Pagina 7 di 9 primaprima ... 56789 ultimoultimo
Visualizzazione dei risultati da 61 a 70 su 88
[AGGIORNATO][ROM][GT-S5830i][UNOFFICIAL] CYANOGENMOD 9.1 by Bieltv.3
  1. #61
    Androidiano VIP L'avatar di devilyuri
    GALAXY next turbo
    Ringraziato 777 volte in 496 Posts
    Per il play store basta mettere il file userinit.sh nella cartella data/local e riavviare
  2. Il seguente Utente ha ringraziato devilyuri per il post:
    megauser (03-07-14)
    Senior Droid L'avatar di megauser
    Altamura
    GT-s5830i
    Ringraziato 68 volte in 48 Posts
    Quote Originariamente inviato da devilyuri Visualizza il messaggio
    scusa per il ritardo grazie per l'informazione devilyuri
    BRICCANDO SI IMPARA
    la mia rom per galaxy ace-i qui: http://www.androidiani.com/forum/mod...ml#post5191353
  5. #63
    Samsung Galaxy Ace GT-S5830i
    Dove lo trovo?
  6. #64
    Androidiano L'avatar di update01
    Apr 2014
    Rilasciata una nuova versione Beta 5 di seguito le novità :
    • Re-newed device tree from scratch
    • Optimized libgralloc and libhwcomposer
    • Fixed laggy bootanimation
    • Completly removed artifacts on screen due to bad HW drivers
    • Finally improved and fixed whole HW system
    • Imporved Nexus S audio libs
    • Fixed microphone
    • New liblight lib open source - future support of BLN
    • New camera library based on QCOM msm7x27 devices
    • Camera preview working
    • Camera pictures working too on native camera app
    • Added all propietary necessary camera libs
    • Panorama mode also working
    • New binary for get_macaddrs and patched libbrcm_ril.so
    • New WIFI configurations
    • FIxed WIFI signal bars
    • Fixed GPS, need more tests
    • Stop using old Bluetooth system, and swithced to CM9
    • Renewed and swithced to AOSP open offline charging
    • Vold now built from source, and faster media scanning
    • Fix battery capacity of some devices, and imrporved battery stats
    • Init and adb binaried built from source
    • Fixed whole adb system (adb shell, su)
    • Force adb to work on the first boot without debug options
    • CWM6 built from ICS source and integrated on kernel build
    • New kernel worked from 0 for all three devices
    • New ramdisk full compatible with CM9 and built from source
    • Common kernel is present on this build
    • Switched to Alcatel libv3d kernel drivers
    • Adapted cooperve camera drivers to common kernel
    • New recovery.fstab partitiont table
    Il download come sempre è disponibile sul sito di Bieltv.3 , megauser appena puoi aggiorna il primo post del 3d
    Forza ragazzi sotto con i vari test
    Samsung Galaxy Ace - GT-S5830i
    Rom : CyanogenMod 11
    Kernel : 2.6.35.7 Jenkins@piripiri209 # 1
    Data build : Web Feb 11 12:50:36 CET 2015
  7. Il seguente Utente ha ringraziato update01 per il post:
    Max94 (18-07-14)
  8. #65
    Senior Droid L'avatar di gilbez
    Torino
    Samsung pocket 3G, GT5830i, n4
    Ringraziato 91 volte in 76 Posts
    Sissignore! La guida per installare la beta 5? Ce la troviamo noi tester per voi?
  9. #66
    Apr 2014
    Quote Originariamente inviato da gilbez Visualizza il messaggio
    Dalle domande e il modo con cui le hai poste mi sa che sei tutto tranne che un vero appassionato di test ... nessuno ti obbliga a provare nulla .
    Ultima modifica di update01; 17-07-14 alle 11:37
  10. #67
    Androidiano L'avatar di simo798
    Catania
    Redmi Note 7
    Ringraziato 84 volte in 39 Posts
    Qualcuno che ha installato la beta 5, riesce a ricevere le telefonate? Io riesco a effettuare le telefonate ma non le ricevo.
    Redmi Note 7 Stock
    exDevice: LG G2 D802
    Rom: Cloudy G2 3.0
    Kernel: Stock kernel
    exDevice:Lg G Pad 8.3
    Rom: Stock Rom 4.4.2 Rooted
    Kernel: Stock Kernel
    Clicca sul tasto Thanks se ti sono stato d'aiuto
  11. #68
    Mar 2014
    Quote Originariamente inviato da simo798 Visualizza il messaggio
    hai fatto riferimento a questi :
    Clockworkrecs5830i.zip
    ext4_formatter.zip
    kernel_CM7_v4.0_cooperve.zip
    CM9_cooperve_Beta_05.zip
    GoogleApps_GearCM_CM9_20140711.zip
    le prove con i file sopra citati sono una tua libera scelta.
    In rete trovi (turchia) dettaglio installazione
    Per tua utilità :ci sono molti problemi in questa rom, consulta in rete perché è così problematico....ti riporto i bug:
    1 - altoparlante frontale e la cuffia non funziona.
    2 - Chiamate suono non vanno e vengono.
    3 - Video Capture non funziona
    4 - condivisione internet non funziona. (Tethering)
  12. #69
    Catania
    Redmi Note 7
    Ho rimesso la stock, la cm9 è veramente fluidissima, ma se non fosse per i problemi alla capsula auricolare, agli auricolari e alla parte telefonica la terrei come rom giornaliera.
    Redmi Note 7 Stock
    Rom: Cloudy G2 3.0
  13. #70
    Androidiano L'avatar di pentola
    Jan 2014
    Ringraziato 34 volte in 34 Posts
    Tenere una rom che non ti fa telefonare è impossibile. Lo sviluppo non è dei più veloci, ma siamo fiduciosi.
    Inviato dal mio B1-711 usando Androidiani App
