[KERNEL] [OP5] [N] [OxygenOS] SimpleGX
    Moderatore L'avatar di BlackJack89
    Vault 105
    OnePlus 5
    Ringraziato 741 volte in 538 Posts
    N.B. Kernel solo per OnePlus 5
    Kernel pronto all'uso, che non necessita di programmi dedicati per la configurazione, mira al miglioramento dei consumi e delle prestazioni generali, aggiungendo alcune ottimizzazioni (non sperimentali) e restando fedele al kernel stock.
    Caratteristiche:
    • Always directly based from latest available "android_kernel_oneplus_msm8998" Android 7.1.1 source from OxygenOS / OnePlus 5 (for clean work)
    • Compiled with stock Google (4.9.x / aarch64-linux-android) toolchain (for best stability)
    • Featuring Anykenel2 (for all ramdisk compatibility)
    • Stock Linux 4.4.21
    • USB fast charge support (disabled by default)
    • Kernel logger disabled
    • Fixed annoying minimum backlight level
    • Wakelocks control support (all wakelocks disabled by default)
    • Several fixes/optimizations patches for stock cpufreq_conservative governor
    • MAPLE I/O scheduler added (and set as default)
    • Completely optimized stock 'cfq' I/O scheduler
    • Xbox controller (and other USB pads) support
    • All TCP congestion control modules activated with Westwood currently as default
    • Removed verify and forced encryption + patched SafetyNet flags to pass CTS
    • Wlan module from official OOS source
    • Some miscellaneous tweaks, fix, patches and security patches to improve overall smoothness and battery life experience
    Prerequisiti prima del flash:
    • Bootloader Sbloccato
    • Rom OxygenOS basata su android N
    • TWRP
    • Opzionale: Kernel Adiutor
    Verificato questo, procediamo col download e flash,
    1. Riavvio in recovery
    2. Backup sempre consigliato
    3. Wipe dalvik/cache
    4. Flash kernel
    5. Reboot
    Per effettuare un'installazione pulita, al punto 3 effettuare un wipe system, successivamente procedere con
    1. Flash della rom
    2. Flash del kernel
    3. Flash Magisk per il root
    4. Riavvio
    Per aggiornare il kernel
    • Da twrp
    • Flash kernel
    • Flash root (magisk o supersu)
    • Wipe cache + dalvik cache
    Download
    QUI
    Link alla Discussione Ufficiale
    Si ringrazia XDA & AndroidGX per le info su cui si basa la guida.
    Un Grazie è sempre ben accetto
  2. Il seguente Utente ha ringraziato BlackJack89 per il post:
    kmd (01-10-17)
    kmd
    kmd non è in linea
    OnePlus 9Pro, OnePlus 11
    @BlackJack89
    lo hai usato o lo stai usando?
    come ti sembra?
    Ultima modifica di kmd; 03-10-17 alle 11:08
  5. #3
    Vault 105
    OnePlus 5
    Il mio telefono sfortunatamente deve ancora arrivare infatti non ho più notizie da Gearbest...spero arrivi così procedo ai test ! Su xda dicono vada bene
    Inviato dal mio MI 5 utilizzando Tapatalk
