Utente del mese: bluemask con ben 32 Thanks ricevuti nell'ultimo mese
Pagina 68 di 112 primaprima ... 1858666768697078 ... ultimoultimo
Visualizzazione dei risultati da 671 a 680 su 1118
[ROM] [09/07/12] CyanogenMod 7.2 RC3 APOCALYPSE FINAL Edition
  1. #671
    Androidiano VIP L'avatar di erghetto
    Napoli
    Galaxy S6 Flat SM-G920F
    Ringraziato 385 volte in 344 Posts
    eh lo so, ma senza offesa spero possano rispondermi matt o theflanker con una spiegazione più "tecnica" ^^
    [Smartphone] Samsung Galaxy S6 Flat (SM-G920F)
    [ROM] Noble Nougat Experience 4.5
    [kernel] Kiboi kernel 2.5
    Viareggio
    Samsung Galaxy S III
    Ringraziato 21 volte in 21 Posts
    Quote Originariamente inviato da erghetto Visualizza il messaggio
    domani esce l'ultima versione della apocalypse..
    Changelog for APOCALYPSE FINAL - 09.07.2012
    - stable, fast and lag-free (to the closest possible)
    - based on official CM7 Nighlty 01.07.2012
    - firekernel updated to 23.06.12 OC-Official
    - build.prop cleaned + added some tweaks
    - updater-script cleaned and done correctly
    - adreno libs updated
    - hw libraries replaced with latest stock libs
    - stock gpsd added to system/bin
    - simple gps.conf just like in Lagloose's patch
    (actually this rom has lagloose's patch but with updated libs)
    - clock on right
    - launcher changed to launcherpro
    (for those with paid version just download licence from market)
    - theme changed to original ICS and modded
    (touchwiz style settings icons, ics dock icons for launcher pro, all the other stuff from previous theme with no window glow or transparency)
    - torch is working on status bar
    - added bln support to official nightly
    - added CWM Manager to official nightly
    - added livewallpaperspicker to official nightly
    - added some deleted CM7 apps in previous versions like pacman, html viewer
    (now when you press "search" on play store or type a url in browser you don't see the homescreen background)
    - re-edited sliding tabs and rotary styles in lockscreen (slightly lighter in color) Lens is left untouched.
    - no gallery, mms, camera or file manager
    (rom is "kinda" barebone - plenty of choices out there, install the ones you want)
    - new bootanimation -- Looks very very good!!!
    - google play store updated to 3.7.13
    - superuser updated to 3.1.3
    Rom still has 30volume steps with fixed ui volume, AE integrated, beats_alsa+audiofx widget, sansation normal and bold font characters fixed for all languages
    Phone runs fine even with live wallpapers on. Coming late night on 09.07.2012 - STAY TUNED!!!
    P.S. vorrei fare una domanda.. è probabile che proverò quest'ultima apocalypse, ma facendo ovviamente un backup di quella attuale nel caso in cui nn dovesse andarmi bene..
    ciò che mi chiedo è.. quando si fa un restore non si dovrebbe in teoria fare un wipe data e tutto il resto?
    cioè il restore esattamente cosa fa? a livello di scrittura files dico..
    esempio.. installo l'ultima apocalypse che uscirà domani.. non mi piace allora faccio il restore per rimettere quella attuale.. tutti i files riguardanti la apocalypse finale che fine fanno? non restano li? se si.. non possono creare problemi?
    vi faccio questo domande perchè ignoro del tutto la questione e mi piacerebbe tanto poter avere una delucidazione in merito ^^
    no non occorre fare i wipe .. io quando facevo il restore non li ho mai fatti , i file riguardanti l'apocalypse vengono rimpiazzati dai file del tuo restore .... , quelli sulla sd restano ... ma te li puoi tranquillamente eliminare
    edit: la mia risposta ti va bene ? xD
  4. #673
    Senior Droid L'avatar di Publio41
    Tivoli(Rm)
    Samsung Galaxy s6edge
    ti dicevo erghetto,non è che tu hai provato a fare:impostazioni>cyanogenmod>performnce?
  5. #674
    Napoli
    @lusserdarmus: va bene grazie XD
    @publio41: si quella dico è normale che esca quel mess.. perchè vai a modificare le frequenze del processore e il modo in cui viene gestito.. quindi il cell ti avverte di stare attento a ciò che fai.. se sai cosa fai vai tranquillo XD
    Ultima modifica di erghetto; 08-07-12 alle 23:23
  6. #675
    Tivoli(Rm)
    @erghetto comunque quando provi la nuova rom puoi tranquillamente fare il full wipe avendo già fatto il backup.......te lo dico di sicuro perchè adesso ho provato una rom per vedere di che si trattasse e facendo prima il backup ho flashato la rom facendo il full wipe ma visto che non mi è piaciuta ho fatto restore ed ho di nuovo l'apocalypse con tutte le applicazioni..............così sei tranquillo?
  7. #676
    Androidiano VIP L'avatar di theflanker
    Ace-> Xperia T30p-> Xperia Z2
    Ringraziato 382 volte in 296 Posts
    Quote Originariamente inviato da Publio41 Visualizza il messaggio
    @erghetto
    mi potete linkare la pagina dove posso trovare l'istallazione della s2e per la memoria interna(la vorrei provare)?
    Publiooooooooo hai postato tre volte di seguito USA IL TASTO MODIFICAAAA. Non sei nuovo del forum dai fa il bravo
    Per S2e è ad inizio guida nel secondo post scritta da Matt
    Ultima modifica di theflanker; 09-07-12 alle 13:44
    Se ti sono stato utile usa il thanks
    XPERIA T LT30p UB
    CM12 UNOFFICIAL Neo's Homebuild
    I miei lavori in sez. Galaxy Ace
  8. #677
    Trentola-Ducenta (CE)
    SAMSUNG GALAXY S6 64 GB
    Ringraziato 24 volte in 24 Posts
    Ragazzi ma quando dovrebbe uscire?
    LG G4 32 GB METALLIC GREY
    [Versione Android] 6.0 Marshmallow
    [ROM] Imperium Rom v1.1
    [Kernel] 3.10.101
    [Numero Build] Imperium Rom v1.1
    [Versione SW] V20e-EUR-XX
    Se ti sono stato utile schiaccia un THANKS!
  9. #678
    Viareggio
    Ragazzi e' uscita la beta 9 di CM 9 !!!!! adesso faccio subito una guida !!!! e ne ho fatta una ieri sulla miui ... xD
    edit: c'e il topic ufficiale iniziato da mik90 quindi se a qualcuno interessa ecco qua https://www.androidiani.com/forum/mo...xyics-167.html
    Ultima modifica di Lusserdarmus; 09-07-12 alle 15:29
  10. #679
    Tivoli(Rm)
    dove si trova?
  11. #680
    Viareggio
    dove si trova?
    qui sul forum ... comunque cercala su google e la troverai
