https://www.androidiani.com/forum/in...nofficial.html
    Nubia Z7MAX
  9. #467
    Feb 2017
    Without a custom kernel Z7 Max does not show the full potential. That's the truth. It's a shame that no one will take to compile this kernel.
    Ultima modifica di HugeDick; 20-02-17 alle 17:28
  10. #468
    lol sure....for have 1k more point in antutu -.-
    overclocking is useless in the daily use
    btw, I'm not interested in overclock but if you want you can add by yourself, my kernel source code: https://github.com/PaoloW8/android_k...5j/tree/cm14.1
    Nubia Z7MAX
  11. #469
    Mar 2014
    Ciao Paolo. Stò cercando di fare un backup della "9" con la 3.03; si interrompe con "process ended with error 255 ; che faccio? provo ricaricando la 3.02?
  12. #470
    Quote Originariamente inviato da vittovitto Visualizza il messaggio
    l'errore 255 dovrebbe essere "not enough space", sicuro di aver abbastanza spazio libero ?
    se stai facendo il backup nella memoria interna prova sulla SD (oppure il contrario)
    personalmente ho fatto millemila backup e non mi ha mai dato problemi
    Nubia Z7MAX
