Pagina 20 di 125 primaprima ... 1018192021223070120 ... ultimoultimo
Visualizzazione dei risultati da 191 a 200 su 1247
[ROM][GT-S5830i][UNOFFICIAL] CyanogenMod 7.2 per cooperve by Bieltv.3 e Spacecaker!!!
  1. #191
    Senior Droid L'avatar di davideowl
    Bologna
    Samsung Galaxy Ace-i
    Ringraziato 81 volte in 76 Posts
    Aggiorno:
    "We are having some issues with new test ROM. Some of the testers are trying to boot. New ROM, must be installed in EXT4 partition, so meta-inf was said to mount RFS while ROM was prepared to boot in EXT4, maybe here our issues with dalvik. I sended new meta-inf to testers, and Im waiting his report.
    Im in contact with developer on SGY and here Ill make u an update of what we are working, fix camera, yes. That its much more difficult than we thought, we though that the error was in format YUV - RGB, but actually seems that our problem is more related to HW drivvers. Not the display one (the one broadcom provide us) tje libstatgefright. Actuallyy samsung is using froyo libs for devices with GB on it. The problem is that the stock libstatgefright call those libs in some moment of the processing. Libstatgefright from CM is diferent from stock and necessary to have it to run CM7, so we can not just replace the lib. What we need to do its find out whem those froyo libs are called and modify libstatgefright source to call them same as stock. Problem? Same as HW drivers. We can not revert engineer yet, so we must hack the code, which is nearly impossible, samsung modify libstatgefright, and they didnt provide us source of it, making video encoding/decoding impossible -> camera preview, recording video amd HQ videosa (youtube and gallery) we are really bad lucky. We will do our best to solve this issue, but thats really dificult."
    Bieltv.3
    Quindi per ora sembra ancora rimandata l'uscita...
    Smartphone: Samsung Galaxy Ace GT-S5830i
    Rom: SGS3 V5 (Sniper Killer)
    Androidiano VIP L'avatar di Lopicl
    Samsung Galaxy Ace i / Nexus 7
    Ringraziato 706 volte in 308 Posts
    Aggiorno io:
    Stò provando lo zip della cm 7 con updater-script modificato da me.
    Se funziona sono un grande!
    Inviato dal mio GT-S5830i con Tapatalk 2
    Smartphone: Samsung Galaxy Ace-i
    ROM: Super IceDroid v3.0 fatta da me!
    Kernel: Hells Fusion v2
    I miei lavori per l'Ace-i:
    Super IceDroid v3.0
    Super XtremeDroid v2
    Ricordatevi sempre il tasto THANKS!
  4. I seguenti 3 Utenti hanno ringraziato Lopicl per il post:
    davideowl (26-04-13),Sabo98 (26-04-13),sorrygladiatore (27-04-13)
  5. #193
    Bologna
    Quote Originariamente inviato da Lopicl Visualizza il messaggio
    Aggiorno io:
    Il nostro eroe!
  6. #194
    Androidiano L'avatar di bannab
    Spilamberto (MO)
    samsung galaxy ace gt-s5830i
    Ringraziato 70 volte in 58 Posts
    Aggiorno io:
    Vai lopicl!!!!!!
    Se ti sono stato d'aiuto clicca il tasto thanks!
    Device: Samsung galaxy ace-i (gt-s5830i)
  7. #195
    Androidiano L'avatar di sorrygladiatore
    Gangi
    Bravo Lopic
    Inviato dal mio GT-S5830i usando Androidiani App
  8. #196
    Spilamberto (MO)
    Ci sei riuscito lopicl...?
  9. #197
    Bologna
    Quote Originariamente inviato da bannab Visualizza il messaggio
    no se leggi su xda dice che sta ancora lavorando... ma noi crediamo in te!
  10. #198
    Senior Droid L'avatar di Sabo98
    Lumia 735
    Ringraziato 52 volte in 41 Posts
    Aggiornamenti?
    Cosa fai quando i tuoi ideali vanno in pezzi? Non lo so, non te lo insegnano a scuola.
    [Stevo-SLC Punk Fuori Di Cresta]
  11. #199
    Palermo
    Galaxy ace plus(sgap)
    Una cm stabile per 5830i senza bug esiste???
  12. #200
    Bologna
    No non esiste ancora
