Pagina 59 di 62 primaprima ... 9495758596061 ... ultimoultimo
Visualizzazione dei risultati da 581 a 590 su 615
[ROM] [Z7MAX] [Android 7.1] CM 14.1 unofficial
  1. #581
    Apr 2015
    A me whatsapp con beta11 va bene...
    Feb 2016
    I have installed this ROM, but have problems with LTE
    Should I install baseband?
    Can I do it now, after booting anu using system?
  4. #583
    Senior Droid L'avatar di ase11
    Ringraziato 47 volte in 44 Posts
    Quote Originariamente inviato da WywernPL Visualizza il messaggio
    yeah, install baseband 3.89, just flash it from TWRP.
  5. #584
    Feb 2016
    Quote Originariamente inviato da ase11 Visualizza il messaggio
    Thank you.
    LTE works on SIM2
    But SIM1 doesn't see network signal at all
    Should I make dalvik and cache wipe? Or what?
  6. #585
    Thank you.
    LTE works on SIM2
    Well, I never used my Z7 with two SIMs so I am not sure. Dalvik and cache wipe does not hurt, though. Try it.
    As you know Z7 lacks B20 band of LTE, so check also with your provider if they use B20 in your spot.
  7. #586
    Feb 2016
    Problem is - according to SIM1 there is no connection (signal strenght = 0)
    I even can't make or receive a call or text message
  8. #587
    mmhmm...it sounds like an hardware issue. Before flashing CM14 Beta11, did SIM1 work?
  9. #588
    Feb 2016
    Yes, worked also on CM14, before update of baseband
    I tried to switch the SIMs, phone recognizes both ok, but still SIM1 don't work and SIM2 works fine.
    I updated baseband with both cards inserted. You think I fried card or slot?
    Ultima modifica di WywernPL; 20-06-17 alle 16:46
  10. #589
    I do not think so. Can you roll back to the previous baseband?
  11. #590
    Feb 2016
    Hmm, I have to guess which one was it - it was installed 1,5 year ago with CM12...
    But, of course - it is still somewhere on my disk
    For now, tried to remove both cards, wipe and installl baseband 3.89 again. Boot with cards
    Nothing changed
    Installed back version of baseband 3.77, still the same
    Ultima modifica di WywernPL; 20-06-17 alle 20:36
