Pagina 60 di 62 primaprima ... 10505859606162 ultimoultimo
Visualizzazione dei risultati da 591 a 600 su 615
[ROM] [Z7MAX] [Android 7.1] CM 14.1 unofficial
  1. #591
    Senior Droid L'avatar di ase11
    Ringraziato 47 volte in 44 Posts
    I am running out of ideas. Try to install CM13 and see what happens.
    Feb 2016
    I have 2 more:
    - install baseband, then update CM14 to Lineage CM14 from needrom (ver 19-05-2017)
    - restore my twrp backup from before update of baseband
    and then, as last resort, full wipe and install CM13
    [EDIT]
    Restore didn't help
    So, only full wipe and CM13 left on table - I'll do it later
    But first I want to try baseband 3,78 and Lineage CM14.
    Do you think this https://www.needrom.com/download/lineageos/ will go without full wipe? Or better make it?
    Ultima modifica di WywernPL; 21-06-17 alle 12:50
  4. #593
    I would do a full wipe.
  5. Il seguente Utente ha ringraziato ase11 per il post:
    WywernPL (21-06-17)
  6. #594
    Feb 2016
    Wiped dalvik+cache -> installed baseband 3,89 -> lineage CM14 (ver 17-04-2017) -> gapps nano
    Both cards works!!
    Connected to LTE
    Thank you for your help
  7. #595
    Feb 2016
    Today I found error in ROM: bluetooth headset is droping the sound once per 3-4 sec
    Audiobook is unreadable
    Lack of possibility to set "ask everytime" for card choice for SMS is painfull also.
    Ultima modifica di WywernPL; 22-06-17 alle 15:02
  8. #596
    unfortunately it's a known bug since CM13 (at least for me) but Paolo couldn't find the solution.
    As workaround I usually reboot the phone while keeping the headset on. In this way bluetooth connection is ok
    Sent from my NX505J using Forum Fiend v1.3.3.
  9. #597
    For SMS, there is a little icon you can use to chance default SIM before start typing
  10. #598
    Feb 2016
    Quote Originariamente inviato da roby777 Visualizza il messaggio
    On CM14 beta3 it worked flawlessly
  11. #599
    Un saluto a tutti i possessori di Z7 max.
    Ho istallato senza alcun problema la beta 10 ma purtroppo non riesco ad istallare la beta 11, quando vado ad installare lo zip da recovery (TWR 3.1.0-0) mi da sempre un errore:
    "Il processo Updater è terminato con ERRORE: 7 - Errore durante l'istallazione dello zip ..."
    Qualcuno può darmi informazioni circa l'errore e la possibile soluzione.
    Grazie mille in anticipo
  12. #600
    Feb 2016
    Strange,I saw identical problem with other branch of CM14 on needrom
    Did you check md5, or download your install zip again?
